IDEL audit message for ILM-initiated deletions in StorageGRID
This message is generated when ILM starts the process of deleting an object.
The IDEL message is generated in either of these situations:
  • For objects in compliant S3 buckets: This message is generated when ILM starts the process of auto-deleting an object because its retention period has expired (assuming the auto-delete setting is enabled and legal hold is off).
  • For objects in non-compliant S3 buckets. This message is generated when ILM starts the process of deleting an object because no placement instructions in the active ILM policies currently apply to the object.
Code Field Description
CBID
Content Block Identifier
The CBID of the object.
CMPA
Compliance: Auto delete
For objects in compliant S3 buckets only. 0 (false) or 1 (true), indicating whether a compliant object should be deleted automatically when its retention period ends, unless the bucket is under a legal hold.
CMPL
Compliance: Legal hold
For objects in compliant S3 buckets only. 0 (false) or 1 (true), indicating whether the bucket is currently under a legal hold.
CMPR
Compliance: Retention period
For objects in compliant S3 buckets only. The length of the object's retention period in minutes.
CTME
Compliance: Ingest time
For objects in compliant S3 buckets only. The object's ingest time. You can add the retention period in minutes to this value to determine when the object can be deleted from the bucket.
DMRK
Delete Marker Version ID
The version ID of the delete marker created when deleting an object from a versioned bucket. Operations on buckets don't include this field.
CSIZ
Content size
The size of the object in bytes.
LOCS
Locations
The storage location of object data within the StorageGRID system. The value for LOCS is "" if the object has no locations (for example, it has been deleted).
CLEC: for erasure-coded objects, the erasure-coding profile ID and the erasure coding group ID that is applied to the object's data.
CLDI: for replicated objects, the LDR node ID and the volume ID of the object's location.
CLNL: ARC node ID of the object's location if the object data is archived.
PATH
S3 Bucket/Key
The S3 bucket name and S3 key name.
RSLT
Result
The result of the ILM operation.
SUCS: The ILM operation was successful.
RULE
Rules Label
  • If an object in a compliant S3 bucket is being deleted automatically because its retention period has expired, this field is blank.
  • If the object is being deleted because there are no more placement instructions that currently apply to the object, this field shows the human-readable label of the last ILM rule that applied to the object.
SGRP
Site (Group)
If present, the object was deleted at the site specified, which is not the site where the object was ingested.
UUID
Universally Unique Identifier
The identifier of the object within the StorageGRID system.
VSID
Version ID
The version ID of the specific version of an object that was deleted. Operations on buckets and objects in unversioned buckets don't include this field.
