Configure S3 regions for StorageGRID
ILM rules can filter objects based on the optional regions where S3 buckets are created, allowing you to store objects from different regions in different storage locations.
If you want to use an S3 bucket region as a filter in a rule, you must first create the regions that can be used by the buckets in your system.
Note You can't change the region for a bucket after the bucket has been created.
Before you begin
About this task
When creating an S3 bucket, you can specify that the bucket be created in a specific region. Specifying a region allows the bucket to be geographically close to its users, which can help optimize latency, minimize costs, and address regulatory requirements.
When you create an ILM rule, you might want to use the region associated with an S3 bucket as an advanced filter. For example, you can design a rule that applies only to objects in S3 buckets created in the us-west-2 region. You can then specify that copies of those objects be placed on Storage Nodes at a data center site within that region to optimize latency.
When configuring regions, follow these guidelines:
  • By default, all buckets are considered to belong to the us-east-1 region.
  • You must create the regions using the Grid Manager before you can specify a non-default region when creating buckets using the Tenant Manager or Tenant Management API, or with the LocationConstraint request element for S3 PUT Bucket API requests. An error occurs if a PUT Bucket request uses a region that hasn't been defined in StorageGRID.
  • You must use the exact region name when you create the S3 bucket. Region names are case sensitive. Valid characters are numbers, letters, and hyphens.
    Note EU isn't considered to be an alias for eu-west-1. If you want to use the EU or eu-west-1 region, you must use the exact name.
  • You can't delete or modify a region if it's used in a rule that is assigned to any policy (active or inactive).
  • If you use an invalid region as the advanced filter in an ILM rule, you can't add that rule to a policy.
    An invalid region can result if you use a region as an advanced filter in an ILM rule but you later delete that region, or if you use the Grid Management API to create a rule and specify a region that you haven't defined.
  • If you delete a region after using it to create an S3 bucket, you will need to re-add the region if you ever want to use the Location Constraint advanced filter to find objects in that bucket.
Steps
  1. Select ILM > Regions.
    The Regions page appears.
  2. Select the All regions or Default region tab.
    All regions
    The All regions tab lists the currently defined regions, including the defined default region.
    Note You can't remove or modify the default region in the All regions tab. Use the Default region tab to change the default region.
    1. To add a region, select Add another region.
    2. Enter the name of a region that you want to use when creating S3 buckets.
      You must use this exact region name as the LocationConstraint request element when you create the corresponding S3 bucket.
    3. To remove an unused region, select the delete icon Remove icon.
      An error message appears if you attempt to remove a region that is currently used in any policy (active or inactive).
    4. When you are done making changes, select Save.
      You can now select these regions from the Advanced filters section in step 1 of the Create ILM rule wizard. See Use advanced filters in ILM rules.
    Default region
    The Default region tab displays the currently defined default region, which you can modify.
    1. To change the default region, select the region name from the available options in the Default region drop-down list.
    2. Select Save.
