Download the StorageGRID recovery package
The recovery package file allows you to restore the StorageGRID system if a failure occurs.
Before you begin
Download the current recovery package file before making grid topology changes to the StorageGRID system or before upgrading software. Then, download a new copy of the recovery package after making grid topology changes or after upgrading software.
Steps
  1. Select Maintenance > System > Recovery package.
  2. Enter the provisioning passphrase, and select Start download.
    The download starts immediately.
  3. When the download completes, open the .zip file and confirm that you can access the contents, including the Passwords.txt file.
  4. Copy the downloaded recovery package file (.zip) to two safe, secure, and separate locations.
    Caution The recovery package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system.
