Gather required materials for StorageGRID grid node recovery
Before performing maintenance procedures, you must ensure you have the necessary materials to recover a failed grid node.
Item Notes
StorageGRID installation archive
If you need to recover a grid node, you need to download the StorageGRID installation files for your platform.
Note: You don't need to download files if you are recovering failed storage volumes on a Storage Node.
Service laptop
The service laptop must have the following:
Recovery package .zip file
Obtain a copy of the most recent recovery package .zip file: sgws-recovery-package-id-revision.zip
The contents of the .zip file are updated each time the system is modified. You are directed to store the most recent version of the recovery package in a secure location after making such changes. Use the most recent copy to recover from grid failures.
When logged in to any Admin Node, use the Grid Manager to download a recovery package. Select Maintenance > System > Recovery package.
If you can't access the Grid Manager, you can find encrypted copies of the recovery package on some Storage Nodes that contain the ADC service. On each Storage Node, examine this location for the recovery package: /var/local/install/sgws-recovery-package-grid-id-revision.zip.gpg Use the recovery package with the highest revision number.
Passwords.txt file
Contains the passwords required to access grid nodes on the command line. Included in the recovery package.
Provisioning passphrase
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not in the Passwords.txt file.
Current documentation for your platform
Go to the platform vendor's website for documentation.
For the current supported versions of your platform, see the NetApp Interoperability Matrix Tool.
Download and extract StorageGRID installation files
Download the software and extract the files, unless you are recovering failed storage volumes on a Storage Node.
You must use the version of StorageGRID that is currently running on the grid.
Steps
  1. Determine which version of the software is currently installed. From the top of the Grid Manager, select the help icon and select About.
  2. Go to the NetApp Downloads page for StorageGRID.
  3. Select the version of StorageGRID that is currently running on the grid.
    StorageGRID software versions have this format: 11.x.y.
  4. Sign in with the username and password for your NetApp account.
  5. Read the End User License Agreement, select the checkbox, and then select Accept & Continue.
  6. In the Install StorageGRID column of the download page, select the .tgz or .zip file for your platform.
    The version shown in the installation archive file must match the version of the software that is currently installed.
    Use the .zip file if you are running Windows.
    Platform Installation archive
    RHEL
    StorageGRID-Webscale-version-RPM-uniqueID.zip
    StorageGRID-Webscale-version-RPM-uniqueID.tgz
    Ubuntu or Debian or Appliances
    StorageGRID-Webscale-version-DEB-uniqueID.zip
    StorageGRID-Webscale-version-DEB-uniqueID.tgz
    VMware
    StorageGRID-Webscale-version-VMware-uniqueID.zip
    StorageGRID-Webscale-version-VMware-uniqueID.tgz
  7. Download and extract the archive file.
  8. Skip to the appropriate section for your platform to choose the files you need, based on your platform and which grid nodes you need to recover.
    The paths listed in the step for each platform are relative to the top-level directory installed by the archive file.
  9. If you are recovering a software-based node, select the appropriate files:
    RHEL
    Path and file name Description
    ./rpms/README
    A text file that describes all of the files contained in the StorageGRID download file.
    ./rpms/NLF000000.txt
    A free license that does not provide any support entitlement for the product.
    ./rpms/StorageGRID-Webscale-Images-version-SHA.rpm
    RPM package for installing the StorageGRID node images on your RHEL hosts.
    ./rpms/StorageGRID-Webscale-Service-version-SHA.rpm
    RPM package for installing the StorageGRID host service on your RHEL hosts.
    Deployment scripting tool
    ./rpms/configure-storagegrid.py
    A Python script used to automate the configuration of a StorageGRID system.
    ./rpms/configure-sga.py
    A Python script used to automate the configuration of StorageGRID appliances.
    ./rpms/configure-storagegrid.sample.json
    An example configuration file for use with the configure-storagegrid.py script.
    ./rpms/storagegrid-ssoauth.py
    An example Python script that you can use to sign in to the Grid Management API when single sign-on is enabled. You can also use this script for Ping Federate integration.
    ./rpms/configure-storagegrid.blank.json
    A blank configuration file for use with the configure-storagegrid.py script.
    ./rpms/extras/ansible
    Example Ansible role and playbook for configuring RHEL hosts for StorageGRID container deployment. You can customize the role or playbook as necessary.
    ./rpms/storagegrid-ssoauth-azure.py
    An example Python script that you can use to sign in to the Grid Management API when single sign-on (SSO) is enabled using Active Directory or Ping Federate.
    ./rpms/storagegrid-ssoauth-azure.js
    A helper script called by the companion storagegrid-ssoauth-azure.py Python script to perform SSO interactions with Azure.
    ./rpms/extras/api-schemas
    API schemas for StorageGRID.
    Note: Before you perform an upgrade, you can use these schemas to confirm that any code you have written to use StorageGRID management APIs will be compatible with the new StorageGRID release if you don't have a non-production StorageGRID environment for upgrade compatibility testing.
    Ubuntu or Debian
    ./debs/README
    ./debs/NLF000000.txt
    A non-production NetApp License File that you can use for testing and proof of concept deployments.
    ./debs/storagegrid-webscale-images-version-SHA.deb
    DEB package for installing the StorageGRID node images on Ubuntu or Debian hosts.
    ./debs/storagegrid-webscale-images-version-SHA.deb.md5
    MD5 checksum for the file /debs/storagegrid-webscale-images-version-SHA.deb.
    ./debs/storagegrid-webscale-service-version-SHA.deb
    DEB package for installing the StorageGRID host service on Ubuntu or Debian hosts.
    ./debs/configure-storagegrid.py
    ./debs/configure-sga.py
    ./debs/storagegrid-ssoauth.py
    ./debs/configure-storagegrid.sample.json
    ./debs/configure-storagegrid.blank.json
    ./debs/extras/ansible
    Example Ansible role and playbook for configuring Ubuntu or Debian hosts for StorageGRID container deployment. You can customize the role or playbook as necessary.
    ./debs/storagegrid-ssoauth-azure.py
    ./debs/storagegrid-ssoauth-azure.js
    ./debs/extras/api-schemas
    VMware
    ./vsphere/README
    ./vsphere/NLF000000.txt
    ./vsphere/NetApp-SG-version-SHA.vmdk
    The virtual machine disk file that is used as a template for creating grid node virtual machines.
    ./vsphere/vsphere-primary-admin.ovf
    ./vsphere/vsphere-primary-admin.mf
    The Open Virtualization Format template file (.ovf) and manifest file (.mf) for deploying the primary Admin Node.
    ./vsphere/vsphere-non-primary-admin.ovf
    ./vsphere/vsphere-non-primary-admin.mf
    The template file (.ovf) and manifest file (.mf) for deploying non-primary Admin Nodes.
    ./vsphere/vsphere-gateway.ovf
    ./vsphere/vsphere-gateway.mf
    The template file (.ovf) and manifest file (.mf) for deploying Gateway Nodes.
    ./vsphere/vsphere-storage.ovf
    ./vsphere/vsphere-storage.mf
    The template file (.ovf) and manifest file (.mf) for deploying virtual machine-based Storage Nodes.
    ./vsphere/deploy-vsphere-ovftool.sh
    A Bash shell script used to automate the deployment of virtual grid nodes.
    ./vsphere/deploy-vsphere-ovftool-sample.ini
    An example configuration file for use with the deploy-vsphere-ovftool.sh script.
    ./vsphere/configure-storagegrid.py
    ./vsphere/configure-sga.py
    ./vsphere/storagegrid-ssoauth.py
    An example Python script that you can use to sign in to the Grid Management API when single sign-on (SSO) is enabled. You can also use this script for Ping Federate integration.
    ./vsphere/configure-storagegrid.sample.json
    ./vsphere/configure-storagegrid.blank.json
    ./vsphere/storagegrid-ssoauth-azure.py
    ./vsphere/storagegrid-ssoauth-azure.js
    ./vsphere/extras/api-schemas
  1. If you are recovering a StorageGRID appliance-based system, select the appropriate files.
Note For appliance installation, these files are required only if you need to avoid network traffic. The appliance can download the required files from the Admin Node where you perform the recovery procedure.
DEB package for installing the StorageGRID node images on your appliances.
MD5 checksum for the file /debs/storagegridwebscale- images-version-SHA.deb.
