Remove StorageGRID port remaps on bare metal hosts
If you want to configure an endpoint for the Load Balancer service, and you want to use a port that has already been configured as the Mapped-To Port of a port remap, you must first remove the existing port remap, or the endpoint will not be effective.
About this task
If you are running StorageGRID on bare metal hosts, follow this procedure instead of the general procedure for removing port remaps. You must edit the node configuration file for each Admin Node and Gateway Node that has conflicting remapped ports to remove all of the node's port remaps and restart the node.
Caution This procedure removes all port remaps. If you need to keep some of the remaps, contact technical support.
For information about configuring load balancer endpoints, see the instructions for administering StorageGRID.
Note This procedure can result in temporary loss of service as nodes are restarted.
Steps
  1. Log in to the host supporting the node. Log in as root or with an account that has sudo permission.
  2. Run the following command to temporarily disable the node: sudo storagegrid node stop node-name
  3. Using a text editor such as vim or pico, edit the node configuration file for the node.
    The node configuration file can be found at /etc/storagegrid/nodes/node-name.conf.
  4. Locate the section of the node configuration file that contains the port remaps.
    See the last two lines in the following example.
    ADMIN_NETWORK_CONFIG = STATIC
    ADMIN_NETWORK_ESL = 10.0.0.0/8, 172.19.0.0/16, 172.21.0.0/16
    ADMIN_NETWORK_GATEWAY = 10.224.0.1
    ADMIN_NETWORK_IP = 10.224.5.140
    ADMIN_NETWORK_MASK = 255.255.248.0
    ADMIN_NETWORK_MTU = 1400
    ADMIN_NETWORK_TARGET = eth1
    ADMIN_NETWORK_TARGET_TYPE = Interface
    BLOCK_DEVICE_VAR_LOCAL = /dev/sda2
    CLIENT_NETWORK_CONFIG = STATIC
    CLIENT_NETWORK_GATEWAY = 47.47.0.1
    CLIENT_NETWORK_IP = 47.47.5.140
    CLIENT_NETWORK_MASK = 255.255.248.0
    CLIENT_NETWORK_MTU = 1400
    CLIENT_NETWORK_TARGET = eth2
    CLIENT_NETWORK_TARGET_TYPE = Interface
    GRID_NETWORK_CONFIG = STATIC
    GRID_NETWORK_GATEWAY = 192.168.0.1
    GRID_NETWORK_IP = 192.168.5.140
    GRID_NETWORK_MASK = 255.255.248.0
    GRID_NETWORK_MTU = 1400
    GRID_NETWORK_TARGET = eth0
    GRID_NETWORK_TARGET_TYPE = Interface
    NODE_TYPE = VM_API_Gateway
    PORT_REMAP = client/tcp/8082/443
    PORT_REMAP_INBOUND = client/tcp/8082/443
  5. Edit the PORT_REMAP and PORT_REMAP_INBOUND entries to remove port remaps.
    PORT_REMAP =
  6. Run the following command to validate your changes to the node configuration file for the node: sudo storagegrid node validate node-name
    Address any errors or warnings before proceeding to the next step.
  7. Run the following command to restart the node without port remaps: sudo storagegrid node start node-name
  8. Log in to the node as admin using the password listed in the Passwords.txt file.
  9. Verify that the services start correctly.
    1. View a list of the statuses of all services on the server:sudo storagegrid-status
      The status is updated automatically.
    2. Wait until all services have a status of either Running or Verified.
    3. Exit the status screen:Ctrl+C
  10. Repeat these steps on each Admin Node and Gateway Node that has conflicting remapped ports.
