Warnings and considerations for StorageGRID node recovery
If a grid node fails, you must recover it as soon as possible. You must review all warnings and considerations for node recovery before you begin.
Caution StorageGRID is a distributed system composed of multiple nodes working with each other. Don't use disk snapshots to restore grid nodes. Instead, refer to the recovery and maintenance procedures for each type of node.
Note If an entire StorageGRID site has failed, contact technical support. Technical support will work with you to develop and execute a site recovery plan that maximizes the amount of data that is recovered and meets your business objectives. Refer to How technical support recovers a site.
Some of the reasons for recovering a failed grid node as soon as possible include the following:
  • A failed grid node can reduce the redundancy of system and object data, leaving you vulnerable to the risk of permanent data loss if another node fails.
  • A failed grid node can impact the efficiency of day-to-day operations.
  • A failed grid node can reduce your ability to monitor system operations.
  • A failed grid node can cause a 500 internal server error if strict ILM rules are in place.
  • If a grid node is not recovered promptly, recovery times might increase. For example, queues might develop that need to be cleared before recovery is complete.
Always follow the recovery procedure for the specific type of grid node you are recovering. Recovery procedures vary for primary or non-primary Admin Nodes, Gateway Nodes, appliance nodes, and Storage Nodes.
Preconditions for recovering grid nodes
All of the following conditions are assumed when recovering grid nodes:
  • The failed physical or virtual hardware has been replaced and configured.
  • The StorageGRID Appliance Installer version on the replacement appliance matches the software version of your StorageGRID system, as described in Verify and upgrade StorageGRID Appliance Installer version.
  • If you are recovering a grid node other than the primary Admin Node, there is connectivity between the grid node being recovered and the Admin Node managing the recovery procedure.
  • If you are recovering an appliance Storage Node, you must specify the same storage type as the original appliance (combined, metadata-only, or data-only) during appliance installation. If you specify a different storage type, the recovery will fail and require reinstallation of the appliance with the correct storage type specified.
Order of node recovery if a server hosting more than one grid node fails
If a server that is hosting more than one grid node fails, you can recover the nodes in any order. However, if the failed server is hosting the primary Admin Node, you must recover that node first.
IP addresses for recovered nodes
Don't attempt to recover a node using an IP address that is currently assigned to any other node. When you deploy the new node, use the failed node's current IP address or an unused IP address.
If you use a new IP address to deploy the new node and then recover the node, the new IP address will continue to be used for the recovered node. If you want to revert to the original IP address, use the Change IP tool after the recovery is complete.
