Access StorageGRID MIB files
MIB files contain definitions and information about the properties of managed resources and services for the nodes in your grid. You can access MIB files that define the objects and notifications for StorageGRID. These files can be useful for monitoring your grid.
See Use SNMP monitoring for more information about SNMP and MIB files.
Access MIB files
Follow these steps to access the MIB files.
Steps
  1. Select Configuration > Monitoring > SNMP agent.
  2. On the SNMP agent page, select the file you want to download:
    • NETAPP-STORAGEGRID-MIB.txt: Defines the alert table and notifications (traps) accessible on all Admin Nodes.
    • ES-NETAPP-06-MIB.mib: Defines objects and notifications for E-Series-based appliances.
    • MIB_1_10.zip: Defines objects and notifications for appliances with a BMC interface.
      Tip You can also access MIB files at the following location on any StorageGRID node: /usr/share/snmp/mibs
  3. To extract the StorageGRID OIDs from the MIB file:
    1. Get the OID of the root of the StorageGRID MIB:
      root@user-adm1:~ # snmptranslate -On -IR storagegrid
      Result: .1.3.6.1.4.1.789.28669 (28669 is always the OID for StorageGRID)
    2. Grep for the StorageGRID OID in the entire tree (using paste to join lines):
      root@user-adm1:~ # snmptranslate -Tso | paste -d " " - - | grep 28669
      Tip The snmptranslate command has many options that are useful for exploring the MIB. This command is available on any StorageGRID node.
MIB file contents
All objects are under the StorageGRID OID.
Object name Object ID (OID) Description
.iso.org.dod.internet.
private.enterprises.
netapp.storagegrid
The MIB module for NetApp StorageGRID entities.
MIB objects
Object name Object ID (OID) Type Access MIB module Description
activeAlertCount
.1.3.6.1.4.1.
789.28669.1.3
Integer32
Read-only
The number of active alerts in the activeAlertTable.
activeAlertTable
.1.3.6.1.4.1.
789.28669.1.4
Sequence of ActiveAlertEntry
Not-accessible
A table of active alerts in StorageGRID.
activeAlertEntry
.1.3.6.1.4.1.
789.28669.1.4.1
Sequence
Not-accessible
A single StorageGRID alert, indexed by alert ID.
activeAlertId
.1.3.6.1.4.1.
789.28669.1.4.1.1
Octet string
Read-only
The ID of the alert. Only unique in the current set of active alerts.
activeAlertName
.1.3.6.1.4.1.
789.28669.1.4.1.2
Octet string
Read-only
The name of the alert.
activeAlertInstance
.1.3.6.1.4.1.
789.28669.1.4.1.3
Octet string
Read-only
The name of the entity that generated the alert, typically the node name.
activeAlertSeverity
.1.3.6.1.4.1.
789.28669.1.4.1.4
Octet string
Read-only
The severity of the alert.
activeAlertStartTime
.1.3.6.1.4.1.
789.28669.1.4.1.5
Date and time
Read-only
The time the alert was triggered.
