What is a StorageGRID Gateway Node?
Gateway Nodes provide a dedicated load-balancing interface that S3 client applications can use to connect to StorageGRID. Load balancing maximizes speed and connection capacity by distributing the workload across multiple Storage Nodes. Gateway Nodes are optional.
The StorageGRID Load Balancer service is provided on all Admin Nodes and all Gateway Nodes. It performs Transport Layer Security (TLS) termination of client requests, inspects the requests, and establishes new secure connections to the Storage Nodes. The Load Balancer service seamlessly directs clients to an optimal Storage Node, so that the failure of nodes or even an entire site is transparent.
You configure one or more load balancer endpoints to define the port and network protocol (HTTPS or HTTP) that incoming and outgoing client requests wil use to access the Load Balancer services on Gateway and Admin Nodes. The load balancer endpoint also defines the client type (S3), the binding mode, and optionally a list of allowed or blocked tenants. See Considerations for load balancing.
As required, you can group the network interfaces of multiple Gateway Nodes and Admin Nodes into a high availability (HA) group. If the active interface in the HA group fails, a backup interface can manage the client application workload. See Manage high availability (HA) groups.
Primary services for Gateway Nodes
The following table shows the primary services for Gateway Nodes; however, this table does not list all node services.
Service Key function
Cache Service
Manages a local cache of object content.
High Availability
Manages high availability virtual IP addresses for groups of Admin Nodes and Gateway Nodes.
Note: This service is also found on Admin Nodes.
Load Balancer
Provides Layer 7 load balancing of S3 traffic from clients to Storage Nodes. This is the recommended load balancing mechanism.
Server Status Monitor (SSM)
Monitors the operating system and underlying hardware.
