Removed or deprecated features and capabilities in StorageGRID
Learn about features and capabilities that have been removed or deprecated in StorageGRID 12.0. Before you upgrade, check whether any removed or deprecated features affect your client applications or grid configuration.
Deprecated
The feature should not be used in new production environments. Existing production environments can continue using the feature.
End of Life
Last shipped version that supports the feature. In some cases, documentation for the feature might be removed at this stage.
Removed
First version that does not support the feature.
StorageGRID end of feature support
Deprecated features will be removed in N+2 major versions. For example, if a feature is deprecated in version N (for example, 6.3), the last version where the feature will exist is N+1 (for example, 6.4). Version N+2 (for example, 6.5) is the first release when the feature doesn't exist in the product.
See the Software Version Support page for additional information.
Note In certain situations, NetApp might end support for particular features sooner than indicated.
Feature Deprecated End of Life Removed Links to earlier documentation
Alarms, legacy (not Alerts)
11.7
11.8
11.9
Archive Node support
11.7
11.8
11.9
Note: Before starting your upgrade, you must:
  1. Decommission all Archive Nodes. See Grid node decommissioning (StorageGRID 11.8 doc site).
  2. Remove all Archive Node references from storage pools and ILM policies. See NetApp Knowledge Base: StorageGRID 11.9 software upgrade resolution guide.
Audit export through CIFS/Samba
11.1
11.6
11.7
CLB service
11.4
11.6
11.7
Docker container engine
11.8
11.9
TBD
Support for Docker as the container engine for software-only deployments is deprecated. Docker will be replaced with another container engine in a future release. Refer to the software requirements for software-based nodes for a list of Docker versions currently supported.
Email setup (legacy)
11.9
12.0
12.1
NFS audit export
11.8
11.9
12.0
Port remap
12.0
12.1
12.2
Swift API support
11.7
11.9
12.0
RHEL 8.8
11.9
11.9
12.0
RHEL 9.0
11.9
11.9
12.0
RHEL 9.2
11.9
11.9
12.0
Ubuntu 18.04
11.9
11.9
12.0
Ubuntu 20.04
11.9
11.9
12.0
Debian 11
11.9
11.9
12.0
Also refer to:
