Configure the container engine storage volume for StorageGRID on Linux
Before installing the Docker or Podman container engine, you might need to format the storage volume and mount it.
Support for Docker as the container engine for software-only deployments is deprecated. Docker will be replaced with another container engine in a future release. |
"Linux" refers to a RHEL, Ubuntu, or Debian deployment. For a list of supported versions, see the NetApp Interoperability Matrix Tool (IMT). |
You can skip these steps if you plan to use the root volume for the Docker or Podman storage volume and have sufficient space available on the host partition containing:
Podman:
/var/lib/containers -
Docker:
/var/lib/docker
Create a file system on the container engine storage volume:
RHELsudo mkfs.ext4 container-engine-storage-volume-device
Ubuntu or Debiansudo mkfs.ext4 docker-storage-volume-device
Mount the container engine storage volume:
RHEL-
For Docker:
sudo mkdir -p /var/lib/docker sudo mount container-storage-volume-device /var/lib/docker
For Podman:
sudo mkdir -p /var/lib/containers sudo mount container-storage-volume-device /var/lib/containers
Ubuntu or Debiansudo mkdir -p /var/lib/docker sudo mount docker-storage-volume-device /var/lib/docker
For Podman:
Add an entry for the container storage volume device to /etc/fstab.
RHEL: container-storage-volume-device
Ubuntu or Debian: docker-storage-volume-device
This step ensures that the storage volume will remount automatically after host reboots.
Install Docker
The StorageGRID system can run on Linux as a collection of containers.
Before you can install StorageGRID for Ubuntu or Debian, you must install Docker.
If you have chosen to use the Docker container engine, follow these steps to install Docker. Otherwise, install Podman.
Install Docker by following the instructions for your Linux distribution.
If Docker is not included with your Linux distribution, you can download it from the Docker website. -
Ensure Docker has been enabled and started by running the following two commands:
sudo systemctl enable docker
sudo systemctl start docker
Confirm you have installed the expected version of Docker by entering the following:
sudo docker version
The Client and Server versions must be 1.11.0 or later.
Install Podman
The StorageGRID system runs as a collection of containers. If you have chosen to use the Podman container engine, follow these steps to install Podman. Otherwise, install Docker.
Install Podman and Podman-Docker by following the instructions for your Linux distribution.
You must also install the Podman-Docker package when you install Podman. -
Confirm you have installed the expected version of Podman and Podman-Docker by entering the following:
sudo docker version
The Podman-Docker package allows you to use Docker commands. The Client and Server versions must be 3.2.3 or later.
Version: 3.2.3 API Version: 3.2.3 Go Version: go1.15.7 Built: Tue Jul 27 03:29:39 2021 OS/Arch: linux/amd64
