Navigate to the StorageGRID Grid Manager
You use the Grid Manager to define all of the information required to configure your StorageGRID system.
Before you begin
The primary Admin Node must be deployed and have completed the initial startup sequence.
Steps
  1. Open your web browser and navigate to:
    https://primary_admin_node_ip
    Alternatively, you can access the Grid Manager on port 8443:
    https://primary_admin_node_ip:8443
    You can use the IP address for the primary Admin Node IP on the Grid Network or on the Admin Network, as appropriate for your network configuration. You might need to use the security/advanced option in your browser to navigate to an untrusted certificate.
  2. Manage a temporary installer password as needed:
    • If a password has already been set using one of these methods, enter the password to proceed.
      • A user set the password while accessing the installer previously
      • For Linux, the password was automatically imported from the node config file at /etc/storagegrid/nodes/<node_name>.conf
      • For VMware, the SSH/console password was automatically imported from the OVF properties
    • If a password has not been set, optionally set a password to secure the StorageGRID installer.
  3. Select Install a StorageGRID system.
    The page used to configure a StorageGRID grid appears.
    StorageGRID installer first screen
