Troubleshoot StorageGRID installation issues
If any problems occur while installing your StorageGRID system, you can access the installation log files. Technical support might also need to use the installation log files to resolve issues.
Note "Linux" refers to a RHEL, Ubuntu, or Debian deployment. For a list of supported versions, see the NetApp Interoperability Matrix Tool (IMT).
Linux
The following installation log files are available from the container that is running each node:
  • /var/local/log/install.log (found on all grid nodes)
  • /var/local/log/gdu-server.log (found on the primary Admin Node)
The following installation log files are available from the host:
  • /var/log/storagegrid/daemon.log
  • /var/log/storagegrid/nodes/node-name.log
To learn how to access the log files, see Collect log files and system data.
VMware
The following are the main installation log files, which technical support might need to resolve issues.
Virtual machine resource reservation requires adjustment
OVF files include a resource reservation designed to ensure that each grid node has sufficient RAM and CPU to operate efficiently. If you create virtual machines by deploying these OVF files on VMware and the predefined number of resources aren't available, the virtual machines will not start.
About this task
If you are certain that the VM host has sufficient resources for each grid node, manually adjust the resources allocated for each virtual machine, and then try starting the virtual machines.
Steps
  1. In the VMware vSphere Hypervisor client tree, select the virtual machine that is not started.
  2. Right‐click the virtual machine, and select Edit Settings.
  3. From the Virtual Machines Properties window, select the Resources tab.
  4. Adjust the resources allocated to the virtual machine:
    1. Select CPU, and then use the Reservation slider to adjust the MHz reserved for this virtual machine.
    2. Select Memory, and then use the Reservation slider to adjust the MB reserved for this virtual machine.
  5. Click OK.
  6. Repeat as required for other virtual machines hosted on the same VM host.
Temporary installation password was disabled
When you deploy a VMware node, you can optionally specify a temporary installation password. You must have this password to access the VM console or use SSH before the new node joins the grid.
If you opted to disable the temporary installation password, you must perform additional steps to debug installation issues.
You can do either of the following:
  • Redeploy the VM but specify a temporary installation password so you can access the console or use SSH to debug installation issues.
  • Use vCenter to set the password:
    1. Power off the VM.
    2. Go to VM, select the Configure tab, and select vApp Options.
    3. Specify type of temporary installation password to set:
      • Select CUSTOM_TEMPORARY_PASSWORD to set a custom temporary password.
      • Select TEMPORARY_PASSWORD_TYPE to use the node name as the temporary password.
    4. Select Set Value.
    5. Set the temporary password:
      • Change CUSTOM_TEMPORARY_PASSWORD to a custom password value.
      • Update the TEMPORARY_PASSWORD_TYPE with the Use node name value.
    6. Restart the VM to apply the new password.
Related information
