Manage StorageGRID bucket policy
You can control user access for an S3 bucket and the objects in that bucket.
Before you begin
  • You are signed in to the Tenant Manager using a supported web browser.
  • You belong to a user group that has the Root access permission. The View all buckets and Manage all buckets permissions only allow viewing.
  • You've verified that the required number of Storage Nodes and sites are available. If two or more Storage Nodes are not available within any site, or if a site is not available, changes to these settings might not be available.
Steps
  1. Select Buckets, then select the bucket you want to manage.
  2. On the bucket details page, select Bucket access > Bucket policy.
  3. Do one of the following:
    • Enter a bucket policy by selecting the Enable policy checkbox. Then enter a valid JSON formatted string.
      Each bucket policy has a size limit of 20,480 bytes.
    • Modify an existing policy by editing the string.
    • Disable a policy by unselecting Enable policy.
For detailed information about bucket policies, including language syntax and examples, see Example bucket policies.
