StorageGRID SG5700 appliances
The SG5700 StorageGRID appliance is an integrated storage and computing platform that operates as a Storage Node in a StorageGRID grid. The appliance can be used in a hybrid grid environment that combines appliance Storage Nodes and virtual (software-based) Storage Nodes.
StorageGRID SG5700 series appliance provides the following features:
Integrate the storage and computing elements for a StorageGRID Storage Node.
Include the StorageGRID Appliance Installer to simplify Storage Node deployment and configuration.
Includes E-Series SANtricity System Manager for hardware management and monitoring.
Support up to four 10-GbE or 25-GbE connections to the StorageGRID Grid Network and Client Network.
Support Full Disk Encryption (FDE) drives or FIPS drives. When these drives are used with the Drive Security feature in SANtricity System Manager, unauthorized access to data is prevented.
The SG5700 appliance is available in four models: the SG5712 and SG5712X, and the SG5760 and SG5760X. There are no specification or functional differences between the SG5712 and SG5712X except for the location of the interconnect ports on the storage controller. Similarly, there are no specification or functional differences between the SG5760 and SG5760X except for the location of the interconnect ports on the storage controller.
SG5700 components
The SG5700 models include the following components:
- Compute controller
E5700SG controller
- Storage controller
E2800A controller
- Chassis
E-Series DE212C enclosure, a two rack-unit (2U) enclosure
- Drives
12 NL-SAS drives (3.5-inch)
- Redundant power supplies and fans
Two power-fan canisters
E5700SG controller
E2800B controller
- Chassis
- Drives
E5700SG controller
E2800A controller
- Chassis
E-Series DE460C enclosure, a four rack-unit (4U) enclosure
- Drives
60 NL-SAS drives (3.5-inch)
Two power canisters and two fan canisters
E5700SG controller
E2800B controller
- Chassis
- Drives
The maximum raw storage available in the StorageGRID appliance is fixed, based on the number of drives in each enclosure. You can't expand the available storage by adding a shelf with additional drives.
SG5700 diagrams
SG5712 front and rear views
The figures show the front and back of the SG5712, a 2U enclosure that holds 12 drives.
SG5712 components
The SG5712 includes two controllers and two power-fan canisters.
| Callout | Description |
1 |
E2800A controller (storage controller) |
2 |
E5700SG controller (compute controller) |
3 |
Power-fan canisters |
SG5712X front and rear views
The figures show the front and back of the SG5712X, a 2U enclosure that holds 12 drives.
SG5712X components
The SG5712X includes two controllers and two power-fan canisters.
1 |
E2800B controller (storage controller) |
2 |
3 |
SG5760 front and rear views
The figures show the front and back of the SG5760 model, a 4U enclosure that holds 60 drives in 5 drive drawers.
SG5760 components
The SG5760 includes two controllers, two fan canisters, and two power canisters.
1 |
2 |
3 |
Fan canister (1 of 2) |
4 |
Power canister (1 of 2) |
SG5760X front and rear views
The figures show the front and back of the SG5760X model, a 4U enclosure that holds 60 drives in 5 drive drawers.
SG5760X components
The SG5760X includes two controllers, two fan canisters, and two power canisters.
1 |
2 |
3 |
4 |
SG5700 controllers
Both the 12-drive SG5712 and SG5712X and the 60-drive SG5760 and SG5760X models of the StorageGRID appliance include an E5700SG compute controller and an E-Series E2800 storage controller.
The SG5712 and SG5760 use a E2800A controller.
The SG5712X and the SG5760X use a E2800B controller.
The E2800A and E2800B controllers are identical in specification and function except for the location of the interconnect ports.
Operates as the compute server for the appliance.
Includes the StorageGRID Appliance Installer.
StorageGRID software is not preinstalled on the appliance. This software is accessed from the Admin Node when you deploy the appliance. -
Can connect to all three StorageGRID networks, including the Grid Network, the Admin Network, and the Client Network.
Connects to the E2800 controller and operates as the initiator.
E5700SG connectors
| Callout | Port | Type | Use |
1 |
Interconnect ports 1 and 2 |
16Gb/s Fibre Channel (FC), optical SFP |
Connect the E5700SG controller to the E2800 controller. |
2 |
Diagnostic and support ports |
Reserved for technical support. |
3 |
Drive expansion ports |
12Gb/s SAS |
Not used. |
4 |
Network ports 1-4 |
10-GbE or 25-GbE, based on SFP transceiver type, switch speed, and configured link speed |
Connect to the Grid Network and the Client Network for StorageGRID. |
5 |
Management port 1 |
1-Gb (RJ-45) Ethernet |
Connect to the Admin Network for StorageGRID. |
6 |
Management port 2 |
Options:
There are two versions of the E2800 storage controller used in the SG5700 appliances: E2800A and E2800B. The E2800A does not have a HIC, and the E2800B has a four-port HIC. The two controller versions have identical specifications and function except for the location of the interconnect ports.
The E2800 series storage controller has the following specifications:
Operates as the storage controller for the appliance.
Manages the storage of data on the drives.
Functions as a standard E-Series controller in simplex mode.
Includes SANtricity OS Software (controller firmware).
Includes SANtricity System Manager for monitoring appliance hardware and for managing alerts, the AutoSupport feature, and the Drive Security feature.
Connects to the E5700SG controller and operates as the target.
E2800A connectors
E2800B connectors
1 |
16Gb/s FC optical SFP |
Connect the E2800 controller to the E5700SG controller. |
2 |
Management ports 1 and 2 |
Note: some optional SANtricity functionality, such as NTP sync for accurate log timestamps, is not available when you choose to leave Port 1 unwired. Note: StorageGRID 11.5 or greater, and SANtricity 11.70 or greater, are required when you leave Port 1 unwired.
3 |
Reserved for technical support use. |
4 |
Drive expansion ports. |
12Gb/s SAS |
Not used. |
