StorageGRID SG5800 appliances
The SG5800 series StorageGRID appliances are integrated storage and computing platforms that operate as Storage Nodes in a StorageGRID grid.
StorageGRID SG5800 series appliances provide the following features:
Integrate the storage and computing elements for a StorageGRID Storage Node.
Include the StorageGRID Appliance Installer to simplify Storage Node deployment and configuration.
Include E-Series SANtricity System Manager for hardware management and monitoring.
Support up to four 10-GbE or 25-GbE connections to the StorageGRID Grid Network and Client Network.
Support Full Disk Encryption (FDE) drives or FIPS drives. When these drives are used with the Drive Security feature in SANtricity System Manager, unauthorized access to data is prevented.
The SG5800 appliance is available in two models: the SG5812 and the SG5860.
SG5800 components
The SG5800 models include the following components:
- Compute controller
SG5800 controller
- Storage controller
E4000 controller
- Chassis
E-Series DE212C enclosure, a two rack-unit (2U) enclosure
- Drives
12 NL-SAS drives (3.5-inch)
- Redundant power supplies and fans
Two power-fan canisters
SG5800 controller
E4000 controller
- Chassis
E-Series DE460C enclosure, a four rack-unit (4U) enclosure
- Drives
60 NL-SAS drives (3.5-inch)
Two power canisters and two fan canisters
The maximum raw storage available in the StorageGRID appliance is fixed, based on the number of drives in each enclosure. You can't expand the available storage by adding a shelf with additional drives.
SG5800 diagrams
SG5812 front and rear views
The figures show the front and back of the SG5812, a 2U enclosure that holds 12 drives.
SG5812 components
The SG5812 includes two controllers and two power-fan canisters.
| Callout | Description |
1 |
E4000 controller (storage controller) |
2 |
SG5800 controller (compute controller) |
3 |
Power-fan canisters |
SG5860 front and rear views
The figures show the front and back of the SG5860 model, a 4U enclosure that holds 60 drives in 5 drive drawers.
SG5860 components
The SG5860 includes two controllers, two fan canisters, and two power canisters.
1 |
2 |
3 |
Fan canister (1 of 2) |
4 |
Power canister (1 of 2) |
SG5800 controller
Both the 12-drive SG5812 and the 60-drive SG5860 models of the StorageGRID appliance include an SG5800 compute controller and an E-Series E4000 storage controller.
Operates as the compute server for the appliance.
Includes the StorageGRID Appliance Installer.
StorageGRID software is not preinstalled on the appliance. This software is accessed from the Admin Node when you deploy the appliance. -
Can connect to all three StorageGRID networks, including the Grid Network, the Admin Network, and the Client Network.
Connects to the E4000 controller and operates as the initiator.
SG5800 connectors
| Callout | Port | Type | Use |
1 |
Management port 1 |
1-Gb (RJ-45) Ethernet |
Connect to the Admin Network for StorageGRID. |
2 |
Diagnostic and support ports |
Reserved for technical support. |
3 |
Drive expansion ports |
12Gb/s SAS |
Not used. |
4 |
Interconnect ports 1 and 2 |
25GbE iSCSI |
Connect the SG5800 controller to the E4000 controller. |
5 |
Network ports 1-4 |
10-GbE or 25-GbE, based on SFP transceiver type, switch speed, and configured link speed |
Connect to the Grid Network and the Client Network for StorageGRID. |
The E4000 series storage controller has the following specifications:
Operates as the storage controller for the appliance.
Manages the storage of data on the drives.
Functions as a standard E-Series controller in simplex mode.
Includes SANtricity OS Software (controller firmware).
Includes SANtricity System Manager for monitoring appliance hardware and for managing alerts, the AutoSupport feature, and the Drive Security feature.
Connects to the SG5800 controller and operates as the target.
E4000 connectors
1 |
Management port |
Port Options: Connect to a management network to enable direct TCP/IP access to SANtricity System Manager Leave unwired to save a switch port and IP address. Access SANtricity System Manager using the Grid Manager or Storage Grid Appliance Installer. Note: Some optional SANtricity functionality, such as NTP sync for accurate log timestamps, is not available when you choose to leave the management port unwired. Note: StorageGRID 11.8 or greater, and SANtricity 11.8 or greater, are required when you leave the management port unwired. |
2 |
Reserved for technical support use. |
3 |
Drive expansion ports. |
12Gb/s SAS |
Not used. |
4 |
25GbE iSCSI |
Connect the E4000 controller to the SG5800 controller. |
