StorageGRID appliances
Troubleshoot hardware installation for an SG110 and SG1100
Contributors netapp-perveilerk
If you encounter issues during the installation, you might find it helpful to review troubleshooting information related to hardware setup and connectivity issues.
View boot-up codes
When you apply power to the appliance, the BMC logs a series of boot-up codes. You can view these codes on a graphical console that is connected to the BMC management port.
Before you begin
  • You know how to access the BMC dashboard.
  • If you want to use serial-over-LAN (SOL), you have experience using IPMI SOL console applications.
Steps
  1. Select one of the following methods for viewing the boot-up codes for the appliance controller, and gather the required equipment.
    Method Required equipment
    VGA console
    • VGA-capable monitor
    • VGA cable
    KVM
    • RJ-45 cable
    Serial port
    • USB cable
    • Virtual serial terminal
    SOL
  2. If you are using a VGA console, perform these steps:
    1. Connect a VGA-capable monitor to the VGA port on the back of the appliance.
    2. View the codes displayed on the monitor.
  3. If you are using BMC KVM, perform these steps:
    1. Connect to the BMC management port and log in to the BMC web interface.
    2. Select Remote Control.
    3. Launch the KVM.
    4. View the codes on the virtual monitor.
  4. If you are using a serial port and terminal, perform these steps:
    1. Connect to the serial USB port on the back of the appliance.
    2. Use settings 115200 8-N-1.
    3. View the codes printed over the serial terminal.
  5. If you are using SOL, perform these steps:
    1. Connect to the IPMI SOL using the BMC IP address and login credentials.
      ipmitool -I lanplus -H BMC_Port_IP -U admin -P Password sol activate
    2. View the codes on the virtual serial terminal.
  6. Use the table to look up the codes for your appliance.
    Code Indicates
    HT
    The master boot script is waiting for OS boot to complete.
    HI
    The master boot script has started.
    PP
    The system is checking to see if the FPGA needs to be updated.
    HP
    The system is checking to see if the network interface card (NIC) firmware needs to be updated.
    RB
    The system is rebooting after applying firmware updates.
    FP
    The hardware subsystem firmware update checks have been completed. Inter-controller communication services are starting.
    HC
    The system is checking for existing StorageGRID installation data.
    HO
    The StorageGRID appliance is running.
    HA
    StorageGRID is running.
View error codes
If a hardware error occurs when the appliance is booting up, the BMC logs an error code. As required, you can view these error codes using the appliance serial port, and then work with technical support to resolve the issue.
Before you begin
  • Gather the required equipment:
    • USB cable
Steps
  3. Review the information printed over the serial terminal for Current Code and the Previous Code.
    If any of the following error codes are shown, work with technical support to resolve the issue.
    Code Indicates
    0x0E
    Microcode not found
    0x0F
    Microcode not loaded
    0x50
    Memory initialization error. Invalid memory type or incompatible memory speed.
    0x51
    Memory initialization error. SPD reading has failed.
    0x52
    Memory initialization error. Invalid memory size or memory modules don't match.
    0x53
    Memory initialization error. No usable memory detected.
    0x54
    Unspecified memory initialization error
    0x55
    Memory not installed
    0x56
    Invalid CPU type or speed
    0x57
    CPU mismatch
    0x58
    CPU self-test failed, or possible CPU cache error
    0x59
    CPU micro-code is not found, or micro-code update failed
    0x5A
    Internal CPU error
    0x5B
    Reset PPI is not available
    0x5C
    PEI phase BMC self-test failure
    0xD0
    CPU initialization error
    0xD1
    North bridge initialization error
    0xD2
    South bridge initialization error
    0xD3
    Some architectural protocols aren't available
    0xD4
    PCI resource allocation error. Out of resources.
    0xD5
    No space for legacy option ROM
    0xD6
    No console output devices are found
    0xD7
    No console input devices are found
    0xD8
    Invalid password
    0xD9
    Error loading boot option (LoadImage returned error)
    0xDA
    Boot option failed (StartImage returned error)
    0xDB
    Flash update failed
    0xDC
    Reset protocol is not available
    0xDD
    DXE phase BMC self-test failure
    0xE8
    MRC: ERR_NO_MEMORY
    0xE9
    MRC: ERR_LT_LOCK
    0xEA
    MRC: ERR_DDR_INIT
    0xEB
    MRC: ERR_MEM_TEST
    0xEC
    MRC: ERR_VENDOR_SPECIFIC
    0xED
    MRC: ERR_DIMM_COMPAT
    0xEE
    MRC: ERR_MRC_COMPATIBILITY
    0xEF
    MRC: ERR_MRC_STRUCT
    0xF0
    MRC: ERR_SET_VDD
    0xF1
    MRC: ERR_IOT_MEM_BUFFER
    0xF2
    MRC: ERR_RC_INTERNAL
    0xF3
    MRC: ERR_INVALID_REG_ACCESS
    0xF4
    MRC: ERR_SET_MC_FREQ
    0xF5
    MRC: ERR_READ_MC_FREQ
    0x70
    MRC: ERR_DIMM_CHANNEL
    0x74
    MRC: ERR_BIST_CHECK
    0xF6
    MRC: ERR_SMBUS
    0xF7
    MRC: ERR_PCU
    0xF8
    MRC: ERR_NGN
    0xF9
    MRC: ERR_INTERLEAVE_FAILURE
Hardware setup appears to hang
The StorageGRID Appliance Installer might not be available if hardware faults or cabling errors prevent the appliance from completing its boot-up processing.
Steps
  1. Review the LEDs on the appliance and the boot-up and error codes displayed in the BMC.
  2. If you need help resolving an issue, contact technical support.
Connection issues
If you can't connect to the services appliance, there might be a network issue, or the hardware installation might not have been completed successfully.
Steps
  1. Try to ping the appliance using the IP address for the appliance :
    ping appliance_IP
  2. If you receive no response from the ping, confirm you are using the correct IP address.
    You can use the IP address of the appliance on the Grid Network, the Admin Network, or the Client Network.
  3. If the IP address is correct, check appliance cabling, QSFP or SFP transceivers, and the network setup.
  4. If physical access to the appliance is available, you can use a direct connection to the permanent link-local IP 169.254.0.1 to check controller networking configuration and update if necessary. For detailed instructions, see step 2 in Access StorageGRID Appliance Installer.
    If that does not resolve the issue, contact technical support.
  5. If the ping was successful, open a web browser.
  6. Enter the URL for the StorageGRID Appliance Installer:
    https://appliances_controller_IP:8443
    The Home page appears.
