StorageGRID appliances
Relocate SG120 and SG1200 in cabinet or rack
Contributors netapp-ivanad
Remove the SG120 or SG1200 from a cabinet or rack to access the top cover or to move the appliance to a different location, then reinstall the appliance into a cabinet or rack when hardware maintenance is complete.
Before you begin
Step 1: Remove SG120 or SG1200 from cabinet or rack
Steps
  1. Label and then disconnect the appliance power cables.
  2. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  3. Label and then disconnect the appliance data cables and any SFP+, SFP28, or SFP56 transceivers.
    Important To prevent degraded performance, don't twist, fold, pinch, or step on the cables.
  4. Loosen the two captive screws on the appliance front panel.
    SG120 or SG1200 rack retaining screws
  5. Slide the SG120 or SG1200 forward out of the rack until the mounting rails are fully extended and you hear the latches on both sides click.
    The appliance top cover is accessible.
    Note If you are fully removing the appliance from the cabinet or rack, follow the instructions for the rail kit to remove the appliance from the rails.
Step 2: Reinstall SG120 or SG1200 into cabinet or rack
Steps
  1. Press the blue rail releases on both rack rails at the same time and slide the SG120 or SG1200 into the rack until it is fully seated.
    When you can't move the controller any further, pull the blue latches on both sides of the chassis to slide the controller all the way in.
    SG120 or SG1200 sliding on rails
    Note Don't attach the front bezel until after you power on the controller.
  2. Tighten the captive screws on the controller front panel to secure the controller in the rack.
  3. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  4. Reconnect the controller data cables and any SFP transceivers.
  5. Reconnect the controller power cables.
  6. Restart the appliance.
