StorageGRID appliances
Power SG120 or SG1200 off and on
Contributors netapp-ivanad
You can shut down the SG120 or SG1200 appliance and power it back on to perform maintenance.
Shut down the SG120 or SG1200 appliance
Shut down the appliance to perform hardware maintenance.
About this task
To prevent service interruptions, shut down the appliance during a scheduled maintenance window when periods of service disruption are acceptable.
Before you begin
You have physically located the appliance.
Steps
  1. Shut down the appliance:
    Caution You must perform a controlled shut down of the appliance by entering the commands specified below. It is a best practice to perform a controlled shutdown when possible to avoid unnecessary alerts, ensure full logs are available, and avoid service disruptions.
    1. If you have not already logged into the grid node, log in using PuTTY or another ssh client:
      1. Enter the following command: ssh admin@grid_node_IP
      2. Enter the password listed in the Passwords.txt file.
      3. Enter the following command to switch to root: su -
      4. Enter the password listed in the Passwords.txt file.
        When you are logged in as root, the prompt changes from $ to #.
    2. Shut down the appliance:
      shutdown -h now
      This command might take up to 10 minutes to complete.
  2. Use one of the following methods to verify that the appliance is powered off:
    • Look at the power LED on the front of the appliance and confirm that it is off.
    • Check the Power Control page of the BMC interface to confirm the appliance is off.
Power on SG120 or SG1200 and verify operation
Power on the controller after completing maintenance.
Before you begin
Steps
  1. Power on the appliance.
    You might have to remove the bezel to access the power switch; if so, remember to reinstall it afterwards.
  2. Monitor the controller LEDs and boot-up codes using one of the following methods:
    • Press the power switch on the front of the controller.
    • Use the controller BMC interface:
      1. Access the controller BMC interface.
      2. Select Power Control.
      3. Select Power On and then select Perform Action.
        Power on appliance from BMC
        Use the BMC interface to monitor start-up status.
  3. Confirm that the appliance controller displays in the Grid Manager and with no alerts.
    It might take up to 20 minutes for the controller to display in the Grid Manager.
    Caution Don't take another appliance node offline unless this appliance has a green icon.
  4. Confirm that the new appliance is fully operational by logging in to the grid node using PuTTY or another ssh client:
    1. Enter the following command: ssh Appliance_IP
Related information
View status indicators
