StorageGRID appliances
SG5800 drive replacement requirements
Contributors netapp-ivanad
Before you replace a drive in an SG5812 or SG5860, review the requirements and considerations.
Drive handling
The drives in your appliance are fragile. Improper drive handling is a leading cause of drive failure.
Follow these rules to avoid damaging the drives in your storage array:
  • Prevent electrostatic discharge (ESD):
    • Keep the drive in the ESD bag until you are ready to install it.
    • Do not insert a metal tool or knife into the ESD bag.
      Open the ESD bag by hand or cut the top off with a pair of scissors.
    • Keep the ESD bag and any packing materials in case you must return a drive later.
    • Always wear an ESD wrist strap grounded to an unpainted surface on your storage enclosure chassis.
      If a wrist strap is unavailable, touch an unpainted surface on your storage enclosure chassis before handling the drive.
  • Handle drives carefully:
    • Always use two hands when removing, installing, or carrying a drive.
    • Never force a drive into a shelf, and use gentle, firm pressure to completely engage the drive latch.
    • Place drives on cushioned surfaces, and never stack drives on top of each other.
    • Do not bump drives against other surfaces.
    • Before removing a drive from a shelf, unlatch the handle and wait 30 seconds for the drive to spin down.
    • Always use approved packaging when shipping drives.
  • Avoid magnetic fields:
    • Keep drives away from magnetic devices.
      Magnetic fields can destroy all data on the drive and cause irreparable damage to the drive circuitry.
