StorageGRID appliances
Upgrade SANtricity OS on E4000 controller using maintenance mode (SG6160)
Contributors netapp-perveilerk netapp-ivanad
You can use maintenance mode to upgrade SANtricity OS on the E4000 controller.
Note For storage controllers currently using SANtricity OS newer than 08.42.20.00 (11.42), it is recommended to use Grid Manager to apply an upgrade. However, you may use the maintenance mode procedure if you prefer it or have been instructed to do so by technical support.
Before you begin
  • You have consulted the NetApp Interoperability Matrix Tool (IMT) to confirm that the SANtricity OS version you are using for the upgrade is compatible with your appliance.
  • You must place the SG5800 controller into maintenance mode, which interrupts the connection to the E4000 controller.
    Note In rare instances, placing a StorageGRID appliance into maintenance mode might make the appliance unavailable for remote access.
About this task
Don't upgrade the SANtricity OS or NVSRAM in the E-Series controller on more than one StorageGRID appliance at a time.
Caution Upgrading more than one StorageGRID appliance at a time might cause data unavailability, depending on your deployment model and ILM policies.
Steps
  1. Confirm the appliance is in maintenance mode.
  2. From a service laptop, access SANtricity System Manager and sign in.
  3. Download the new SANtricity OS Software file and NVSRAM file to the management client.
    Caution The NVSRAM is specific to the StorageGRID appliance. Don't use the standard NVSRAM download.
  4. Follow the instructions in the E4000 and E5800 SANtricity Software and Firmware Upgrade Guide or the SANtricity System Manager online help to upgrade the E4000 controller's firmware and NVSRAM.
    Note Activate the upgrade files immediately. Don't defer activation.
  5. If this procedure completed successfully and you have additional procedures to perform while the node is in maintenance mode, perform them now. When you are done, or if you experienced any failures and want to start over, select Advanced > Reboot Controller, and then select one of these options:
    • Select Reboot into StorageGRID
    • Select Reboot into Maintenance Mode to reboot the controller with the node remaining in maintenance mode. Select this option if you experienced any failures during the procedure and want to start over. After the node finishes rebooting into maintenance mode, restart from the appropriate step in the procedure that failed.
      It can take up to 20 minutes for the appliance to reboot and rejoin the grid. To confirm that the reboot is complete and that the node has rejoined the grid:
      1. In the Grid Manager, select NODES.
      2. Verify that the appliance node has a normal status (green check mark icon green check mark to the left of the node name), which indicates that no alerts are active and the node is connected to the grid.
