StorageGRID appliances
Replace drive in SG6200-CN
Contributors netapp-ivanad
The SG6260 appliance contains two SSD drives in the SG6200-CN controller which function as a read cache. If one of these drives fails, you must replace it as soon as possible to minimize the potential performance impact.
Before you begin
Steps
  1. Verify that the drive's left fault LED is amber or use the drive slot ID from the alert to locate the drive.
    The drives are in the following positions in the chassis (front of chassis with bezel removed shown).
    SSD location in SG6260
  2. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  3. Unpack the replacement drive, and set it on a static-free, level surface near the appliance.
    Save all packing materials.
  4. Press the release button on the failed drive.
    Removing a drive from the chassis
    The handle on the drive springs open partially, and the drive releases from the slot.
  5. Open the handle, slide the drive out, and place it on a static-free, level surface.
  6. Press the release button on the replacement drive before you insert it into the drive slot.
    The latch springs open.
  7. Insert the replacement drive in the slot, and then close the drive handle.
    Caution Don't use excessive force while closing the handle.
    When the drive is fully inserted, you hear a click.
    When both SSD drives are functioning normally, the system will automatically restore read-cache functionality. You can run diagnostics to monitor the read-cache hit rate. Since the cache was just rebuilt, the hit rate might be low initially but should increase over time as the cache is repopulated by clients accessing object data.
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Parts Return & Replacements page for further information.
