Test and demonstrate S3 encryption options on StorageGRID
By Aron Klein
StorageGRID and the S3 API offer a number of different ways to encrypt your data at rest. To learn more, see Review StorageGRID encryption methods.
This guide will demonstrate the S3 API encryption methods.
Server Side Encryption (SSE)
SSE allows the client to store an object and encrypt it with a unique key that is managed by StorageGRID. When the object is requested, the object is decrypted by the key stored in storageGRID.
SSE Example
PUT an object with SSE
aws s3api put-object --bucket <bucket> --key <file> --body "<file>" --server-side-encryption AES256 --endpoint-url https://s3.example.com -
HEAD the object to verify encryption
aws s3api head-object --bucket <bucket> --key <file> --endpoint-url https://s3.example.com{ "AcceptRanges": "bytes", "LastModified": "2022-05-02T19:03:03+00:00", "ContentLength": 47, "ETag": "\"82e8bfb872e778a4687a26e6c0b36bc1\"", "ContentType": "text/plain", "ServerSideEncryption": "AES256", "Metadata": {} } -
GET the object
aws s3api get-object --bucket <bucket> --key <file> <file> --endpoint-url https://s3.example.com
Server Side Encryption with Customer provided keys (SSE-C)
SSE allows the client to store an object and encrypt it with a unique key that is provided by the client with the object. When the object is requested, the same key must be provided in order to decrypt and return the object.
SSE-C Example
For testing or demonstration purposes you can create an encryption key
Create an encryption key
openssl enc -aes-128-cbc -pass pass:secret -P`salt=E9DBB6603C7B3D2A key=23832BAC16516152E560F933F261BF03 iv =71E87C0F6EC3C45921C2754BA131A315
Put an object with the generated key
aws s3api put-object --bucket <bucket> --key <file> --body "file" --sse-customer-algorithm AES256 --sse-customer-key 23832BAC16516152E560F933F261BF03 --endpoint-url https://s3.example.com -
Head the object
aws s3api head-object --bucket <bucket> --key <file> --sse-customer-algorithm AES256 --sse-customer-key 23832BAC16516152E560F933F261BF03 --endpoint-url https://s3.example.com{ "AcceptRanges": "bytes", "LastModified": "2022-05-02T19:20:02+00:00", "ContentLength": 47, "ETag": "\"f92ef20ab87e0e13951d9bee862e9f9a\"", "ContentType": "binary/octet-stream", "Metadata": {}, "SSECustomerAlgorithm": "AES256", "SSECustomerKeyMD5": "rjGuMdjLpPV1eRuotNaPMQ==" }
If you do not provide the encryption key, you will receive an error "An error occurred (404) when calling the HeadObject operation: Not Found" |
Get the object
aws s3api get-object --bucket <bucket> --key <file> <file> --sse-customer-algorithm AES256 --sse-customer-key 23832BAC16516152E560F933F261BF03 --endpoint-url https://s3.example.com
If you do not provide the encryption key, you will receive an error "An error occurred (InvalidRequest) when calling the GetObject operation: The object was stored using a form of Server Side Encryption. The correct parameters must be provided to retrieve the object." |
Bucket Server Side Encryption (SSE-S3)
SSE-S3 allows the client to define a default encryption behavior for all objects stored in a bucket. The objects are encrypted with a unique key that is managed by StorageGRID. When the object is requested, the object is decrypted by they key stored in storageGRID.
Bucket SSE-S3 Example
Create a new bucket and set a default encryption policy
Create new bucket
aws s3api create-bucket --bucket <bucket> --region us-east-1 --endpoint-url https://s3.example.com -
Put bucket encryption
aws s3api put-bucket-encryption --bucket <bucket> --server-side-encryption-configuration '{"Rules": [{"ApplyServerSideEncryptionByDefault": {"SSEAlgorithm": "AES256"}}]}' --endpoint-url https://s3.example.com
Put an object in the bucket
aws s3api put-object --bucket <bucket> --key <file> --body "file" --endpoint-url https://s3.example.com -
Head the object
aws s3api head-object --bucket <bucket> --key <file> --endpoint-url https://s3.example.com{ "AcceptRanges": "bytes", "LastModified": "2022-05-02T20:16:23+00:00", "ContentLength": 47, "ETag": "\"82e8bfb872e778a4687a26e6c0b36bc1\"", "ContentType": "binary/octet-stream", "ServerSideEncryption": "AES256", "Metadata": {} } -
GET the object
