Node Clone
Node clone considerations and performance.
Node clone can be a faster method for replacing existing appliance nodes for a tech refresh, increase capacity, or increase performance of your StorageGRID system. Node clone can also be useful for converting to node encryption with a KMS, or changing a storage node from DDP8 to DDP16.
The used capacity of the source node is not relevant to the time required for the clone process to complete. Node clone is a full copy of the node including free space in the node.
The source and destination appliances must be at the same PGE version
The destination node must always have larger capacity than the source
Make sure the new destination appliance has a larger drive size than the source
If the destination appliance has the same size drives and is configured for DDP8, you can configure the destination for DDP16. If the source is already configured for DDP16 then node clone will not be possible.
When going from SG5660 or SG5760 appliances to SG6060 appliances be aware that the SG5x60's have 60 capacity drives where the SG6060 only has 58.
The node clone process requires the source node to be offline to the grid for the duration of the cloning process. If an additional node goes offline during this time client services may be impacted.
11.8 and bellow: A storage node can only be offline for 15 days. If the cloning process estimate is close to 15 days or will exceed 15 days, use the expansion and decommission procedures.
11.9: The 15 day limit has been removed.
For a SG6060 or SG6160 with expansion shelves, you need to add the time for the correct shelf drive size to the time of the base appliance time to get the full clone duration.
The number of volumes in a target storage appliance must be greater than or equal to the number of volumes in the source node. You cannot clone a source node with 16 object store volumes (rangedb) to a target storage appliance with 12 object store volumes even if the target appliance has larger capacity than the source node. Most storage appliances have 16 object store volumes, except the SGF6112 storage appliance that has only 12 object store volumes. For example, you cannot clone from a SG5760 to a SGF6112.
Node clone Performance estimates
The following tables contain calculated estimates for node clone duration. Conditions vary so, entries in BOLD may risk exceeding the 15 day limit for a node down.
DDP8
SG5612/SG5712/SG5812 → Any
| Network Interface speed | 4TB Drive size | 8TB Drive size | 10TB Drive size | 12TB Drive size | 16TB Drive size | 18TB Drive size | 22TB Drive size |
10GB |
1 Day |
2 Days |
2.5 Days |
3 Days |
4 Days |
4.5 Days |
5.5 Days |
25GB |
1 Day |
2 Days |
2.5 Days |
3 Days |
4 Days |
4.5 Days |
5.5 Days |
SG5660 → SG5760/SG5860
10GB |
3.5 Day |
7 Days |
8.5 Days |
10.5 Days |
13.5 Days |
15.5 Days |
18.5 Days |
25GB |
3.5 Day |
7 Days |
8.5 Days |
10.5 Days |
13.5 Days |
15.5 Days |
18.5 Days |
SG5660 → SG6060/SG6160
10GB |
2.5 Day |
4.5 Days |
5.5 Days |
6.5 Days |
9 Days |
10 Days |
12 Days |
25GB |
2 Day |
4 Days |
5 Days |
6 Days |
8 Days |
9 Days |
10 Days |
SG5760/SG5860 → SG5760/SG5860
10GB |
3.5 Day |
7 Days |
8.5 Days |
10.5 Days |
13.5 Days |
15.5 Days |
18.5 Days |
25GB |
3.5 Day |
7 Days |
8.5 Days |
10.5 Days |
13.5 Days |
15.5 Days |
18.5 Days |
SG5760/SG5860 → SG6060/SG6160
10GB |
2.5 Day |
4.5 Days |
5.5 Days |
6.5 Days |
9 Days |
10 Days |
12 Days |
25GB |
2 Day |
3.5 Days |
4.5 Days |
5.5 Days |
7 Days |
8 Days |
9.5 Days |
SG6060/SG6160 → SG6060/SG6160
10GB |
2.5 Day |
4.5 Days |
5.5 Days |
6.5 Days |
8.5 Days |
9.5 Days |
11.5 Days |
25GB |
2 Day |
3 Days |
4 Days |
4.5 Days |
6 Days |
7 Days |
8.5 Days |
DDP16
10GB |
3.5 Day |
6.5 Days |
8 Days |
9.5 Days |
12.5 Days |
14 Days |
17 Days |
25GB |
3.5 Day |
6.5 Days |
8 Days |
9.5 Days |
12.5 Days |
14 Days |
17 Days |
10GB |
2.5 Day |
5 Days |
6 Days |
7.5 Days |
10 Days |
11 Days |
13 Days |
25GB |
2 Day |
3.5 Days |
4 Days |
5 Days |
6.5 Days |
7 Days |
8.5 Days |
10GB |
3 Day |
5 Days |
6 Days |
7 Days |
9.5 Days |
10.5 Days |
13 Days |
25GB |
2 Day |
3.5 Days |
4.5 Days |
5 Days |
7 Days |
7.5 Days |
9 Days |
Expansion shelf (add to above SG6060/SG6160 for each shelf on source appliance)
10GB |
3.5 Day |
5 Days |
6 Days |
7 Days |
9.5 Days |
10.5 Days |
12 Days |
25GB |
2 Day |
3 Days |
4 Days |
4.5 Days |
6 Days |
7 Days |
8.5 Days |
By Aron Klein
