Create Okta application for OIDC in StorageGRID
Contributors netapp-pcarriga
Create an Okta application for all Admin Nodes for OpenID Connect (OIDC) in your StorageGRID system.
Before you begin
  • You have experience creating Okta applications, or you have access to the Okta documentation.
  • You have Okta Administrator access.
About this task
An Okta application must contain sign-in and sign-out redirect URIs for all Admin Nodes. Redirect URIs ensure that users can securely sign in to and out of any Admin Node. You can create a single Okta application for all Admin Nodes (recommended) or a different application for each Admin Node.
Use the default settings unless otherwise specified. In some cases you can use settings required by your organization.
Step 1: Create an Okta application
Create an Okta application using the Okta UI.
Steps
  1. In Okta, go to Applications > Applications.
  2. Select Create App Integration, then enter the following information:
    • Sign-in method: OIDC - OpenID Connect
    • Application type: Web Application
  3. Select Next.
  4. Enter a name for the application in the App Integration field.
  5. Verify that Authorization Code is selected (default) for Core grants.
  6. Add the sign-in and sign-out redirect URIs for each Admin Node:
    • Sign-in redirect URI: https://<Admin_IP_address_or_FQDN>/api/v4/oidc-callback
    • Sign-out redirect URI: https://<Admin_IP_address_or_FQDN>/api/v4/oidc-logged-out
      Note If one or more load balancer endpoints are configured for the management interface, add the redirect URIs for each port. For example: https://<Admin_IP_address_or_FQDN>:<port>/api/v4/oidc-callback and https://<Admin_IP_address_or_FQDN>:<port>/api/v4/oidc-logged-out
  7. Select Save. Save the client ID and client secret values for use later.
Step 2: Add a federate group
Create a group or use an existing group from the Active Directory Federation Service (AD FS) server for StorageGRID.
Steps
  1. In GRID Manager, select Configuration > Admin groups > Create group > Federate Group.
  2. Enter the AD FS server group name.
  3. Select Read-write for access mode and Root access for permissions.
  4. Select Create group.
Step 3: Import AD FS server groups and users
Install the Okta Active Directory client in the AD FS Server. Then, import the AD FS server groups and users.
Steps
  1. In Okta, go to Directory > Directory Integrations > Add Directory > Add Active Directory.
  2. Select Set Up Active Directory > Download Agent.
  3. Immediately follow the setup process.
    Note If you delay, the setup might stall and you will need to start over.
    1. Select the Active Directory domain.
    2. Create an OktaService account instead of linking an existing user.
    3. Select the organizational units that contain the users and the organizational units that contain the groups.
    4. Select the User Principal Name (UPN) that uses the AD UPN as the Okta username. For example: user@domain.com
  4. Search for the Okta AD Agent Management Utility application. Then, run the application and confirm that the status message The agent is running appears.
    Note The Okta AD client must be running whenever you want to execute an AD FS server sync and import with Okta.
  5. In Okta, go to Directory > Directory Integrations.
  6. Select the directory integration that you created.
  7. Select Import > Import Now.
  8. Select the user that you want to import, then select Confirm Assignments.
  9. Go to Directory > People and confirm that the user was imported successfully.
    If the user status isn't Active, select Activate and keep refreshing the page until the user has the Active status.
  10. Go to Directory > Groups and confirm that the group for the imported user was automatically imported.
  11. Select the group and verify that the imported user is part of this group.
Step 4: Set up a claim
Set up a claim to include AD FS server groups in the access token. Then, verify that the claim includes the imported group for the imported user and Okta application.
Steps
  1. In Okta, go to Directory > Groups.
  2. Select the imported group for the imported user.
  3. Select Applications > Assign applications > Assign.
  4. Go to Security > API.
  5. Select the default authorization server.
  6. Select Claims > Add Claim. Then, create a claim with the following credentials:
    • Name: groups
    • Include in token type: ID Token - Always
    • Value type: Expression
    • Value: Groups.startsWith("active_directory","",100)
    • Include in: Any scope
  7. Go to Security > API.
  8. Select the default authorization server.
  9. Select the Token Preview tab and enter the following credentials for Request Properties:
    • OAuth/OIDC client: <application name>
    • Grant type: Authorization Code
    • User: Imported user (e-mail address)
    • Scopes: email, profile, openid
  10. Select Execute.
    The imported group appears in the Preview id_token tab in the Payload.
What's next
After creating an Okta application, configure SSO using OIDC.
