Automate grid federation connections in StorageGRID
Contributors netapp-lhalbert netapp-pcarriga
After you've installed and configured two or more StorageGRID systems running version 12.1 or later, you can automate the creation, editing, and maintenance of grid federation connections using the manage-grid-federation.py Python script and a JSON configuration file.
Before you begin
  • All grids are running StorageGRID 12.1 or later.
  • If single sign-on (SSO) is enabled on any grid, you've disabled it.
  • You have a Linux machine with Python 3.6 or later installed.
  • You know the location of the following files from the installation archive:
    Filename Description
    Python script used to automate grid federation connection management
    manage-grid-federation.sample.json
    Example configuration file for use with the script
  • You've created a manage-grid-federation.json configuration file. To create this file, you can modify the example configuration file, manage-grid-federation.sample.json.
Caution Store the grid admin passwords and provisioning passphrases from your manage-grid-federation.json configuration file in a secure location. If credentials are omitted from the file, the script will prompt for them interactively. You should also store a backup of the modified configuration file in a secure location.
Configuration file fields
The JSON configuration file is an array of objects. Each object represents one grid and supports the following fields:
Field Required Description
hostname
Yes
Admin Node hostname or IP address for the grid
grid_name
Yes
Display name for the grid (12 characters maximum)
username
No
Grid admin username (prompted interactively if omitted)
password
No
Grid admin password (prompted interactively if omitted)
passphrase
No
Provisioning passphrase (prompted interactively if omitted)
ca_bundle
No
Path to a custom CA certificate bundle for SSL verification
region
No
Desired default S3 region for global namespace connections
CNAME
No
Desired CNAME for global namespace connections
globalEndpoint
No
Desired global namespace endpoint
Note If you configure any of the global namespace fields (region, CNAME, globalEndpoint), you must provide all three for each grid. Ensure the regions and CNAMEs are unique across grids, and the globalEndpoint value is identical for all grids.
About this task
You can use the manage-grid-federation.py Python script and the manage-grid-federation.json configuration file to automate grid federation connection management. The script performs the following operations:
  • Authenticates to each grid using the Grid Management API
  • Verifies that all grids are running StorageGRID 12.1 or later
  • Verifies that Single Sign-On is disabled on every grid
  • Retrieves existing grid federation connections and S3 configuration
  • Updates S3 region, CNAME, and global namespace endpoint settings when configured
  • Creates new grid federation connections for any grid pairs that are not yet connected
  • Edits existing connections when display names or global namespace settings have changed
  • Displays a summary of all connections and their status
Tip You can also manage grid federation connections using the Grid Manager UI or the Grid Management API directly.
Steps
  1. Log in to the Linux machine you are using to run the Python script.
  2. Change to the directory containing the script.
    For example:
    cd StorageGRID-Webscale-version/platform
    where platform is debs, rpms, or vsphere.
  3. Run the Python script and use the configuration file you created.
    For example:
    ./manage-grid-federation.py -i manage-grid-federation.json
    You can use the following command-line options:
    Option Default Description
    -i, --input-json-file
    (required)
    Path to the JSON configuration file containing the list of grids
    -b, --base-port
    23001
    Starting port number for new grid federation connections
    --no-verify-ssl
    SSL verification enabled
    Disables SSL certificate verification for local-to-grid connections
Edit existing connections
If the script detects that existing connections require changes — for example, because grid display names changed or global namespace settings need to be updated — it will display a summary of the proposed edits and prompt for confirmation before proceeding.
When S3 configuration updates (region, CNAME, or globalEndpoint) are required on grids that have global namespace enabled, the script must temporarily disable global namespace to apply the changes. In this case, the confirmation prompt will warn about the temporary routing outage:
*** Global Namespace Disable Required ***
Global Namespace must be disabled to update region/CNAME/globalEndpoint settings.
Routing requests will not work until Global Namespace is re-enabled.
Grids requiring S3 updates: grid1.example.com, grid2.example.com
Proceed with these edits and the temporary routing outage? [y/N]:
Caution While global namespace is temporarily disabled during S3 configuration updates, global namespace routing requests won't function. Plan this operation during a maintenance window.
After you finish
Your grid federation connections are established and configured when the script displays a confirmation summary similar to the following:
===== Newly Established Connections =====
 • Grid-A and Grid-B — grid-a.example.com and grid-b.example.com on port 23001
Total new connections: 1
===== All Grid-Federation Connections =====
  Name              Source                Target                Port   Status    Global Namespace
  Grid-A and Grid-B grid-a.example.com    grid-b.example.com    23001  new       enabled
Total connections listed: 1
===== Grid S3 Configuration Summary =====
 grid-a.example.com:
    Default Region: us-east-1
    CNAME: s3-a.example.com
    Global namespace endpoint: gn.example.com
 grid-b.example.com:
    Default Region: us-west-1
    CNAME: s3-b.example.com
Exit status
Code Description
0
Script completed successfully
1
Validation failed or a grid API call returned an error (check the log output)
Note If any connections fail, the script continues processing remaining pairs and reports all failures in the Failed Connections section of the output. Review the error messages and resolve any issues before re-running the script.
