Request approval for MAV-protected operations in StorageGRID
Contributors netapp-lhalbert
As a StorageGRID administrator or user, when you initiate a MAV-protected operation in StorageGRID, a request is generated automatically. A message appears to inform you that the operation requires approval.
The StorageGRID system defines which operations are protected by MAV. When you initiate a MAV-protected operation, the request is sent to the MAV administrators for approval.
Steps
The StorageGRID system informs you that you've initiated a MAV-protected operation.
  1. As needed, perform any of the following tasks:
    1. Check the status of your request by selecting Configuration > Access control > Multi-admin verification > My requests.
      • Pending. Request has been initiated.
      • Expired. Request wasn't addressed within 30 days. Or a user with Root access permission disabled MAV, which means all pending requests are expired.
      • Withdrawn. A user withdrew their request.
      • Approved. A MAV administrator approved the pending request.
      • Rejected. A MAV administrator rejected the pending request.
    2. Check the pending requests of other users by selecting Configuration > Access control > Multi-admin verification > Other requests.
    3. To cancel an operation, select My requests > the request you want to cancel > Withdraw.
After a MAV administrator approves the request, the operation is performed automatically.
If your request is rejected, the operation isn't performed, and you can submit a new request if needed.
