Recover from StorageGRID primary Admin Node failures using a non-primary Admin Node
You must complete a specific set of tasks to recover from a primary Admin Node failure using a non-primary Admin Node. The primary Admin Node hosts the Configuration Management Node (CMN) service for the grid.
Follow these high-level steps to recover a primary Admin Node using a non-primary Admin Node:
