Configure log management in StorageGRID
Contributors netapp-pcarriga netapp-lhalbert netapp-perveilerk
As needed, configure audit levels, protocol headers, the location of audit messages and logs, and log retention.
All StorageGRID nodes generate audit messages and logs to track system activity and events. Audit messages and logs are essential tools for monitoring and troubleshooting.
Optionally, you can configure an external syslog server to save audit information remotely. You can minimize the performance impact of audit message logging without reducing the completeness of audit data by using an external server. An external syslog server is especially useful if you have a large grid, use multiple types of S3 applications, or want to retain all audit data.
Before you begin
Change audit message levels
You can set a different audit level for each of the following categories of messages in the audit log:
Audit category Default setting More information
System
Normal
Storage
Management
Normal
Client reads
Normal
Client writes
Normal
ILM
Normal
Cross-grid replication
Note During upgrades, audit level configurations won't be effective immediately.
Steps
  1. Select Configuration > Monitoring > Log management.
  2. For each category of audit message, select an audit level from the drop-down list:
    Audit level Description
    Off
    No audit messages from the category are logged.
    Only error messages are logged—​audit messages for which the result code wasn't "successful" (SUCS).
    Normal
    Standard transactional messages are logged—​the messages listed in these instructions for the category.
    Debug
    Deprecated. This level behaves the same as the Normal audit level.
    The messages included for any particular level include those that would be logged at the higher levels. For example, the Normal level includes all of the Error messages.
    Note If you don't need a detailed record of client read operations for your S3 applications, optionally change the Client Reads setting to Error to decrease the number of audit messages recorded in the audit log.
  3. Select Save.
Define HTTP request headers
You can optionally define any HTTP request headers you want to include in client read and write audit messages.
Steps
  1. In the Audit protocol headers section, define the HTTP request headers you want to include in client read and write audit messages.
    Use an asterisk (*) as a wildcard to match zero or more characters. Use the escape sequence (\*) to match a literal asterisk.
  2. Select Add another header to create additional headers, if needed.
    When StorageGRID finds HTTP headers in a request, it includes them in the audit message under the field HTRH.
    Note Audit protocol request headers are logged only if the audit level for Client Reads or Client Writes isn't Off.
  3. Select Save
Configure log location
By default, audit messages and logs are saved on the nodes where they're generated. StorageGRID regularly rotates and eventually deletes audit messages and logs to prevent them from consuming excessive disk space. To save audit messages and a subset of logs externally, use an external syslog server.
If you want to save the log files internally, choose a tenant and bucket for log storage and enable log archival.
Use an external syslog server
You can optionally configure an external syslog server to save audit logs, application logs, and security event logs to a location outside of your grid.
Note If you don't want to use an external syslog server, skip this step and go to Select log location.
Tip If the configuration options available in this procedure aren't flexible enough to meet your requirements, additional configuration options can be applied using the audit-destinations endpoints, which are in the private API section of the Grid Management API. For example, you can use the API if you want to use different syslog servers for different groups of nodes.
Enter syslog information
Access the Configure external syslog server wizard and provide the information StorageGRID needs to access the external syslog server.
Steps
  1. From the Local node and external server tab, select Configure external syslog server. Or, if you have previously configured an external syslog server, select Edit external syslog server.
    The Configure external syslog server wizard appears.
  2. For the Enter syslog info step of the wizard, enter a valid fully qualified domain name or an IPv4 or IPv6 address for the external syslog server in the Host field.
  3. Enter the destination port on the external syslog server (must be an integer between 1 and 65535). The default port is 514.
  4. Select the protocol used to send audit information to the external syslog server.
    Using TLS or RELP/TLS is recommended. You must upload a server certificate to use either of these options. Using certificates helps secure the connections between your grid and the external syslog server. For more information, see Manage security certificates.
    All protocol options require support by, and configuration of, the external syslog server. You must choose an option that is compatible with the external syslog server.
    Note Reliable Event Logging Protocol (RELP) extends the functionality of the syslog protocol to provide reliable delivery of event messages. Using RELP can help prevent the loss of audit information if your external syslog server has to restart.
  5. Select Continue.
  6. If you selected TLS or RELP/TLS, upload the server CA certificates, client certificate, and client private key.
    1. Select Browse for the certificate or key you want to use.
    2. Select the certificate or key file.
    3. Select Open to upload the file.
      A green check appears next to the certificate or key file name, notifying you that it has been uploaded successfully.
  7. Select Continue.
Manage syslog content
You can select which information to send to the external syslog server.
Steps
  1. For the Manage syslog content step of the wizard, select each type of audit information you want to send to the external syslog server.
    • Send audit logs: Sends StorageGRID events and system activities
    • Send security events: Sends security events such as when an unauthorized user attempts to sign in or a user signs in as root
    • Send application logs: Sends StorageGRID software log files useful for troubleshooting, including:
      • bycast-err.log
      • bycast.log
      • jaeger.log
      • nms.log (Admin Nodes only)
      • prometheus.log
      • raft.log
      • hagroups.log
    • Send access logs: Sends HTTP access logs for external requests to Grid Manager, Tenant Manger, configured load balancer endpoints, and grid federation requests from remote systems.
  2. Use the drop-down menus to select the severity and facility (type of message) for each category of audit information you want to send.
    Setting severity and facility values can help you aggregate the logs in customizable ways for easier analysis.
    1. For Severity, select Passthrough, or select a severity value between 0 and 7.
      If you select a value, StorageGRID applies the selected value to all messages of this type. You lose details about different severities if you override severity with a fixed value.
      Severity Description
      Passthrough
      Each message sent to the external syslog to have the same severity value as when it was logged locally onto the node:
      • For audit logs, the severity is "info."
      • For security events, the severity values are generated by the Linux distribution on the nodes.
      • For application logs, the severities vary between "info" and "notice," depending on what the issue is. For example, adding an NTP server and configuring an HA group gives a value of "info," while intentionally stopping the SSM or RSM service gives a value of "notice."
      • For access logs, the severity is "info."
      0
      Emergency: System is unusable
      1
      Alert: Action must be taken immediately
      2
      Critical: Critical conditions
      3
      Error: Error conditions
      4
      Warning: Warning conditions
      5
      Notice: Normal but significant condition
      6
      Informational: Informational messages
      7
      Debug: Debug-level messages
    2. For Facilty, select Passthrough, or select a facility value between 0 and 23.
      If you select a value, it will be applied to all messages of this type. Information about different facilities will be lost if you override facility with a fixed value.
      Facility Description
      Passthrough
      Each message sent to the external syslog to have the same facility value as when it was logged locally onto the node:
      • For audit logs, the facility sent to the external syslog server is "local7."
      • For security events, the facility values are generated by the linux distribution on the nodes.
      • For application logs, the application logs sent to the external syslog server have the following facility values:
        • bycast.log: user or daemon
        • bycast-err.log: user, daemon, local3, or local4
        • jaeger.log: local2
        • nms.log: local3
        • prometheus.log: local4
        • raft.log: local5
        • hagroups.log: local6
      • For access logs, the facility sent to the external syslog server is "local0."
      0
      kern (kernel messages)
      1
      user (user-level messages)
      2
      mail
      3
      daemon (system daemons)
      4
      auth (security/authorization messages)
      5
      syslog (messages generated internally by syslogd)
      6
      lpr (line printer subsystem)
      7
      news (network news subsystem)
      8
      UUCP
      9
      cron (clock daemon)
      10
      security (security/authorization messages)
      11
      FTP
      12
      NTP
      13
      logaudit (log audit)
      14
      logalert (log alert)
      15
      clock (clock daemon)
      16
      local0
      17
      local1
      18
      local2
      19
      local3
      20
      local4
      21
      local5
      22
      local6
      23
      local7
  3. Select Continue.
Send test messages
Before using an external syslog server, request that all nodes in your grid send test messages to the external syslog server. These test messages help you validate your entire log collection infrastructure before you commit to sending data to the external syslog server.
Caution Don't use the external syslog server configuration until you confirm that the external syslog server received a test message from each node in your grid and that the message was processed as expected.
Steps
  1. If you don't want to send test messages because you are certain your external syslog server is configured properly and can receive audit information from all the nodes in your grid, select Skip and finish.
    A green banner indicates that the configuration has been saved.
  2. Otherwise, select Send test messages (recommended).
    Test results continuously appear on the page until you stop the test. While the test is in progress, your audit messages continue to be sent to your previously configured destinations.
  3. If you receive any errors during syslog server configuration or at runtime, correct them and select Send test messages again.
    See Troubleshoot an external syslog server to help you resolve any errors.
  4. Wait until you see a green banner indicating all nodes have passed testing.
  5. Check your syslog server to determine if test messages are being received and processed as expected.
    Note If you are using UDP, check your entire log collection infrastructure. The UDP protocol doesn't allow for as rigorous error detection as the other protocols.
  6. Select Stop and finish.
    You are returned to the Audit and syslog server page. A green banner indicates that the syslog server configuration has been saved.
    Note StorageGRID audit information isn't sent to the external syslog server until you select a destination that includes the external syslog server.
Select log location
You can specify where audit logs, security event logs, StorageGRID application logs, and access logs are sent.
Note
StorageGRID defaults to local node audit destinations and stores the audit information in /var/local/log/localaudit.log.
When using /var/local/log/localaudit.log, the Grid Manager and Tenant Manager audit log entries might be sent to a Storage Node. You can find which node has the most recent entries by using the run-each-node --parallel "zgrep MGAU /var/local/log/localaudit.log | tail" command.
Some destinations are available only if you have configured an external syslog server.
Steps
  1. Select Log location > Local node and external server.
  2. To change the log location for the log types, select a different option.
    Tip Local nodes only and External syslog server typically provide better performance.
    Option Description
    Local nodes only (default)
    Audit messages, security event logs, and application logs aren't sent to Admin Nodes. Instead, they are saved only on the nodes that generated them ("the local node"). The audit information generated on every local node is stored in /var/local/log/localaudit.log.
    Note: StorageGRID periodically removes local logs in a rotation to free up space. When the log file for a node reaches 1 GB, the existing file is saved, and a new log file is started. The rotation limit for the log is 21 files. When the 22nd version of the log file is created, the oldest log file is deleted. On average about 20 GB of log data is stored on each node. To store logs for an extended period of time, use a tenant and bucket for log storage.
    Admin Nodes/local nodes
    Audit messages are sent to the audit log on Admin Nodes, and security event logs and application logs are stored on the nodes that generated them. The audit information is stored in the following files:
    • Admin Nodes (primary and non-primary): /var/local/audit/export/audit.log
    • All nodes: The /var/local/log/localaudit.log file is typically empty or missing. It might contain secondary information, such as an additional copy of some messages.
    Audit information is sent to an external syslog server and saved on the local nodes (/var/local/log/localaudit.log). The type of information sent depends upon how you configured the external syslog server. This option is enabled only after you have configured an external syslog server.
    Admin Nodes and external syslog server
    Audit messages are sent to the audit log (/var/local/audit/export/audit.log) on Admin Nodes, and audit information is sent to the external syslog server and saved on the local node (/var/local/log/localaudit.log). The type of information sent depends upon how you configured the external syslog server. This option is enabled only after you have configured an external syslog server.
  3. Select Save.
    A warning message appears.
  4. Select OK to confirm that you want to change the destination for audit information.
    New logs are sent to the destinations you selected. Existing logs remain in their current location.
Use a bucket
Logs are periodically rotated. Use an S3 bucket in the same grid to store logs for an extended period of time.
  1. Select Log location > Use a bucket.
  2. Select the Enable archive logs checkbox.
  3. If the listed tenant and bucket aren't the ones you want to use, select Change tenant and bucket, and then select either Create tenant and bucket or Select tenant and bucket.
    1. Enter a new tenant name.
    2. Enter and confirm a password for the new tenant.
    3. Enter a new bucket name.
    4. Select Create and enable.
    1. Select a tenant name from the pull-down.
    2. Select a bucket from the pull-down.
    3. Select Select and enable.
  1. Select Save.
    Logs will be stored in the tenant and bucket you specified. The object key name for the logs are in this format:
    system-logs/{node_hostname}/{absolute_path_to_log_file_on_node}--{last_modified_time}.gz
    For example:
    system-logs/DC1-SN1/var/local/log/localaudit.log--2025-05-12_13:41:44.gz
Manage log retention
You can manage how long StorageGRID retains logs by creating an ILM rule or configuring an S3 bucket lifecycle policy.
ILM rule
Create an ILM rule for the bucket and add this rule to the active ILM policy.
Steps
  1. Select ILM > Rules.
  2. Select Create. Step 1 (Enter details) of the Create an ILM rule wizard appears:
    1. Enter a unique name for the rule. For example: ILM Rule for archived logs.
    2. Select the log archival S3 tenant account.
    3. Specify the log archival S3 bucket.
  3. Continue to Step 2 (Define placements) and define the placement for the archived logs rule. For example, the ILM rule stores one replicated copy in Site 1 and one replicated copy in Site 2 for the first year. After one year, a 2+1 erasure-coded copy is made and saved at only one site.
  4. After creating the rule, add it to an active ILM policy.
S3 bucket lifecycle
Configure an S3 bucket lifecycle policy on the log archival S3 bucket:
      "Rules": [
            "ID": "Retain logs forever",
            "Filter": {},
            "Status": "Enabled",
            "Expiration": {}
When you configure an S3 bucket lifecycle policy on the log archival S3 bucket, the lifecycle expiration actions override the ILM policy for objects matching the bucket lifecycle filter. Objects that don't match the bucket lifecycle filter use the retention settings of the ILM policy. If an object matches a bucket lifecycle filter and no expiration actions are explicitly specified, the retention settings of the ILM policy aren't used and it's implied that object versions are retained forever.
