Manage StorageGRID tenant users
You can create local users and assign them to local groups to determine which features these users can access. You can also import federated users. The Tenant Manager includes one predefined local user, named root. Although you can add and remove local users, you can't remove the root user.
If single sign-on (SSO) is enabled for your StorageGRID system, local users won't be able to sign in to the Tenant Manager or the Tenant Management API, although they can use client applications to access the tenant's resources, based on group permissions. |
You are signed in to the Tenant Manager using a supported web browser.
You belong to a user group that has the Root access permission.
If your tenant account has the Use grid federation connection permission, you have reviewed the workflow and considerations for syncing tenant groups and users, and you are signed in to the tenant's source grid.
Create a local user
You can create a local user and assign them to one or more local groups to control their access permissions.
S3 users who don't belong to any groups don't have management permissions or S3 group policies applied to them. These users might have S3 bucket access granted through a bucket policy.
Access the Create user wizard
Select Access Management > Users.
Select Create user.
Enter credentials
For the Enter user credentials step, complete the following fields.
Field Description Full name
The full name for this user, for example, the first name and last name of a person or the name of an application.
Username
The name this user will use to sign in. Usernames must be unique and can't be changed.
Note: If your tenant account has the Use grid federation connection permission, a cloning error will occur if the same Username already exists for the tenant on the destination grid.
Password and Confirm password
The password the user will initially use when signing in.
Deny access
Select Yes to prevent this user from signing in to the tenant account, even though they might still belong to one or more groups.
For example, select Yes to temporarily suspend a user's ability to sign in.
Select Continue.
Assign to groups
Assign the user to one or more local groups to determine which tasks they can perform.
Assigning a user to groups is optional. If you'd prefer, you can select users when you create or edit groups.
Users who don't belong to any groups will have no management permissions. Permissions are cumulative. Users will have all permissions for all groups they belong to. See Tenant management permissions.
Select Create user.
If your tenant account has the Use grid federation connection permission and you are on the tenant's source grid, the new local user is synced to the tenant's destination grid. Succeeded appears as the Sync status in the Overview section of the user's detail page.
Select Finish to return to the Users page.
View or edit local user
Review the information provided on the Users page, which lists basic information for all local and federated users for this tenant account.
If you want to change the user's full name:
Select the checkbox for the user.
Select Actions > Edit full name.
Enter the new name.
Select Save changes.
If you want to view more details or make additional edits, do either of the following:
Select the username.
Select the checkbox for the user, and select Actions > View user details.
Review the Overview section, which shows the following information for each user:
Full name
Username
User type
Denied access
Access mode
Group membership
Edit user settings as needed. See Create local user for details about what to enter.
In the Overview section, change the full name by selecting the name or the edit icon
.You can't change the username.
On the Password tab, change the user's password, and select Save changes.
On the Access tab, select No to allow the user to sign in or select Yes to prevent the user from signing in. Then, select Save changes.
On the Access keys tab, select Create key and follow the instructions for creating another user's S3 access keys.
On the Groups tab, select Edit groups to add the user to groups or remove the user from groups. Then, select Save changes.
Confirm that you selected Save changes for each section you changed.
Import federated users
You can import one or more federated users, up to a maximum of 100 users, directly into the Users page.
Select Import federated users.
Enter the UUID or username for one or more federated users.
For multiple entries, add each UUID or username on a new line.
Select Import.
If the import into the Users field fails for one or more users, perform the following steps:
Expand Users not imported and select Copy users.
Retry the import by selecting Previous and pasting the copied users into the Import federated users dialog box.
After you close the Import federated users dialog box, the federated user information displays on the Users page for the successfully imported users.
Duplicate local user
You can duplicate a local user to create a new user more quickly.
If your tenant account has the Use grid federation connection permission and you duplicate a user from the tenant's source grid, the duplicated user will be synced to the tenant's destination grid. |
Select the checkbox for the user you want to duplicate.
Select Actions > Duplicate user.
Select Create user.
Retry user sync
If any user failed to sync, "Failed" appears in the Sync status column for the user. A banner appears above the table to indicate that one or more users failed to sync.
To retry syncing:
On the banner, select Retry sync. This operation retries syncing for all users that failed to sync.
To retry syncing an individual user, select the user name. On the user details page, select Retry sync.
View the status of the sync operation from the details page of each user you're syncing.
If the retry is successful, "Succeeded" appears in the Sync status column for each user that was successfully synced, and the banner disappears.
For additional information, see Sync tenant groups and users.
Delete one or more local users
You can permanently delete one or more local users who no longer need to access the StorageGRID tenant account.
If your tenant account has the Use grid federation connection permission and you delete a local user, StorageGRID will delete the corresponding user on the other grids in the connection, unless that user is a federated user on a target grid. You must use the federated identity source to delete federated users. |
Select the checkbox for each user you want to delete.
Select Actions > Delete user or Actions > Delete users.
A confirmation dialog box appears.
Select Delete user or Delete users.
