Perform backend management with kubectl
Learn about how to perform backend management operations by using kubectl.
Delete a backend
By deleting a TridentBackendConfig, you instruct Astra Trident to delete/retain backends (based on deletionPolicy). To delete a backend, ensure that deletionPolicy is set to delete. To delete just the TridentBackendConfig, ensure that deletionPolicy is set to retain. This will ensure the backend is still present and can be managed by using tridentctl.
Run the following command:
kubectl delete tbc <tbc-name> -n trident
Astra Trident does not delete the Kubernetes Secrets that were in use by TridentBackendConfig. The Kubernetes user is responsible for cleaning up secrets. Care must be taken when deleting secrets. You should delete secrets only if they are not in use by the backends.
View the existing backends
kubectl get tbc -n trident
You can also run tridentctl get backend -n trident or tridentctl get backend -o yaml -n trident to obtain a list of all backends that exist. This list will also include backends that were created with tridentctl.
Update a backend
There can be multiple reasons to update a backend:
Credentials to the storage system have changed. To update credentials, the Kubernetes Secret that is used in the
TridentBackendConfigobject must be updated. Astra Trident will automatically update the backend with the latest credentials provided. Run the following command to update the Kubernetes Secret:
kubectl apply -f <updated-secret-file.yaml> -n trident
Parameters (such as the name of the ONTAP SVM being used) need to be updated.
In this case,TridentBackendConfigobjects can be updated directly through Kubernetes.
kubectl apply -f <updated-backend-file.yaml>
Alternatively, make changes to the existing TridentBackendConfig CR by running the following command:
kubectl edit tbc <tbc-name> -n trident
If a backend update fails, the backend continues to remain in its last known configuration. You can view the logs to determine the cause by running kubectl get tbc <tbc-name> -o yaml -n trident or kubectl describe tbc <tbc-name> -n trident.
After you identify and correct the problem with the configuration file, you can re-run the update command.
