Astra Trident
Pod Security Standards (PSS) and Security Context Constraints (SCC)
Contributors netapp-aruldeepa
Kubernetes Pod Security Standards (PSS) and Pod Security Policies (PSP) define permission levels and restrict the behavior of pods. OpenShift Security Context Constraints (SCC) similarly define pod restriction specific to the OpenShift Kubernetes Engine. To provide this customization, Astra Trident enables certain permissions during installation. The following sections detail the permissions set by Astra Trident.
Note PSS replaces Pod Security Policies (PSP). PSP was deprecated in Kubernetes v1.21 and will be removed in v1.25. For more information, Refer to Kubernetes: Security.
Permission Description
Privileged
CSI requires mount points to be Bidirectional, which means the Trident node pod must run a privileged container. For more information, refer to Kubernetes: Mount propagation.
Host networking
Required for the iSCSI daemon. iscsiadm manages iSCSI mounts and uses host networking to communicate with the iSCSI daemon.
Host IPC
NFS uses interprocess communication (IPC) to communicate with the NFSD.
Host PID
Required to start rpc-statd for NFS. Astra Trident queries host processes to determine if rpc-statd is running before mounting NFS volumes.
Capabilities
The SYS_ADMIN capability is provided as part of the default capabilities for privileged containers. For example, Docker sets these capabilities for privileged containers:
CapPrm: 0000003fffffffff
CapEff: 0000003fffffffff
Seccomp
Seccomp profile is always "Unconfined" in privileged containers; therefore, it cannot be enabled in Astra Trident.
SELinux
On OpenShift, privileged containers are run in the spc_t ("Super Privileged Container") domain, and unprivileged containers are run in the container_t domain. On containerd, with container-selinux installed, all containers are run in the spc_t domain, which effectively disables SELinux. Therefore, Astra Trident does not add seLinuxOptions to containers.
DAC
Privileged containers must be run as root. Non-privileged containers run as root to access unix sockets required by CSI.
Label Description Default
pod-security.kubernetes.io/enforce
pod-security.kubernetes.io/enforce-version
Allows the Trident Controller and nodes to be admitted into the install namespace.
Do not change the namespace label.
enforce: privileged
enforce-version: <version of the current cluster or highest version of PSS tested.>
Warning Changing the namespace labels can result in pods not being scheduled, an "Error creating: …​" or, "Warning: trident-csi-…​". If this happens, check if the namespace label for privileged was changed. If so, reinstall Trident.
Field Description Default
allowPrivilegeEscalation
Privileged containers must allow privilege escalation.
true
allowedCSIDrivers
Trident does not use inline CSI ephemeral volumes.
Empty
allowedCapabilities
Non-privileged Trident containers do not require more capabilities than the default set and privileged containers are granted all possible capabilities.
Empty
allowedFlexVolumes
Trident does not make use of a FlexVolume driver, therefore they are not included in the list of allowed volumes.
Empty
allowedHostPaths
The Trident node pod mounts the node's root filesystem, therefore there is no benefit to setting this list.
Empty
allowedProcMountTypes
Trident does not use any ProcMountTypes.
Empty
allowedUnsafeSysctls
Trident does not require any unsafe sysctls.
Empty
defaultAddCapabilities
No capabilities are required to be added to privileged containers.
Empty
defaultAllowPrivilegeEscalation
Allowing privilege escalation is handled in each Trident pod.
false
forbiddenSysctls
No sysctls are allowed.
Empty
fsGroup
Trident containers run as root.
RunAsAny
hostIPC
Mounting NFS volumes requires host IPC to communicate with nfsd
true
hostNetwork
iscsiadm requires the host network to communicate with the iSCSI daemon.
true
hostPID
Host PID is required to check if rpc-statd is running on the node.
true
hostPorts
Trident does not use any host ports.
Empty
privileged
Trident node pods must run a privileged container in order to mount volumes.
true
readOnlyRootFilesystem
Trident node pods must write to the node filesystem.
false
requiredDropCapabilities
Trident node pods run a privileged container and cannot drop capabilities.
none
runAsGroup
RunAsAny
runAsUser
runAsAny
runtimeClass
Trident does not use RuntimeClasses.
Empty
seLinux
Trident does not set seLinuxOptions because there are currently differences in how container runtimes and Kubernetes distributions handle SELinux.
Empty
supplementalGroups
RunAsAny
volumes
Trident pods require these volume plugins.
hostPath, projected, emptyDir
Labels Description Default
allowHostDirVolumePlugin
Trident node pods mount the node's root filesystem.
true
allowHostIPC
Mounting NFS volumes requires host IPC to communicate with nfsd.
true
allowHostNetwork
true
allowHostPID
true
allowHostPorts
false
true
allowPrivilegedContainer
true
none
allowedCapabilities
Empty
Empty
fsGroup
RunAsAny
groups
This SCC is specific to Trident and is bound to its user.
Empty
false
none
runAsUser
RunAsAny
seLinuxContext
Empty
seccompProfiles
Privileged containers always run "Unconfined".
Empty
supplementalGroups
RunAsAny
users
One entry is provided to bind this SCC to the Trident user in the Trident namespace.
n/a
volumes
hostPath, downwardAPI, projected, emptyDir
