What’s new
Release Notes provide information about new features, enhancements, and bug fixes in the latest version of Trident.
The tridentctl binary for Linux that is provided in the installer zip file is the tested and supported version. Be aware that the macos binary provided in the /extras part of the zip file is not tested or supported.
What's new in 25.02.1
Trident
Fixes
Kubernetes:
Fixed an issue in the trident-operator where sidecar image names and versions were incorrectly populated when using a non-default image registry (Issue #983).
Fixed the issue where multipath sessions fail to recover during an ONTAP failover giveback (Issue #961).
Changes in 25.02
Beginning with Trident 25.02, the What's New summary provides details about enhancements, fixes, and deprecations for both Trident and Trident Protect releases.
Trident
Enhancements
Kubernetes:
Added support for ONTAP ASA r2 for iSCSI.
Added support for force detach for ONTAP-NAS volumes during Non-Graceful Node Shutdown scenarios. New ONTAP-NAS volumes will now utilize per-volume export policies managed by Trident. Provided an upgrade path for existing volumes to transition to the new export policy model on unpublish without affecting active workloads.
Added cloneFromSnapshot annotation.
Added support for cross namespace volume cloning.
Enhanced iSCSI self-healing scan remediations to initiate rescans by exact host, channel, target and LUN ID.
Added support for Kubernetes 1.32.
OpenShift:
Added support for automatic iSCSI node preparation for RHCOS on ROSA clusters.
Added support for OpenShift Virtualization for ONTAP drivers.
Added Fibre Channel support on ONTAP-SAN driver.
Added NVMe LUKS support.
Switched to scratch image for all base images.
Added iSCSI connection state discovery and logging when iSCSI sessions should be logged in but are not (Issue #961).
Added support for SMB volumes with google-cloud-netapp-volumes driver.
Added support to allow ONTAP volumes to skip recovery queue on deletion.
Added support to override default images using SHAs instead of tags.
Added image-pull-secrets flag to tridentctl installer.
Fixes
Kubernetes:
Fixed missing node IP addresses from automatic export policies (Issue #965).
Fixed automatic export policies switching to per volume policy prematurely for ONTAP-NAS-Economy.
Fixed backend config credentials to support all available AWS ARN partitions (Issue #913).
Added option to disable the auto configurator reconciliation in the Trident operator (Issue #924).
Added securityContext for csi-resizer container (Issue #976).
Trident Protect
NetApp Trident Protect provides advanced application data management capabilities that enhance the functionality and availability of stateful Kubernetes applications backed by NetApp ONTAP storage systems and the NetApp Trident CSI storage provisioner.
Enhancements
Added backup and restore support for KubeVirt / OpenShift Virtualization VMs for both volumeMode: File and volumeMode: Block (raw device) storage. This support is compatible with all Trident drivers, and enhances the existing protection features when replicating storage using NetApp SnapMirror with Trident Protect.
Added the capability to control freeze behavior at application level for Kubevirt environments.
Added support for configuring AutoSupport proxy connections.
Added the ability to define a secret for data mover encryption (Kopia / Restic).
Added the ability to manually run an execution hook.
Added the ability to configure security context constraints (SCCs) during Trident Protect installation.
Added support for configuring nodeSelector during Trident Protect installation.
Added support for HTTP / HTTPS egress proxy for AppVault objects.
Extended ResourceFilter to enable exclusion of cluster-scoped resources.
Added support for the AWS session token in S3 AppVault credentials.
Added support for resource collection after pre-snapshot execution hooks.
Fixes
Improved the management of temporary volumes to skip the ONTAP volume recovery queue.
SCC annotations are now restored to original values.
Improved restore efficiency with support for parallel operations.
Enhanced support for execution hook timeouts for larger applications.
Changes in 24.10.1
Enhancements
Kubernetes: Added support for Kubernetes 1.32.
Fixes
Updated Trident and Trident-ASUP dependencies to address CVE-2024-45337 and CVE-2024-45310.
Removed logouts for intermittently unhealthy non-CHAP portals during iSCSI self-healing (Issue #961).
Changes in 24.10
Enhancements
Google Cloud NetApp Volumes driver is now generally available for NFS volumes and supports zone-aware provisioning.
GCP Workload Identity will be used as Cloud Identity for Google Cloud NetApp Volumes with GKE.
Added
formatOptionsconfiguration parameter to ONTAP-SAN and ONTAP-SAN-Economy drivers to allow users to specify LUN format options. -
Reduced Azure NetApp Files minimum volume size to 50 GiB. Azure new minimum size expected to be generally available in November.
Added
denyNewVolumePoolsconfiguration parameter to restrict ONTAP-NAS-Economy and ONTAP-SAN-Economy drivers to preexisting Flexvol pools. -
Added detection for the addition, removal, or renaming of aggregates from the SVM across all ONTAP drivers.
Added 18MiB overhead to LUKS LUNs to ensure reported PVC size is usable.
Improved ONTAP-SAN and ONTAP-SAN-Economy node stage and unstage error handling to allow unstage to remove devices after a failed stage.
Added a custom role generator allowing customers to create a minimalistic role for Trident in ONTAP.
Added additional logging for troubleshooting
lsscsi(Issue #792).
Kubernetes
Added new Trident features for Kubernetes-native workflows:
Data protection
Data migration
Disaster recovery
Application mobility
Added a new flag
--k8s_api_qpsto installers to set the QPS value used by Trident to communicate with the Kubernetes API server. -
Added
--node-prepflag to installers for automatic management of storage protocol dependencies on Kubernetes cluster nodes. Tested and verified compatibility with Amazon Linux 2023 iSCSI storage protocol -
Added support for force detach for ONTAP-NAS-Economy volumes during Non-Graceful Node Shutdown scenarios.
New ONTAP-NAS-Economy NFS volumes will use per-qtree export policies when using
autoExportPolicybackend option. Qtrees will only be mapped to node restrictive export policies at time of publish to improve access control and security. Existing qtrees will be switched to the new export policy model when Trident unpublishes the volume from all nodes to do so without impacting active workloads. -
Added support for Kubernetes 1.31.
Experimental Enhancements
Added tech preview for Fibre Channel support on ONTAP-SAN driver.
Fixes
Kubernetes:
Fixed Rancher admission webhook preventing Trident Helm installations (Issue #839).
Fixed Affinity key in helm chart values (Issue #898).
Fixed tridentControllerPluginNodeSelector/tridentNodePluginNodeSelector won't work with "true" value (Issue #899).
Deleted ephemeral snapshots created during cloning (Issue #901).
Added support for Windows Server 2019.
Fixed `go mod tidy`in Trident repo (Issue #767).
Deprecations
Kubernetes:
Updated minimum supported Kubernetes to 1.25.
Removed support for POD Security Policy.
Product rebranding
Beginning with the 24.10 release, Astra Trident is rebranded to Trident (Netapp Trident). This rebranding does not affect any features, platforms supported, or interoperability for Trident.
Changes in 24.06
Enhancements
IMPORTANT: The
limitVolumeSizeparameter now limits qtree/LUN sizes in the ONTAP economy drivers. Use the newlimitVolumePoolSizeparameter to control Flexvol sizes in those drivers. (Issue #341). -
Added ability for iSCSI self-healing to initiate SCSI scans by exact LUN ID if deprecated igroups are in use (Issue #883).
Added support for volume clone and resize operations to be allowed even when the backend is in suspended mode.
Added ability for user-configured log settings for the Trident controller to be propagated to Trident node pods.
Added support in Trident to use REST by default instead of ONTAPI (ZAPI) for ONTAP versions 9.15.1 and later.
Added support for custom volume names and metadata on the ONTAP storage backends for new persistent volumes.
Enhanced the
azure-netapp-files(ANF) driver to automatically enable the snapshot directory by default when the NFS mount options are set to use NFS version 4.x. -
Added Bottlerocket support for NFS volumes.
Added technical preview support for Google Cloud NetApp Volumes.
Kubernetes
Added support for Kubernetes 1.30.
Added ability for Trident DaemonSet to clean zombie mounts and residual tracking files at startup (Issue #883).
Added PVC annotation
trident.netapp.io/luksEncryptionfor dynamically importing LUKS volumes (Issue #849). -
Added topology awareness to ANF driver.
Added support for Windows Server 2022 nodes.
Fixes
Fixed Trident installation failures due to stale transactions.
Fixed tridentctl to ignore warning messages from Kubernetes (Issue #892).
Changed Trident controller
SecurityContextConstraintpriority to0(Issue #887). -
ONTAP drivers now accept volume sizes below 20MiB (Issue[#885).
Fixed Trident to prevent shrinking of FlexVol volumes during resize operation for the ONTAP-SAN driver.
Fixed ANF volume import failure with NFS v4.1.
Changes in 24.02
Enhancements
Added support for Cloud Identity.
AKS with ANF - Azure Workload Identity will be used as Cloud identity.
EKS with FSxN - AWS IAM role will be used as Cloud identity.
Added support to install Trident as an add-on on EKS cluster from EKS console.
Added ability to configure and disable iSCSI self-healing (Issue #864).
Added Amazon FSx personality to ONTAP drivers to enable integration with AWS IAM and SecretsManager, and to enable Trident to delete FSx volumes with backups (Issue #453).
Kubernetes
Added support for Kubernetes 1.29.
Fixes
Fixed ACP warning messages, when ACP is not enabled (Issue #866).
Added a 10-second delay before performing a clone split during snapshot delete for ONTAP drivers, when a clone is associated with the snapshot.
Deprecations
Removed in-toto attestations framework from multi-platform image manifests.
Changes in 23.10
Fixes
Fixed volume expansion if a new requested size is smaller than the total volume size for ontap-nas and ontap-nas-flexgroup storage drivers (Issue #834).
Fixed volume size to display only usable size of the volume during import for ontap-nas and ontap-nas-flexgroup storage drivers (Issue #722).
Fixed FlexVol name conversion for ONTAP-NAS-Economy.
Fixed Trident initialization issue on a windows node when node is rebooted.
Enhancements
Kubernetes
Added support for Kubernetes 1.28.
Trident
Added support for using Azure Managed Identities (AMI) with azure-netapp-files storage driver.
Added support for NVMe over TCP for the ONTAP-SAN driver.
Added ability to pause the provisioning of a volume when backend is set to suspended state by user (Issue #558).
Changes in 23.07.1
Kubernetes: Fixed daemonset deletion to support zero-downtime upgrades (Issue #740).
Changes in 23.07
Fixes
Kubernetes
Fixed Trident upgrade to disregard old pods stuck in terminating state (Issue #740).
Added toleration to "transient-trident-version-pod" definition (Issue #795).
Trident
Fixed ONTAPI (ZAPI) requests to ensure LUN serial numbers are queried when getting LUN attributes to identify and fix ghost iSCSI devices during Node Staging operations.
Fixed error handling in storage driver code (Issue #816).
Fixed quota resize when using ONTAP drivers with use-rest=true.
Fixed LUN clone creation in ontap-san-economy.
Revert publish info field from
rawDevicePathtodevicePath; added logic to populate and recover (in some cases)devicePathfield.
Enhancements
Kubernetes
Added support for importing pre-provisioned snapshots.
Minimized deployment and daemonset linux permissions (Issue #817).
Trident
No longer reporting the state field for "online" volumes and snapshots.
Updates the backend state if the ONTAP backend is offline (Issues #801, #543).
LUN Serial Number is always retrieved and published during the ControllerVolumePublish workflow.
Added additional logic to verify iSCSI multipath device serial number and size.
Additional verification for iSCSI volumes to ensure correct multipath device is unstaged.
Added tech preview support for NVMe over TCP for the ONTAP-SAN driver.
Documentation
Many organizational and formatting improvements have been made.
Deprecations
Kubernetes
Removed support for v1beta1 snapshots.
Removed support for pre-CSI volumes and storage classes.
Updated minimum supported Kubernetes to 1.22.
Changes in 23.04
Force volume detach for ONTAP-SAN-* volumes is supported only with Kubernetes versions with the Non-Graceful Node Shutdown feature gate enabled. Force detach must be enabled at install time using the --enable-force-detach Trident installer flag.
Fixes
Fixed Trident Operator to use IPv6 localhost for installation when specified in spec.
Fixed Trident Operator cluster role permissions to be in sync with the bundle permissions (Issue #799).
Fixed issue with attaching raw block volume on multiple nodes in RWX mode.
Fixed FlexGroup cloning support and volume import for SMB volumes.
Fixed issue where Trident controller could not shut down immediately (Issue #811).
Added fix to list all igroup names associated with a specified LUN provisioned with ontap-san-* drivers.
Added a fix to allow external processes to run to completion.
Fixed compilation error for s390 architecture (Issue #537).
Fixed incorrect logging level during volume mount operations (Issue #781).
Fixed potential type assertion error (Issue #802).
Enhancements
Kubernetes:
Added support for Kubernetes 1.27.
Added support for importing LUKS volumes.
Added support for ReadWriteOncePod PVC access mode.
Added support for force detach for ONTAP-SAN-* volumes during Non-Graceful Node Shutdown scenarios.
All ONTAP-SAN-* volumes will now use per-node igroups. LUNs will only be mapped to igroups while actively published to those nodes to improve our security posture. Existing volumes will be opportunistically switched to the new igroup scheme when Trident determines it is safe to do so without impacting active workloads (Issue #758).
Improved Trident security by cleaning up unused Trident-managed igroups from ONTAP-SAN-* backends.
Added support for SMB volumes with Amazon FSx to the ontap-nas-economy and ontap-nas-flexgroup storage drivers.
Added support for SMB shares with the ontap-nas, ontap-nas-economy and ontap-nas-flexgroup storage drivers.
Added support for arm64 nodes (Issue #732).
Improved Trident shutdown procedure by deactivating API servers first (Issue #811).
Added cross-platform build support for Windows and arm64 hosts to Makefile; see BUILD.md.
Deprecations
Kubernetes: Backend-scoped igroups will no longer be created when configuring ontap-san and ontap-san-economy drivers (Issue #758).
Changes in 23.01.1
Fixes
Fixed Trident Operator cluster role permissions to be in sync with the bundle permissions Issue #799.
Changes in 23.01
Kubernetes 1.27 is now supported in Trident. Please upgrade Trident prior to upgrading Kubernetes. |
Fixes
Kubernetes: Added options to exclude Pod Security Policy creation to fix Trident installations via Helm (Issues #783, #794).
Enhancements
Added support for Kubernetes 1.26.
Improved overall Trident RBAC resource utilization (Issue #757).
Added automation to detect and fix broken or stale iSCSI sessions on host nodes.
Added support for expanding LUKS encrypted volumes.
Kubernetes: Added credential rotation support for LUKS encrypted volumes.
Added support for SMB volumes with Amazon FSx for NetApp ONTAP to the ontap-nas storage driver.
Added support for NTFS permissions when using SMB volumes.
Added support for storage pools for GCP volumes with CVS service level.
Added support for optional use of flexgroupAggregateList when creating FlexGroups with the ontap-nas-flexgroup storage driver.
Improved performance for the ontap-nas-economy storage driver when managing multiple FlexVol volumes
Enabled dataLIF updates for all ONTAP NAS storage drivers.
Updated the Trident Deployment and DaemonSet naming convention to reflect the host node OS.
Deprecations
Kubernetes: Updated minimum supported Kubernetes to 1.21.
DataLIFs should no longer be specified when configuring
ontap-sanorontap-san-economydrivers.
Changes in 22.10
You must read the following critical information before upgrading to Trident 22.10.
Critical information about Trident 22.10
Fixes
Fixed issue specific to ONTAP backend created using
credentialsfield failing to come online during 22.07.0 upgrade (Issue #759). -
Docker: Fixed an issue causing the Docker volume plugin to fail to start in some environments (Issue #548 and Issue #760).
Fixed SLM issue specific to ONTAP SAN backends to ensure only subset of dataLIFs belonging to reporting nodes are published.
Fixed performance issue where unnecessary scans for iSCSI LUNs happened when attaching a volume.
Removed granular retries within the Trident iSCSI workflow to fail fast and reduce external retry intervals.
Fixed issue where an error was returned when flushing an iSCSI device when the corresponding multipath device was already flushed.
Enhancements
Kubernetes:
Added support for Kubernetes 1.25. You must upgrade Trident to 22.10 prior to upgrading to Kubernetes 1.25.
Added a separate ServiceAccount, ClusterRole, and ClusterRoleBinding for the Trident Deployment and DaemonSet to allow future permissions enhancements.
Added support for cross-namespace volume sharing.
All Trident
ontap-*storage drivers now work with the ONTAP REST API. -
Added new operator yaml (
bundle_post_1_25.yaml) without aPodSecurityPolicyto support Kubernetes 1.25. -
Added support for LUKS-encrypted volumes for
ontap-sanandontap-san-economystorage drivers. -
Added support for Windows Server 2019 nodes.
Added support for SMB volumes on Windows nodes through the
azure-netapp-filesstorage driver. -
Automatic MetroCluster switchover detection for ONTAP drivers is now generally available.
Deprecations
Kubernetes: Updated minimum supported Kubernetes to 1.20.
Removed Astra Data Store (ADS) driver.
Removed support for
yesandsmartoptions forfind_multipathswhen configuring worker node multipathing for iSCSI.
Changes in 22.07
Fixes
Kubernetes
Fixed issue to handle boolean and number values for node selector when configuring Trident with Helm or the Trident Operator. (GitHub issue #700)
Fixed issue in handling errors from non-CHAP path, so that kubelet will retry if it fails. GitHub issue #736)
Enhancements
Transition from k8s.gcr.io to registry.k8s.io as default registry for CSI images
ONTAP-SAN volumes will now use per-node igroups and only map LUNs to igroups while actively published to those nodes to improve our security posture. Existing volumes will be opportunistically switched to the new igroup scheme when Trident determines it is safe to do so without impacting active workloads.
Included a ResourceQuota with Trident installations to ensure Trident DaemonSet is scheduled when PriorityClass consumption is limited by default.
Added support for Network Features to Azure NetApp Files driver. (GitHub issue #717)
Added tech preview automatic MetroCluster switchover detection to ONTAP drivers. (GitHub issue #228)
Deprecations
Kubernetes: Updated minimum supported Kubernetes to 1.19.
Backend config no longer allows multiple authentication types in single config.
Removals
AWS CVS driver (deprecated since 22.04) has been removed.
Kubernetes
Removed unnecessary SYS_ADMIN capability from node pods.
Reduces nodeprep down to simple host info and active service discovery to do a best-effort
confirmation that NFS/iSCSI services are available on worker nodes.
Documentation
A new Pod Security Standards (PSS) section has been added detailing permissions enabled by Trident on installation.
Changes in 22.04
NetApp is continually improving and enhancing its products and services. Here are some of the latest features in Trident. For previous releases, refer to earlier versions of documentation].
If you are upgrading from any previous Trident release and use Azure NetApp Files, the location config parameter is now a mandatory, singleton field.
Fixes
Improved parsing of iSCSI initiator names. (GitHub issue #681)
Fixed issue where CSI storage class parameters weren't allowed. (GitHub issue #598)
Fixed duplicate key declaration in Trident CRD. (GitHub issue #671)
Fixed inaccurate CSI Snapshot logs. (GitHub issue #629))
Fixed issue with unpublishing volumes on deleted nodes. (GitHub issue #691)
Added handling of filesystem inconsistencies on block devices. (GitHub issue #656)
Fixed issue pulling auto-support images when setting the
imageRegistryflag during installation. (GitHub issue #715) -
Fixed issue where Azure NetApp Files driver failed to clone a volume with multiple export rules.
Enhancements
Inbound connections to Trident's secure endpoints now require a minimum of TLS 1.3. (GitHub issue #698)
Trident now adds HSTS headers to responses from its secure endpoints.
Trident now attempts to enable the Azure NetApp Files unix permissions feature automatically.
Kubernetes: Trident daemonset now runs at system-node-critical priority class. (GitHub issue #694)
Removals
E-Series driver (disabled since 20.07) has been removed.
Changes in 22.01.1
Fixes
Fixed panic when accessing nil fields for aggregate space in ONTAP API responses.
Changes in 22.01.0
Fixes
Kubernetes: Increase node registration backoff retry time for large clusters.
Fixed issue where azure-netapp-files driver could be confused by multiple resources with the same name.
ONTAP SAN IPv6 DataLIFs now work if specified with brackets.
Fixed issue where attempting to import an already imported volume returns EOF leaving PVC in pending state. (GitHub issue #489)
Fixed issue when Trident performance slows down when > 32 snapshots are created on a SolidFire volume.
Replaced SHA-1 with SHA-256 in SSL certificate creation.
Fixed Azure NetApp Files driver to allow duplicate resource names and limit operations to a single location.
Enhancements
Kubernetes enhancements:
Added support for Kubernetes 1.23.
Add scheduling options for Trident pods when installed via Trident Operator or Helm. (GitHub issue #651)
Allow cross-region volumes in GCP driver. (GitHub issue #633)
Added support for 'unixPermissions' option to Azure NetApp Files volumes. (GitHub issue #666)
Deprecations
Trident REST interface can listen and serve only at 127.0.0.1 or [::1] addresses
Changes in 21.10.1
The v21.10.0 release has an issue that can put the Trident controller into a CrashLoopBackOff state when a node is removed and then added back to the Kubernetes cluster. This issue is fixed in v21.10.1 (GitHub issue 669). |
Fixes
Fixed potential race condition when importing a volume on a GCP CVS backend resulting in failure to import.
Fixed an issue that can put the Trident controller into a CrashLoopBackOff state when a node is removed and then added back to the Kubernetes cluster (GitHub issue 669).
Fixed issue where SVMs were no longer discovered if no SVM name was specified (GitHub issue 612).
Changes in 21.10.0
Fixes
Fixed issue where clones of XFS volumes could not be mounted on the same node as the source volume (GitHub issue 514).
Fixed issue where Trident logged a fatal error on shutdown (GitHub issue 597).
Kubernetes-related fixes:
Return a volume's used space as the minimum restoreSize when creating snapshots with
ontap-nasandontap-nas-flexgroupdrivers (GitHub issue 645). -
Fixed issue where
Failed to expand filesystemerror was logged after volume resize (GitHub issue 560). -
Fixed issue where a pod could get stuck in
Terminatingstate (GitHub issue 572). -
Fixed the case where an
ontap-san-economyFlexVol might be full of snapshot LUNs (GitHub issue 533). -
Fixed custom YAML installer issue with different image (GitHub issue 613).
Fixed snapshot size calculation (GitHub issue 611).
Fixed issue where all Trident installers could identify plain Kubernetes as OpenShift (GitHub issue 639).
Fixed the Trident operator to stop reconciliation if the Kubernetes API server is unreachable (GitHub issue 599).
Enhancements
Added support for
unixPermissionsoption to GCP-CVS Performance volumes. -
Added support for scale-optimized CVS volumes in GCP in the range 600 GiB to 1 TiB.
Kubernetes-related enhancements:
Added support for Kubernetes 1.22.
Enabled the Trident operator and Helm chart to work with Kubernetes 1.22 (GitHub issue 628).
Added operator image to
tridentctlimages command (GitHub issue 570).
Experimental enhancements
Added support for volume replication in the
ontap-sandriver. -
Added tech preview REST support for the
ontap-nas-flexgroup,ontap-san, andontap-nas-economydrivers.
Known issues
Known issues identify problems that might prevent you from using the product successfully.
When upgrading a Kubernetes cluster from 1.24 to 1.25 or later that has Trident installed, you must update values.yaml to set
excludePodSecurityPolicytotrueor add--set excludePodSecurityPolicy=trueto thehelm upgradecommand before you can upgrade the cluster. -
Trident now enforces a blank
fsType(fsType="") for volumes that do not have thefsTypespecified in their StorageClass. When working with Kubernetes 1.17 or later, Trident supports providing a blankfsTypefor NFS volumes. For iSCSI volumes, you are required to set thefsTypeon your StorageClass when enforcing anfsGroupusing a Security Context. -
When using a backend across multiple Trident instances, each backend configuration file should have a different
storagePrefixvalue for ONTAP backends or use a differentTenantNamefor SolidFire backends. Trident cannot detect volumes that other instances of Trident have created. Attempting to create an existing volume on either ONTAP or SolidFire backends succeeds, because Trident treats volume creation as an idempotent operation. IfstoragePrefixorTenantNamedo not differ, there might be name collisions for volumes created on the same backend. -
When installing Trident (using
tridentctlor the Trident Operator) and usingtridentctlto manage Trident, you should ensure theKUBECONFIGenvironment variable is set. This is necessary to indicate the Kubernetes cluster thattridentctlshould work against. When working with multiple Kubernetes environments, you should ensure that theKUBECONFIGfile is sourced accurately. -
To perform online space reclamation for iSCSI PVs, the underlying OS on the worker node might require mount options to be passed to the volume. This is true for RHEL/Red Hat Enterprise Linux CoreOS (RHCOS) instances, which require the
discardmount option; ensure that the discard mountOption is included in yourStorageClassto support online block discard. -
If you have more than one instance of Trident per Kubernetes cluster, Trident cannot communicate with other instances and cannot discover other volumes that they have created, which leads to unexpected and incorrect behavior if more than one instance runs within a cluster. There should be only one instance of Trident per Kubernetes cluster.
If Trident-based
StorageClassobjects are deleted from Kubernetes while Trident is offline, Trident does not remove the corresponding storage classes from its database when it comes back online. You should delete these storage classes usingtridentctlor the REST API. -
If a user deletes a PV provisioned by Trident before deleting the corresponding PVC, Trident does not automatically delete the backing volume. You should remove the volume via
ONTAP cannot concurrently provision more than one FlexGroup at a time unless the set of aggregates are unique to each provisioning request.
When using Trident over IPv6, you should specify
managementLIFanddataLIFin the backend definition within square brackets. For example,[fd20:8b1e:b258:2000:f816:3eff:feec:0].You cannot specify dataLIFon an ONTAP SAN backend. Trident discovers all available iSCSI LIFs and uses them to establish the multipath session. -
If using the
solidfire-sandriver with OpenShift 4.5, ensure that the underlying worker nodes use MD5 as the CHAP authentication algorithm. Secure FIPS-compliant CHAP algorithms SHA1, SHA-256, and SHA3-256 are available with Element 12.7.
