Known issues
Contributors netapp-aruldeepa
Known issues identify problems that might prevent you from using this release of the product successfully.
The following known issues affect the current release:
Restoring Restic backups of large files can fail
When restoring 30GB or larger files from an Amazon S3 backup that was made using Restic, the restore operation can fail. As a workaround, back up the data using Kopia as the data mover (Kopia is the default data mover for backups). Refer to Protect applications using Trident Protect for instructions.
