Customize Trident operator installation
Contributors netapp-aruldeepa
The Trident operator allows you to customize Trident installation using the attributes in the TridentOrchestrator spec. If you want to customize the installation beyond what TridentOrchestrator arguments allow, consider using tridentctl to generate custom YAML manifests to modify as needed.
Understanding controller pods and node pods
Trident runs as a single controller pod, plus a node pod on each worker node in the cluster. The node pod must be running on any host where you want to potentially mount a Trident volume.
Kubernetes node selectors and tolerations and taints are used to constrain a pod to run on a specific or preferred node. Using the`ControllerPlugin` and NodePlugin, you can specify constraints and overrides.
  • The controller plugin handles volume provisioning and management, such as snapshots and resizing.
  • The node plugin handles attaching the storage to the node.
Configuration options
Warning spec.namespace is specified in TridentOrchestrator to signify the namespace where Trident is installed. This parameter cannot be updated after Trident is installed. Attempting to do so causes the TridentOrchestrator status to change to Failed. Trident is not intended to be migrated across namespaces.
This table details TridentOrchestrator attributes.
Parameter Description Default
namespace
Namespace to install Trident in
"default"
debug
Enable debugging for Trident
false
enableForceDetach
ontap-san, ontap-san-economy, ontap-nas, and ontap-nas-economy only.
Works with Kubernetes Non-Graceful Node Shutdown (NGNS) to grant cluster administrators ability to safely migrate workloads with mounted volumes to new nodes should a node become unhealthy.
false
windows
Setting to true enables installation on Windows worker nodes.
false
cloudProvider
Set to "Azure" when using managed identities or a cloud identity on an AKS cluster.
Set to "AWS" when using a cloud identity on an EKS cluster.
Set to "GCP" when using a cloud identity on a GKE cluster.
cloudIdentity
Set to workload identity ("azure.workload.identity/client-id: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx") when using cloud identity on an AKS cluster.
Set to AWS IAM role ("'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/trident-role'") when using cloud identity on an EKS cluster.
Set to cloud identity ("'iam.gke.io/gcp-service-account: xxxx@mygcpproject.iam.gserviceaccount.com'") when using cloud identity on a GKE cluster.
IPv6
Install Trident over IPv6
false
k8sTimeout
Timeout for Kubernetes operations.
Note The k8sTimeout parameter is applicable only for Trident installation.
180sec
silenceAutosupport
Don't send autosupport bundles to NetApp
automatically
false
autosupportImage
The container image for Autosupport Telemetry
"netapp/trident-autosupport:25.06"
autosupportProxy
The address/port of a proxy for sending Autosupport
Telemetry
"http://proxy.example.com:8888"
uninstall
A flag used to uninstall Trident
false
logFormat
Trident logging format to be used [text,json]
"text"
tridentImage
Trident image to install
"netapp/trident:25.06"
imageRegistry
Path to internal registry, of the format
<registry FQDN>[:port][/subpath]
"registry.k8s.io"
kubeletDir
Path to the kubelet directory on the host
"/var/lib/kubelet"
wipeout
A list of resources to delete to perform a complete removal of
Trident
imagePullSecrets
Secrets to pull images from an internal registry
imagePullPolicy
Sets the image pull policy for the the Trident operator. Valid values are:
Always to always pull the image.
IfNotPresent to pull the image only if it does not already exist on the node.
Never to never pull the image.
IfNotPresent
controllerPluginNodeSelector
Additional node selectors for pods. Follows same format as pod.spec.nodeSelector.
No default; optional
controllerPluginTolerations
Overrides Kubernetes tolerations for pods. Follows the same format as pod.spec.Tolerations.
nodePluginNodeSelector
nodePluginTolerations
nodePrep
Enables Trident to prepare the nodes of the Kubernetes cluster to manage volumes using the specified data storage protocol.
Currently, iscsi is the only value supported.
Note Beginning with OpenShift 4.19, the minimum Trident version supported for this feature is 25.06.1.
k8sAPIQPS
The queries per second (QPS) limit used by the controller while communicating with the Kubernetes API server. The Burst value is set automatically based on the QPS value.
100; optional
enableConcurrency
Enables concurrent Trident controller operations for improved throughput.
Note Tech Preview: This feature is experimental in NetApp Trident 25.06 and currently supports limited parallel workflows with the ONTAP-SAN driver (iSCSI and FCP protocols).
false
Note For more information on formatting pod parameters, refer to Assigning Pods to Nodes.
Details about force detach
Force detach is available for ontap-san, ontap-san-economy, ontap-nas, and ontap-nas-economy only. Before enabling force detach, non-graceful node shutdown (NGNS) must be enabled on the Kubernetes cluster. NGNS is enabled by default for Kubernetes 1.28 and above. For more information, refer to Kubernetes: Non Graceful node shutdown.
Note When using the ontap-nas or ontap-nas-economy driver, you need to set the autoExportPolicy parameter in the backend configuration to true so that Trident can restrict access from the Kubernetes node with the taint applied using managed export policies.
Warning Because Trident relies on Kubernetes NGNS, do not remove out-of-service taints from an unhealthy node until all non-tolerable workloads are rescheduled. Recklessly applying or removing the taint can jeopardize backend data protection.
When the Kubernetes cluster administrator has applied the node.kubernetes.io/out-of-service=nodeshutdown:NoExecute taint to the node and enableForceDetach is set to true, Trident will determine the node status and:
  1. Cease backend I/O access for volumes mounted to that node.
  2. Mark the Trident node object as dirty (not safe for new publications).
    Note The Trident controller will reject new publish volume requests until the node is re-qualified (after having been marked as dirty) by the Trident node pod. Any workloads scheduled with a mounted PVC (even after the cluster node is healthy and ready) will be not be accepted until Trident can verify the node clean (safe for new publications).
When node health is restored and the taint is removed, Trident will:
  1. Identify and clean stale published paths on the node.
  2. If the node is in a cleanable state (the out-of-service taint has been removed and the node is in Ready state) and all stale, published paths are clean, Trident will readmit the node as clean and allow new published volumes to the node.
Sample configurations
You can use the attributes in Configuration options when defining TridentOrchestrator to customize your installation.
Basic custom configuration
This example, created after running the cat deploy/crds/tridentorchestrator_cr_imagepullsecrets.yaml command, represents a basic custom installation:
kind: TridentOrchestrator
metadata:
spec:
  debug: true
  namespace: trident
  imagePullSecrets:
  - thisisasecret
Node selectors
This example installs Trident with node selectors.
metadata:
spec:
  debug: true
  namespace: trident
  controllerPluginNodeSelector:
    nodetype: master
  nodePluginNodeSelector:
    storage: netapp
This example, created after running the cat deploy/crds/tridentorchestrator_cr.yaml command, installs Trident on a Windows worker node.
metadata:
spec:
  debug: true
  namespace: trident
  windows: true
Managed identities on an AKS cluster
This example installs Trident to enable managed identities on an AKS cluster.
metadata:
spec:
  debug: true
  namespace: trident
  cloudProvider: "Azure"
Cloud identity on an AKS cluster
This example installs Trident for use with a cloud identity on an AKS cluster.
metadata:
spec:
  debug: true
  namespace: trident
  cloudIdentity: 'azure.workload.identity/client-id: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx'
Cloud identity on an EKS cluster
metadata:
spec:
  debug: true
  namespace: trident
  cloudProvider: "AWS"
  cloudIdentity: "'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/trident-role'"
Cloud identity for GKE
This example installs Trident for use with a cloud identity on a GKE cluster.
kind: TridentBackendConfig
metadata:
spec:
  version: 1
  storageDriverName: google-cloud-netapp-volumes
  projectNumber: '012345678901'
  network: gcnv-network
  serviceLevel: Premium
  storagePool: pool-premium1
