Clone volumes across namespaces
Contributors netapp-aruldeepa
Using Trident, you can create new volumes using existing volumes or volumesnapshots from a different namespace inside the same Kubernetes cluster.
Prerequisites
Before cloning volumes, ensure that the source and destination backends are of the same type and have the same storage class.
Note Cloning across namespaces is supported only for the ontap-san and ontap-nas storage drivers. Read-only clones are not supported.
Quick start
You can set up volume cloning in just a few steps.
One Configure source PVC to clone the volume
The source namespace owner grants permission to access the data in the source PVC.
Two Grant permission to create a CR in the destination namespace
The cluster administrator grants permission to the owner of the destination namespace to create the TridentVolumeReference CR.
Three Create TridentVolumeReference in the destination namespace
The owner of the destination namespace creates the TridentVolumeReference CR to refer to the source PVC.
Four Create the clone PVC in the destination namespace
The owner of the destination namespace creates PVC to clone the PVC from the source namespace.
Configure the source and destination namespaces
To ensure security, cloning volumes across namespaces requires collaboration and action by the source namespace owner, cluster administrator, and destination namespace owner. The user role is designated in each step.
Steps
  1. Source namespace owner: Create the PVC (pvc1) in the source namespace (namespace1) that grants permission to share with the destination namespace (namespace2) using the cloneToNamespace annotation.
    kind: PersistentVolumeClaim
    apiVersion: v1
    metadata:
      namespace: namespace1
      annotations:
        trident.netapp.io/cloneToNamespace: namespace2
    spec:
      accessModes:
        - ReadWriteMany
      storageClassName: trident-csi
      resources:
        requests:
          storage: 100Gi
    Trident creates the PV and its backend storage volume.
    Note
    • You can share the PVC to multiple namespaces using a comma-delimited list. For example, trident.netapp.io/cloneToNamespace: namespace2,namespace3,namespace4.
    • You can share to all namespaces using *. For example, trident.netapp.io/cloneToNamespace: *
    • You can update the PVC to include the cloneToNamespace annotation at any time.
  2. Cluster admin: Ensure that proper RBAC is in place to grant permission to the destination namespace owner to create the TridentVolumeReference CR in the destination namespace (namespace2).
  3. Destination namespace owner: Create a TridentVolumeReference CR in the destination namespace that refers to the source namespace pvc1.
    kind: TridentVolumeReference
    metadata:
      namespace: namespace2
    spec:
      pvcName: pvc1
      pvcNamespace: namespace1
  4. Destination namespace owner: Create a PVC (pvc2) in destination namespace (namespace2) using the cloneFromPVC or cloneFromSnapshot, and cloneFromNamespace annotations to designate the source PVC.
    apiVersion: v1
    metadata:
      annotations:
        trident.netapp.io/cloneFromPVC: pvc1
        trident.netapp.io/cloneFromNamespace: namespace1
    spec:
      accessModes:
        - ReadWriteMany
      resources:
        requests:
          storage: 100Gi
Limitations
  • For PVCs provisioned using ontap-nas-economy drivers, read-only clones are not supported.
