Expand volumes
Contributors netapp-aruldeepa
Trident provides Kubernetes users the ability to expand their volumes after they are created. Find information about the configurations required to expand iSCSI, NFS, SMB, NVMe/TCP, and FC volumes.
Expand an iSCSI volume
You can expand an iSCSI Persistent Volume (PV) by using the CSI provisioner.
Note iSCSI volume expansion is supported by the ontap-san, ontap-san-economy, solidfire-san drivers and requires Kubernetes 1.16 and later.
Step 1: Configure the StorageClass to support volume expansion
Edit the StorageClass definition to set the allowVolumeExpansion field to true.
cat storageclass-ontapsan.yaml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-san"
allowVolumeExpansion: True
For an already existing StorageClass, edit it to include the allowVolumeExpansion parameter.
Step 2: Create a PVC with the StorageClass you created
Edit the PVC definition and update the spec.resources.requests.storage to reflect the newly desired size, which must be greater than the original size.
cat pvc-ontapsan.yaml
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
  storageClassName: ontap-san
Trident creates a Persistent Volume (PV) and associates it with this Persistent Volume Claim (PVC).
kubectl get pvc
NAME      STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
san-pvc   Bound    pvc-8a814d62-bd58-4253-b0d1-82f2885db671   1Gi        RWO            ontap-san      8s
kubectl get pv
NAME                                       CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS   CLAIM             STORAGECLASS   REASON   AGE
pvc-8a814d62-bd58-4253-b0d1-82f2885db671   1Gi        RWO            Delete           Bound    default/san-pvc   ontap-san               10s
Step 3: Define a pod that attaches the PVC
Attach the PV to a pod for it to be resized. There are two scenarios when resizing an iSCSI PV:
  • If the PV is attached to a pod, Trident expands the volume on the storage backend, rescans the device, and resizes the filesystem.
  • When attempting to resize an unattached PV, Trident expands the volume on the storage backend. After the PVC is bound to a pod, Trident rescans the device and resizes the filesystem. Kubernetes then updates the PVC size after the expand operation has successfully completed.
In this example, a pod is created that uses the san-pvc.
 kubectl get pod
NAME         READY   STATUS    RESTARTS   AGE
ubuntu-pod   1/1     Running   0          65s
 kubectl describe pvc san-pvc
Namespace:     default
StorageClass:  ontap-san
Status:        Bound
Volume:        pvc-8a814d62-bd58-4253-b0d1-82f2885db671
Labels:        <none>
Annotations:   pv.kubernetes.io/bind-completed: yes
               pv.kubernetes.io/bound-by-controller: yes
               volume.beta.kubernetes.io/storage-provisioner: csi.trident.netapp.io
Finalizers:    [kubernetes.io/pvc-protection]
Capacity:      1Gi
Access Modes:  RWO
VolumeMode:    Filesystem
Mounted By:    ubuntu-pod
Step 4: Expand the PV
To resize the PV that has been created from 1Gi to 2Gi, edit the PVC definition and update the spec.resources.requests.storage to 2Gi.
kubectl edit pvc san-pvc
# Please edit the object below. Lines beginning with a '#' will be ignored,
# and an empty file will abort the edit. If an error occurs while saving this file will be
# reopened with the relevant failures.
apiVersion: v1
metadata:
  annotations:
    pv.kubernetes.io/bind-completed: "yes"
    pv.kubernetes.io/bound-by-controller: "yes"
  creationTimestamp: "2019-10-10T17:32:29Z"
  finalizers:
  - kubernetes.io/pvc-protection
  namespace: default
  resourceVersion: "16609"
  selfLink: /api/v1/namespaces/default/persistentvolumeclaims/san-pvc
  uid: 8a814d62-bd58-4253-b0d1-82f2885db671
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 2Gi
Step 5: Validate the expansion
You can validate the expansion worked correctly by checking the size of the PVC, PV, and the Trident volume:
kubectl get pvc san-pvc
san-pvc   Bound    pvc-8a814d62-bd58-4253-b0d1-82f2885db671   2Gi        RWO            ontap-san      11m
kubectl get pv
pvc-8a814d62-bd58-4253-b0d1-82f2885db671   2Gi        RWO            Delete           Bound    default/san-pvc   ontap-san               12m
tridentctl get volumes -n trident
|                   NAME                   |  SIZE   | STORAGE CLASS | PROTOCOL |             BACKEND UUID             | STATE  | MANAGED |
| pvc-8a814d62-bd58-4253-b0d1-82f2885db671 | 2.0 GiB | ontap-san     | block    | a9b7bfff-0505-4e31-b6c5-59f492e02d33 | online | true    |
Expand an FC volume
You can expand an FC Persistent Volume (PV) by using the CSI provisioner.
Note FC volume expansion is supported by the ontap-san driver and requires Kubernetes 1.16 and later.
kind: StorageClass
metadata:
parameters:
apiVersion: v1
metadata:
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
kubectl get pvc
kubectl get pv
Attach the PV to a pod for it to be resized. There are two scenarios when resizing an FC PV:
 kubectl get pod
Namespace:     default
Status:        Bound
Labels:        <none>
Capacity:      1Gi
Access Modes:  RWO
apiVersion: v1
metadata:
  annotations:
  finalizers:
  namespace: default
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 2Gi
kubectl get pv
Expand an NFS volume
Trident supports volume expansion for NFS PVs provisioned on ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, gcp-cvs, and azure-netapp-files backends.
To resize an NFS PV, the admin first needs to configure the storage class to allow volume expansion by setting the allowVolumeExpansion field to true:
cat storageclass-ontapnas.yaml
kind: StorageClass
metadata:
parameters:
  backendType: ontap-nas
allowVolumeExpansion: true
If you have already created a storage class without this option, you can simply edit the existing storage class by using kubectl edit storageclass to allow volume expansion.
cat pvc-ontapnas.yaml
apiVersion: v1
metadata:
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 20Mi
  storageClassName: ontapnas
Trident should create a 20 MiB NFS PV for this PVC:
kubectl get pvc
ontapnas20mb   Bound    pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7   20Mi         RWO            ontapnas        9s
kubectl get pv pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7
pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7   20Mi       RWO            Delete           Bound    default/ontapnas20mb   ontapnas                 2m42s
Step 3: Expand the PV
To resize the newly created 20 MiB PV to 1 GiB, edit the PVC and set spec.resources.requests.storage to 1 GiB:
kubectl edit pvc ontapnas20mb
apiVersion: v1
metadata:
  annotations:
  creationTimestamp: 2018-08-21T18:26:44Z
  finalizers:
  namespace: default
  resourceVersion: "1958015"
  selfLink: /api/v1/namespaces/default/persistentvolumeclaims/ontapnas20mb
  uid: c1bd7fa5-a56f-11e8-b8d7-fa163e59eaab
spec:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
Step 4: Validate the expansion
You can validate the resize worked correctly by checking the size of the PVC, PV, and the Trident volume:
kubectl get pvc ontapnas20mb
ontapnas20mb   Bound    pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7   1Gi        RWO            ontapnas        4m44s
pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7   1Gi        RWO            Delete           Bound    default/ontapnas20mb   ontapnas                 5m35s
tridentctl get volume pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7 -n trident
| pvc-08f3d561-b199-11e9-8d9f-5254004dfdb7 | 1.0 GiB | ontapnas      | file     | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true    |
