Manually deploy the Trident operator (Offline mode)
You can manually deploy the Trident operator to install Trident. This process applies to installations where the container images required by Trident are stored in a private registry. If you do not have a private image registry, use the process for standard deployment.
Critical information about Trident10
You must read the following critical information about Trident.
  • Kubernetes 1.34 is now supported in Trident. Upgrade Trident prior to upgrading Kubernetes.
  • Trident strictly enforces the use of multipathing configuration in SAN environments, with a recommended value of find_multipaths: no in multipath.conf file.
    Use of non-multipathing configuration or use of find_multipaths: yes or find_multipaths: smart value in multipath.conf file will result in mount failures. Trident has recommended the use of find_multipaths: no since the 21.07 release.
Manually deploy the Trident operator and install Trident
Review the installation overview to ensure you've met installation prerequisites and selected the correct installation option for your environment.
Before you begin
Log in to the Linux host and verify it is managing a working and supported Kubernetes cluster and that you have the necessary privileges.
Note With OpenShift, use oc instead of kubectl in all of the examples that follow, and log in as system:admin first by running oc login -u system:admin or oc login -u kube-admin.
Details
  1. Verify your Kubernetes version:
    kubectl version
  2. Verify cluster administrator privileges:
    kubectl auth can-i '*' '*' --all-namespaces
  3. Verify you can launch a pod that uses an image from Docker Hub and reach your storage system over the pod network:
    kubectl run -i --tty ping --image=busybox --restart=Never --rm -- \
      ping <management IP>
Step 1: Download the Trident installer package
The Trident installer package contains everything you need to deploy the Trident operator and install Trident. Download and extract the latest version of the Trident installer from the Assets section on GitHub.
wget https://github.com/NetApp/trident/releases/download/v6.0/trident-installer-25.10.0.tar.gz
tar -xf trident-installer-25.10.0.tar.gz
cd trident-installer
Step 2: Create the TridentOrchestrator CRD
Create the TridentOrchestrator Custom Resource Definition (CRD). You will create a TridentOrchestrator Custom Resources later. Use the appropriate CRD YAML version in deploy/crds to create the TridentOrchestrator CRD:
kubectl create -f deploy/crds/<VERSION>.yaml
Step 3: Update the registry location in the operator
In /deploy/operator.yaml, update image: docker.io/netapp/trident-operator:25.10.0 to reflect the location of your image registry. Your Trident and CSI images can be located in one registry or different registries, but all CSI images must be located in the same registry. For example:
  • image: <your-registry>/trident-operator:25.10.0 if your images are all located in one registry.
  • image: <your-registry>/netapp/trident-operator:25.10.0 if your Trident image is located in a different registry from your CSI images.
Step 4: Deploy the Trident operator
The Trident installer provides a bundle file that can be used to install the operator and create associated objects. The bundle file is an easy way to deploy the operator and install Trident using a default configuration.
  • For clusters running Kubernetes 1.24, use bundle_pre_1_25.yaml.
  • For clusters running Kubernetes 1.25 or later, use bundle_post_1_25.yaml.
Before you begin
  • By default, the Trident installer deploys the operator in the trident namespace. If the trident namespace does not exist, create it using:
    kubectl apply -f deploy/namespace.yaml
  • To deploy the operator in a namespace other than the trident namespace, update serviceaccount.yaml, clusterrolebinding.yaml and operator.yaml and generate your bundle file using the kustomization.yaml.
    1. Create the kustomization.yaml using the following command where <bundle.yaml> is bundle_pre_1_25.yaml or bundle_post_1_25.yaml based on your Kubernetes version.
      cp deploy/kustomization_<bundle.yaml> deploy/kustomization.yaml
    2. Compile the bundle using using the following command where <bundle.yaml> is bundle_pre_1_25.yaml or bundle_post_1_25.yaml based on your Kubernetes version.
      kubectl kustomize deploy/ > deploy/<bundle.yaml>
Steps
  1. Create the resources and deploy the operator:
    kubectl create -f deploy/<bundle.yaml>
  2. Verify the operator, deployment, and replicasets were created.
    kubectl get all -n <operator-namespace>
Important There should only be one instance of the operator in a Kubernetes cluster. Do not create multiple deployments of the Trident operator.
Step 5: Update the image registry location in the TridentOrchestrator
Your Trident and CSI images can be located in one registry or different registries, but all CSI images must be located in the same registry. Update deploy/crds/tridentorchestrator_cr.yaml to add the additional location specs based on your registry configuration.
Images in one registry
imageRegistry: "<your-registry>"
autosupportImage: "<your-registry>/trident-autosupport:25.10"
tridentImage: "<your-registry>/trident:25.10.0"
Images in different registries
Step 6: Create the TridentOrchestrator and install Trident
You can now create the TridentOrchestrator and install Trident. Optionally, you can further customize your Trident installation using the attributes in the TridentOrchestrator spec. The following example shows an installation where Trident and CSI images are located in different registries.
kubectl create -f deploy/crds/tridentorchestrator_cr.yaml
tridentorchestrator.trident.netapp.io/trident created
kubectl describe torc trident
Namespace:
Labels:      <none>
Annotations: <none>
API Version: trident.netapp.io/v1
Kind:        TridentOrchestrator
Spec:
  Autosupport Image:  <your-registry>/trident-autosupport:25.10
  Debug:              true
  Image Registry:     <your-registry>
  Namespace:          trident
  Trident Image:      <your-registry>/trident:25.10.0
Status:
  Current Installation Params:
    IPv6:                       false
    Autosupport Hostname:
    Autosupport Proxy:
    Autosupport Serial Number:
    Debug:                      true
    Http Request Timeout:       90s
    Image Pull Secrets:
    k8sTimeout:           30
    Kubelet Dir:          /var/lib/kubelet
    Log Format:           text
    Probe Port:           17546
    Silence Autosupport:  false
  Message:                Trident installed
  Namespace:              trident
  Status:                 Installed
  Version:                v25.10.0
Events:
    Type Reason Age From Message ---- ------ ---- ---- -------Normal
    Installing 74s trident-operator.netapp.io Installing Trident Normal
    Installed 67s trident-operator.netapp.io Trident installed
Verify the installation
There are several ways to verify your installation.
Using TridentOrchestrator status
The status of TridentOrchestrator indicates if the installation was successful and displays the version of Trident installed. During the installation, the status of TridentOrchestrator changes from Installing to Installed. If you observe the Failed status and the operator is unable to recover by itself, check the logs.
Status Description
Installing
The operator is installing Trident using this TridentOrchestrator CR.
Installed
Trident has successfully installed.
Uninstalling
The operator is uninstalling Trident, because
spec.uninstall=true.
Uninstalled
Trident is uninstalled.
Failed
The operator could not install, patch, update or uninstall
Trident; the operator will automatically try to recover from this state. If this state persists you will require troubleshooting.
Updating
The operator is updating an existing installation.
The TridentOrchestrator is not used. Another one already
exists.
Using pod creation status
You can confirm if the Trident installation completed by reviewing the status of the created pods:
kubectl get pods -n trident
NAME                                       READY   STATUS    RESTARTS   AGE
trident-controller-7d466bf5c7-v4cpw        6/6     Running   0           1m
trident-node-linux-mr6zc                   2/2     Running   0           1m
trident-node-linux-xrp7w                   2/2     Running   0           1m
trident-node-linux-zh2jt                   2/2     Running   0           1m
trident-operator-766f7b8658-ldzsv          1/1     Running   0           3m
Using tridentctl
You can use tridentctl to check the version of Trident installed.
./tridentctl -n trident version
| SERVER VERSION | CLIENT VERSION |
| 25.10.0        | 25.10.0        |
