Install the Trident Protect CLI plugin
You can use the Trident Protect command line plugin, which is an extension of the Trident tridentctl utility, to create and interact with Trident Protect custom resources (CRs).
Before using the command line utility, you need to install it on the machine you use to access your cluster. Follow these steps, depending on if your machine uses an x64 or ARM CPU.
Download plugin for Linux AMD64 CPUs
Steps
  1. Download the Trident Protect CLI plugin:
    curl -L -o tridentctl-protect https://github.com/NetApp/tridentctl-protect/releases/download/25.10.0/tridentctl-protect-linux-amd64
Download plugin for Linux ARM64 CPUs
Steps
    curl -L -o tridentctl-protect https://github.com/NetApp/tridentctl-protect/releases/download/25.10.0/tridentctl-protect-linux-arm64
Download plugin for Mac AMD64 CPUs
Steps
    curl -L -o tridentctl-protect https://github.com/NetApp/tridentctl-protect/releases/download/25.10.0/tridentctl-protect-macos-amd64
Download plugin for Mac ARM64 CPUs
Steps
    curl -L -o tridentctl-protect https://github.com/NetApp/tridentctl-protect/releases/download/25.10.0/tridentctl-protect-macos-arm64
  1. Enable execute permissions for the plugin binary:
    chmod +x tridentctl-protect
  2. Copy the plugin binary to a location that is defined in your PATH variable. For example, /usr/bin or /usr/local/bin (you might need elevated privileges):
    cp ./tridentctl-protect /usr/local/bin/
  3. Optionally, you can copy the plugin binary to a location in your home directory. In this case, it is recommended to ensure the location is part of your PATH variable:
    cp ./tridentctl-protect ~/bin/
Note Copying the plugin to a location in your PATH variable enables you to use the plugin by typing tridentctl-protect or tridentctl protect from any location.
View Trident CLI plugin help
You can use the built-in plugin help features to get detailed help on the capabilities of the plugin:
Steps
  1. Use the help function to view usage guidance:
    tridentctl-protect help
Enable command auto-completion
After you have installed the Trident Protect CLI plugin, you can enable auto-completion for certain commands.
Enable auto-completion for the Bash shell
Steps
  1. Create the completion script:
    tridentctl-protect completion bash > tridentctl-completion.bash
  2. Make a new directory in your home directory to contain the script:
    mkdir -p ~/.bash/completions
  3. Move the downloaded script to the ~/.bash/completions directory:
    mv tridentctl-completion.bash ~/.bash/completions/
  4. Add the following line to the ~/.bashrc file in your home directory:
    source ~/.bash/completions/tridentctl-completion.bash
Enable auto-completion for the Z shell
Steps
    tridentctl-protect completion zsh > tridentctl-completion.zsh
    mkdir -p ~/.zsh/completions
  3. Move the downloaded script to the ~/.zsh/completions directory:
    mv tridentctl-completion.zsh ~/.zsh/completions/
  4. Add the following line to the ~/.zprofile file in your home directory:
    source ~/.zsh/completions/tridentctl-completion.zsh
Result
Upon your next shell login, you can use command auto-completion with the tridentctl-protect plugin.
