Deploy sample application
When the storage class and PVC are created, you can mount the PV to a pod. This section lists the example command and configuration to attach the PV to a pod.
Steps
  1. Mount the volume in a pod.
    kubectl create -f pv-pod.yaml
    These examples show basic configurations to attach the PVC to a pod:
    Basic configuration:
    kind: Pod
    apiVersion: v1
    metadata:
    spec:
      volumes:
        - name: pv-storage
          persistentVolumeClaim:
           claimName: basic
      containers:
        - name: pv-container
          image: nginx
          ports:
            - containerPort: 80
          volumeMounts:
            - mountPath: "/my/mount/path"
    Note You can monitor the progress using kubectl get pod --watch.
  2. Verify that the volume is mounted on /my/mount/path.
    kubectl exec -it pv-pod -- df -h /my/mount/path
Filesystem                                                        Size  Used  Avail Use%  Mounted on
192.168.188.78:/trident_pvc_ae45ed05_3ace_4e7c_9080_d2a83ae03d06  1.1G  320K  1.0G   1%   /my/mount/path
You can now delete the Pod. The Pod application will no longer exist, but the volume will remain.
kubectl delete pod pv-pod
