Automatic volume expansion
Automatic volume expansion enables Persistent Volumes provisioned by Trident to grow automatically when used capacity reaches a defined threshold. This capability reduces operational overhead and helps prevent application disruption caused by capacity exhaustion. Automatic volume expansion is implemented using Autogrow Policies. An Autogrow Policy defines:
  • The utilization threshold that triggers expansion
  • The amount by which the volume grows
  • The maximum size the volume can reach
Note Volumes increase in size automatically when the defined utilization threshold is exceeded. Volumes are never automatically reduced.
Requirements
Before configuring automatic volume expansion, ensure that the following requirements are met:
  • Trident 26.02 or later
  • Role-based access control permissions to create TridentAutogrowPolicy custom resources
  • StorageClasses configured with allowVolumeExpansion: true
  • Supported ONTAP protocols:
    • Network File System (NFS)
    • Internet Small Computer Systems Interface (iSCSI)
    • Non-Volatile Memory Express (NVMe)
    • Fibre Channel Protocol (FCP)
Limitations
  • ONTAP Non-Volatile Memory Express raw block volumes earlier than ONTAP 9.16.1 do not support automatic expansion.
  • For storage area network volumes, if growthAmount is less than or equal to 50 mebibytes, Trident automatically increases the value to 51 mebibytes before resizing, provided the resulting size does not exceed maxSize.
  • In brownfield environments, automatic expansion might not function for certain existing volumes due to volume publication migration behavior.
  • When a volume reaches maxSize, no further expansion occurs.
  • Supported protocols for automatic volume expansion:
Provision Volumes with Autogrow Policy
Autogrow Policy can be configured at two levels:
  • Storage class level: Sets default for all volumes (using annotation)
  • PVC level: Overrides storage class default (using annotation)
Create an Autogrow Policy
Autogrow Policies enable automatic volume expansion when volumes reach a defined capacity threshold.
Ensure you have:
  • Trident 26.02 or later installed
  • Role-based access control permissions to create TridentAutogrowPolicy resources
  • Understanding of workload growth requirements
An Autogrow Policy defines how volumes expand automatically when they reach a defined capacity threshold.
You can create Autogrow Policies at any point in your workflow:
  • Before StorageClasses and volumes are created
  • After StorageClasses exist
  • After volumes are provisioned
This flexibility allows you to introduce automatic expansion without recreating existing resources.
Autogrow Policy specifications
Autogrow Policies are Kubernetes custom resources defined as follows:
Field Description Format Required Example Default
name
Unique policy identifier
String
Yes
production-db-policy
None
usedThreshold
Capacity percentage that triggers expansion
Percentage string
Yes
"80%"
None
growthAmount
Amount to grow when threshold is reached
Percentage or size
No
"10%" or "5Gi"
"10%"
maxSize
Maximum volume size limit
Kubernetes quantity
No
"500Gi"
Unlimited
Steps
  1. Create a YAML file that defines your Autogrow Policy:
    kind: TridentAutogrowPolicy
    metadata:
    spec:
      usedThreshold: "80%"
      growthAmount: "10%"
      maxSize: "500Gi"
  2. Apply the policy to your cluster:
    kubectl apply -f autogrow-policy.yaml
  3. Verify that the policy was created:
    kubectl get tridentautogrowpolicy standard-autogrow
    Expected output
    NAME                USED THRESHOLD   GROWTH AMOUNT   STATE
    standard-autogrow   80%              10%             Success
Policy states
After you create a policy, Trident validates the specification and assigns one of the following states:
State Description Action required
Success
Policy is validated and ready to use.
None.
Failed
Validation errors detected.
Review and fix the specification.
Deleting
Deletion is in progress.
Wait for completion.
Associate a policy with a StorageClass
You can associate an Autogrow Policy with a StorageClass by using the trident.netapp.io/autogrowPolicy annotation. All volumes provisioned from that StorageClass inherit the policy.
Note The StorageClass must have allowVolumeExpansion: true.
Steps
  1. Create or modify a StorageClass with the Autogrow Policy annotation:
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    metadata:
      annotations:
        trident.netapp.io/autogrowPolicy: "production-db-policy"
    parameters:
      backendType: "ontap-san"
      fsType: "ext4"
  2. Apply the StorageClass:
    kubectl apply -f storageclass.yaml
  3. Verify the annotation:
    kubectl get storageclass ontap-gold -o jsonpath='{.metadata.annotations.trident\.netapp\.io/autogrowPolicy}'
    Expected output
Policy precedence
When Autogrow Policy annotations are set on both a StorageClass and a PVC, Trident applies the following precedence rules:
  1. PVC annotation takes priority. If a PVC sets trident.netapp.io/autogrowPolicy, that value is always used.
  2. StorageClass annotation applies only when the PVC has no annotation.
  3. If neither has the annotation, no Autogrow Policy is applied.
Table 1. Precedence examples
StorageClass annotation PVC annotation Effective behavior
trident.netapp.io/autogrowPolicy: standard-agp
Not set
Uses standard-agp.
trident.netapp.io/autogrowPolicy: logs-policy
Uses logs-policy (PVC overrides StorageClass).
trident.netapp.io/autogrowPolicy: "none"
No Autogrow Policy (PVC disables autogrow).
Not set
trident.netapp.io/autogrowPolicy: dev-policy
Uses dev-policy.
Not set
Not set
No Autogrow Policy.
Configuration examples
The following examples show common Autogrow Policy configurations for different use cases.
Conservative policy for production databases
metadata:
spec:
  usedThreshold: "75%"
  growthAmount: "20%"
  maxSize: "5Ti"
Log storage with fixed growth increments
metadata:
spec:
  usedThreshold: "90%"
  growthAmount: "10Gi"
  maxSize: "100Gi"
Minimal policy with defaults
When you omit growthAmount and maxSize, Trident uses the defaults (10% growth, unlimited size):
metadata:
spec:
  usedThreshold: "85%"
Policy with a custom maxSize and default growthAmount
metadata:
spec:
  usedThreshold: "70%"
  maxSize: "100Gi"
Aggressive growth with unlimited maxSize
metadata:
spec:
  growthAmount: "150%"
Policy with fractional percentages
metadata:
spec:
  usedThreshold: "80.28%"
  growthAmount: "10.65%"
  maxSize: "100Gi"
Note Fractional percentages are supported. If you specify more than three decimal places, Trident rounds the value to three decimal places.
NAS StorageClass with Autogrow
kind: StorageClass
metadata:
  annotations:
    trident.netapp.io/autogrowPolicy: "standard-autogrow"
parameters:
  backendType: "ontap-nas"
  fsType: "ext4"
SAN StorageClass with Autogrow
kind: StorageClass
metadata:
  annotations:
parameters:
  fsType: "ext4"
