Configure a PVC
This sections includes instructions on how to create a PersistentVolumeClaim (PVC) that uses the configured Kubernetes StorageClass to request a PV.
If successful, you can then mount the PV to a pod.
Create the PVC
A PersistentVolumeClaim (PVC) is a request for access to the PersistentVolume on the cluster. The PVC can be configured to request storage of a certain size or access mode. Using the associated StorageClass, the cluster administrator can control more than PersistentVolume size and access mode—​such as performance or service level.
After you create the Trident backend and StorageClass you can create a PVC. After the PVC is created, you can mount the volume in a pod.
Sample manifests
The following examples show basic PVC configuration options.
PVC with RWX access
This example shows a basic PVC with RWX access that is associated with a StorageClass named basic-csi.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 1Gi
  storageClassName: ontap-gold
PVC using iSCSI example
This example shows a basic PVC for iSCSI with RWO access that is associated with a StorageClass named protection-gold.
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
  storageClassName: protection-gold
Create PVC
Steps
  1. Create the PVC.
    kubectl create -f pvc.yaml
  2. Verify the PVC status.
    kubectl get pvc
NAME        STATUS VOLUME     CAPACITY ACCESS MODES STORAGECLASS AGE
pvc-storage Bound  pv-name 2Gi      RWO                       5m
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Trident provisions volumes.
