Controller scalability
Trident improves controller scalability through increased concurrency across multiple storage drivers. When you enable controller scalability, the Trident controller processes storage operations in parallel instead of serializing them, which increases throughput in Kubernetes environments with many concurrent operations.
Before you deploy, determine which Trident drivers support controller scalability at general availability and which drivers are available as a technical preview in Trident 26.06. This helps you make informed deployment decisions and manage risk. Controller scalability is disabled by default.
Key concepts and definitions
Controller scalability refers to the Trident controller's ability to process multiple storage operations in parallel rather than serializing them behind a single lock. These operations include volume creation, deletion, and resizing; snapshot creation and deletion; volume publish and unpublish; and backend management.
When you enable controller scalability, operations on different volumes and backends proceed concurrently. This increases throughput and reduces end-to-end operation time in environments with high numbers of concurrent PersistentVolumeClaim and VolumeSnapshot operations.
Default behavior (serial mode)
By default, the Trident controller processes operations one at a time. Each create, delete, resize, or snapshot request completes before Trident starts the next one. Serial mode is the supported default for all installations and requires no configuration.
Serial mode is sufficient for most workloads. Enable controller scalability only when operation volume creates a backlog under serial processing.
Controller scalability support
Trident supports controller scalability at different maturity levels for different storage drivers.
General availability
The following drivers support controller scalability at general availability in Trident 26.06:
  • ontap-san
  • ontap-nas
  • ontap-nas-economy
  • ontap-san-economy
  • google-cloud-netapp-volumes
  • azure-netapp-files
  • solidfire-san
Note
The google-cloud-netapp-volumes and google-cloud-netapp-volumes-san drivers are different. Trident supports only google-cloud-netapp-volumes. Do not use google-cloud-netapp-volumes-san in backend configurations or examples.
Technical preview
The following driver supports controller scalability as a technical preview feature in Trident 26.06:
  • asa-r2 (SAN and NVMe)
This driver has the following limitations:
  • Controller concurrency is available for evaluation and testing only.
  • Behavior can change from one release to the next.
  • NetApp does not recommend use in production environments.
How enableConcurrency works
When you set enableConcurrency to true, Trident applies concurrent processing across all backends that the controller manages. The setting applies to every backend at once. You cannot enable it for individual backends or individual drivers.
Every configured backend must use a driver in the general availability or technical preview list. If any backend uses an unsupported driver, Trident does not start, and Trident does not add a backend that uses an unsupported driver.
To restore startup, remove or reconfigure any backend that uses an unsupported driver, or disable controller scalability.
Before you enable
Important
Before you enable controller scalability, confirm that every configured backend uses a driver in the general availability or technical preview list. If any backend uses an unsupported driver, Trident does not start after you enable the feature.
Use the following table to decide whether to enable controller scalability.
If your environment Then
Uses only supported drivers and experiences a backlog of controller operations
Enable controller scalability.
Uses any unsupported driver
Keep the default serial mode. Do not enable controller scalability.
Handles low operation volume with no backlog
The enableConcurrency configuration option controls controller scalability. You must explicitly enable this option during Trident installation, or when you update an existing deployment.
Trident operator deployment
To enable controller scalability with the Trident operator, set enableConcurrency to true in the TridentOrchestrator custom resource (CR).
New installation
Create or edit the TridentOrchestrator CR and set enableConcurrency to true:
kind: TridentOrchestrator
metadata:
spec:
  namespace: trident
  enableConcurrency: true
Apply the CR:
kubectl apply -f tridentorchestrator_cr.yaml
Existing installation
Patch the existing TridentOrchestrator CR to enable controller scalability:
kubectl patch torc trident --type=merge -p '{"spec":{"enableConcurrency":true}}'
Verify that Trident applied the setting:
kubectl get torc trident -o jsonpath='{.status.currentInstallationParams.enableConcurrency}'
Helm deployment
To enable controller scalability with Helm, set the enableConcurrency value to true.
New installation
helm install trident netapp-trident/trident-operator --namespace trident --create-namespace --set enableConcurrency=true
helm upgrade trident netapp-trident/trident-operator --namespace trident --set enableConcurrency=true
Alternatively, set enableConcurrency to true in a custom values.yaml file:
# values.yaml
Then install or upgrade with the values file:
helm install trident netapp-trident/trident-operator --namespace trident --create-namespace -f values.yaml
tridentctl deployment
To enable controller scalability with tridentctl, pass the --enable-concurrency flag during installation.
New installation
tridentctl install -n trident --enable-concurrency
To enable controller scalability on an existing tridentctl deployment, uninstall Trident and reinstall it with the flag:
tridentctl uninstall -n trident
Verify that controller scalability is enabled
After you enable controller scalability, verify that the Trident controller runs with concurrency enabled. Check the controller pod logs:
kubectl logs -n trident deploy/trident-controller | grep -i concurrency
The output includes a log entry that confirms concurrency is enabled.
Concurrency behavior
When controller scalability is enabled, the Trident controller applies the following behavior:
  • Trident replaces the single global lock with fine-grained, per-resource locking.
  • Trident serializes operations that modify the same resource to maintain data consistency.
  • Operations that only read from a resource proceed concurrently with other read operations on that resource.
  • Trident limits concurrent ONTAP API requests to 20 per management LIF to prevent overload of backend storage systems.
  • If multiple backends share the same management LIF, they share this 20-request limit.
Caveats and limitations
The following considerations apply to controller scalability in Trident 26.06:
  • Controller scalability supports only the drivers in the general availability and technical preview lists. For details, see Before you enable.
  • The Trident controller manages concurrency internally. This release provides no user-configurable concurrency limits.
  • Overall throughput depends on the storage driver in use, backend responsiveness, and Kubernetes API server performance.
  • High concurrency can increase load on backend storage systems.
  • Controller scalability behavior is not identical across all drivers.
  • The technical preview driver can exhibit inconsistent performance under high load and can change behavior between releases.
  • Debugging concurrent operations can be more complex because of parallel execution. Metrics and logs can show interleaved operation output.
Recommendations
Before you enable controller scalability, complete the following steps:
  1. Confirm that every configured backend uses a driver in the general availability or technical preview list.
  2. Test the change in a non-production cluster before you apply it in production.
  3. Verify that controller scalability is enabled after you apply the change.
Apply the following general recommendations when you operate with controller scalability:
  • Use general availability drivers for production environments that require high scalability.
  • Evaluate the technical preview driver only in non-production environments.
  • Monitor backend and controller performance when you operate at scale.
  • Do not assume operation ordering in automation scripts.
