Configure Google Cloud NetApp Volumes ONTAP-mode storage pools
Beginning with Trident 26.06, you can configure existing ontap-san and ontap-nas backends to provision storage on Google Cloud NetApp Volumes (GCNV) ONTAP-mode storage pools. This feature is a Tech Preview.
Note
This feature is a Tech Preview in Trident 26.06. Tech Preview features are not supported for production use. The functionality, configuration fields, and supported matrix can change before general availability (GA).
How it works
Trident reuses the existing ontap-san and ontap-nas driver logic and routes ONTAP REST calls through a GCNV proxy endpoint. This approach lets you provision and manage storage on GCNV-hosted ONTAP clusters while keeping the same operational workflows that you use for a direct ONTAP backend. ONTAP-mode does not introduce a new storage driver. You enable it per backend by adding a gcnv configuration block to an ontap-san or ontap-nas backend.
The provisioning path is as follows:
PersistentVolumeClaim → Trident (ontap-san or ontap-nas) → ONTAP REST client → GCNV proxy → ONTAP cluster in the GCNV pool
Supported and unsupported scope
This Tech Preview supports the following:
  • Drivers: ontap-san (iSCSI) and ontap-nas (NFS or SMB).
  • Lifecycle operations through the proxy: backend initialization, volume creation and deletion, and related ONTAP REST flows.
  • Authentication models: Workload Identity Pool (WIP), service account key, and Application Default Credentials (ADC) fallback.
The following are out of scope for this Tech Preview:
  • The ontap-san-economy, ontap-nas-economy, and ontap-nas-flexgroup drivers.
  • The ASA r2 personality path.
  • ZAPI fallback. ONTAP-mode uses ONTAP REST only.
Prerequisites
Before you configure an ONTAP-mode backend, ensure that you have the following:
  • Trident 26.06 or later.
  • A GCNV ONTAP-mode storage pool in your target project and location.
  • GCP IAM permissions for proxy operations, scoped appropriately for your environment.
  • A backend configuration that includes proxyURL, projectNumber, location, and poolID.
  • For iSCSI SAN workflows, the node-side iSCSI and multipath prerequisites for your platform. Refer to Prepare the worker node.
Configure the backend
A TridentBackendConfig requires credentials. For ONTAP-mode, that secret holds GCP proxy credentials—not ONTAP managementLIF / username / password. svm is optional: each GCNV ONTAP-mode pool currently has one SVM, and Trident derives it from the pool when omitted.
Use the same service account pattern as native GCNV: non-sensitive fields in gcnv.apiKey, private_key and private_key_id in the secret. See Google Cloud NetApp Volumes configuration examples.
ontap-san backend
kind: TridentBackendConfig
metadata:
  namespace: trident
spec:
  version: 1
  storageDriverName: ontap-san
  backendName: gcnv-ontap-san
  credentials:
    type: secret
  gcnv:
    proxyURL: "https://netapp.googleapis.com"
    projectNumber: "<project-number>"
    poolID: "<pool-id>"
  svm: "<svm-name>"
ontap-nas backend
metadata:
  namespace: trident
spec:
  version: 1
  storageDriverName: ontap-nas
  backendName: gcnv-ontap-nas
  credentials:
    type: secret
  gcnv:
    poolID: "<pool-id>"
    apiKey:
      type: service_account
      project_id: "<project-id>"
      client_email: "<service-account-email>"
      client_id: "<client-id>"
      auth_uri: "https://accounts.google.com/o/oauth2/auth"
      token_uri: "https://oauth2.googleapis.com/token"
      auth_provider_x509_cert_url: "https://www.googleapis.com/oauth2/v1/certs"
      client_x509_cert_url: "<client-x509-cert-url>"
Secret
apiVersion: v1
kind: Secret
metadata:
  namespace: trident
type: Opaque
stringData:
  private_key_id: "<private-key-id>"
  private_key: |
    -----BEGIN PRIVATE KEY-----
    <private-key>
    -----END PRIVATE KEY-----
Note
Do not put private_key or private_key_id in the TridentBackendConfig spec—the CRD rejects them. Use ontap-san with the same gcnv and credential pattern for block storage.
svm: "<svm-name>"
== Authentication
Trident resolves credentials for proxy access in the following order:
. Workload Identity Pool (WIP)
. Service account key
. Application Default Credentials (ADC)
For this Tech Preview, use the following practices:
* Prefer Workload Identity Pool where it is available.
* Do not embed raw private keys in version-controlled backend files. Store credentials in a Kubernetes secret.
* Apply least-privilege IAM scoping to the service account.
== Validation and initialization behavior
Trident validates an ONTAP-mode backend during initialization and fails fast rather than partially initializing.
Backend initialization fails if a required `gcnv` field is missing, the driver is unsupported for ONTAP-mode, or credential resolution fails.
== Known limitations
* This feature is a Tech Preview. Behavior and the supported matrix can change before GA.
* ZAPI fallback is not used in ONTAP-mode.
* Protocol and node-readiness requirements still apply. For example, iSCSI workflows require the node-side prerequisites described in link:../trident-use/worker-node-prep.html[Prepare the worker node].
* Existing ONTAP and GCNV environment constraints still apply.
== Upgrade and compatibility
ONTAP-mode is opt-in per backend through the `gcnv` configuration block:
* Existing non-GCNV ONTAP backends are unaffected.
* Mixed deployments that combine direct ONTAP backends and ONTAP-mode proxy backends are supported through backend-level configuration. Each backend is configured independently.
* To stop using ONTAP-mode, remove or replace the affected backends. No global switch is required.
== What's next?
Apply secret before TBC; use `kubectl apply` and `-n trident` to match examples.
