Manage Autogrow Policies
After you create Autogrow Policies, you can view, update, and delete them. You can also monitor which volumes use a given policy.
View Autogrow Policies
List all policies
Use kubectl to list all Autogrow Policies in your cluster:
kubectl get tridentautogrowpolicy
Alternatively, use tridentctl:
tridentctl get autogrowpolicy
View policy details
To view the full specification and status of a policy:
kubectl describe tridentautogrowpolicy production-db-policy
To view a policy with its associated volumes in YAML format:
tridentctl get autogrowpolicy production-db-policy -o yaml
Update an Autogrow Policy
You can modify an existing policy to change its threshold, growth amount, or maximum size. Changes take effect immediately for all volumes that use the policy.
Important Changes affect all volumes that use the policy. When possible, test changes in a non-production environment first.
Steps
  1. Edit the policy:
    kubectl edit tridentautogrowpolicy production-db-policy
  2. Modify the spec fields as needed:
    spec:
      usedThreshold: "75%"    # Changed from 80%
      growthAmount: "20%"     # Changed from 10%
      maxSize: "1Ti"          # Changed from 500Gi
  3. Save and exit. The changes take effect immediately.
Update considerations
  • Immediate effect: All volumes that use the policy adopt the new parameters at the next growth evaluation.
  • No volume restart required: Changes apply to the next growth operation.
  • Test first: Validate changes in a non-production environment when possible.
  • Communicate changes: Notify teams when you modify shared policies.
Delete an Autogrow Policy
Autogrow Policies use finalizer protection to prevent accidental deletion while volumes actively use them.
Steps
  1. Delete the policy:
    kubectl delete tridentautogrowpolicy production-db-policy
  2. If volumes still use the policy, the deletion enters a Deleting state. Check which volumes are affected:
  3. Remove the policy from each affected volume. Choose one of the following options:
    • Option A: Explicitly disable autogrow by setting the annotation to "none":
      kubectl annotate pvc <pvc-name> \
        trident.netapp.io/autogrowPolicy="none" \
        --overwrite
    • Option B: Remove the annotation entirely:
        trident.netapp.io/autogrowPolicy-
Deletion behavior
Scenario Behavior
No volumes use the policy
Policy is deleted immediately.
Volumes use the policy
Policy enters Deleting state. A finalizer blocks completion until all volumes are removed.
All volumes are removed from the policy
Finalizers are removed and the policy is deleted.
Monitor Autogrow Policy usage
Check volumes using a policy
tridentctl get autogrowpolicy production-db-policy -o json | jq '.volumes'
Find which policy a volume uses
kubectl get pvc database-pvc -o jsonpath='{.metadata.annotations.trident\.netapp\.io/autogrowPolicy}'
Monitor policy events
kubectl get events --field-selector involvedObject.kind=TridentAutogrowPolicy
Supported protocols
Autogrow supports the following storage protocols:
  • NFS
  • iSCSI
  • FCP
  • NVMe
Note For SAN volumes, if the configured growthAmount is 50 MiB or less, Trident automatically increases the growth amount to 51 MB for the resize operation, as long as the resulting size does not exceed maxSize.
Supported backends
Autogrow supports ONTAP backends. Autogrow also supports Google Cloud NetApp Volumes (GCNV) for both NAS and SAN volumes.
Known limitations
  • ONTAP NVMe raw block volumes: Volumes created with ONTAP versions earlier than 9.16.1 do not support autogrow.
  • Existing volumes (brownfield deployments): Autogrow might not work for existing volumes even if a valid Autogrow Policy is applied. This limitation is due to an ongoing migration of volume publications. To confirm that migration is complete, check the Trident controller logs for "Migration completed" messages.
Frequently asked questions
When does Trident evaluate the threshold?
Trident continuously monitors volume usage. When the used capacity crosses the usedThreshold, Trident creates an internal resize request and expands the volume by the configured growthAmount.
For example, this policy triggers expansion at 80% capacity and grows the volume by 10% each time, up to a maximum of 500 GiB:
kind: TridentAutogrowPolicy
metadata:
spec:
  usedThreshold: "80%"
  growthAmount: "10%"
  maxSize: "500Gi"
Can I apply a policy after volumes are already provisioned?
Yes. You can create an Autogrow Policy at any time and apply it to existing PVCs by adding or updating the trident.netapp.io/autogrowPolicy annotation. You do not need to recreate the PVC or the StorageClass.
To apply a policy to an existing PVC:
  trident.netapp.io/autogrowPolicy="production-db-policy" \
  --overwrite
To apply a policy to an existing StorageClass:
kubectl annotate storageclass ontap-gold \
  --overwrite
What happens if I set an Autogrow Policy on both the StorageClass and the PVC?
The PVC annotation always takes precedence. If a PVC has the trident.netapp.io/autogrowPolicy annotation, Trident uses that value regardless of what the StorageClass specifies. Refer to Policy precedence for details.
For example, given this StorageClass:
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
  annotations:
    trident.netapp.io/autogrowPolicy: "standard-agp"
allowVolumeExpansion: true
And this PVC that overrides the StorageClass policy:
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
  annotations:
    trident.netapp.io/autogrowPolicy: "logs-policy"
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 50Gi
  storageClassName: ontap-gold
Trident uses logs-policy for database-pvc, not standard-agp.
How do I disable autogrow for a specific volume?
Set the PVC annotation to "none". This setting overrides any StorageClass-level policy for that volume:
  --overwrite
You can verify that autogrow is disabled:
kubectl get pvc <pvc-name> -o jsonpath='{.metadata.annotations.trident\.netapp\.io/autogrowPolicy}'
Expected output
none
What happens when a volume reaches maxSize?
Trident stops expanding the volume. It creates no further resize requests for that volume, even if usage continues to increase beyond the usedThreshold.
For example, with this policy, Trident stops growing the volume after it reaches 100 GiB:
metadata:
spec:
  usedThreshold: "90%"
  growthAmount: "10Gi"
  maxSize: "100Gi"
To allow unlimited growth, omit maxSize or set it to 0:
metadata:
spec:
  usedThreshold: "85%"
  growthAmount: "10%"
Can I change a policy without restarting volumes?
Yes. When you update a policy, all volumes that use that policy adopt the new parameters at the next growth evaluation. No volume restarts are required.
To update a policy in place:
Modify the fields as needed:
spec:
Save and exit. Verify the updated policy:
kubectl get tridentautogrowpolicy production-db-policy
Expected output
NAME                   USED THRESHOLD   GROWTH AMOUNT   STATE
production-db-policy   75%              20%             Success
Why is my policy in a Failed state?
A Failed state indicates that the policy specification contains validation errors. Run the following command to view the error details:
kubectl describe tridentautogrowpolicy <policy-name>
Common causes include an invalid usedThreshold (must be 1–99%), a growthAmount that exceeds maxSize, or an invalid Kubernetes quantity format. Correct the specification and reapply:
kubectl apply -f autogrow-policy.yaml
Why can't I delete a policy?
Policies use finalizer protection. If volumes still use the policy, deletion enters a Deleting state and waits until you remove all volumes from the policy.
Identify the affected volumes:
Then remove the annotation from each PVC:
# Option A: Explicitly disable autogrow
  --overwrite
# Option B: Remove the annotation entirely
After you remove all volumes, Trident releases the finalizer and deletes the policy.
Which backends does autogrow support?
Autogrow supports ONTAP backends. It also supports Google Cloud NetApp Volumes (GCNV) for both NAS and SAN volumes.
Autogrow supports the NFS, iSCSI, FCP, and NVMe protocols. NVMe raw block volumes require ONTAP 9.16.1 or later.
Existing volumes in brownfield deployments might require volume publication migration to complete before autogrow takes effect. To verify migration status, check the Trident controller logs:
kubectl logs -l app=trident-controller -n trident | grep "Migration completed"
The following StorageClass examples show autogrow configured for NAS and SAN backends:
NAS backend
kind: StorageClass
metadata:
  annotations:
    trident.netapp.io/autogrowPolicy: "standard-autogrow"
parameters:
  backendType: "ontap-nas"
  fsType: "ext4"
SAN backend
kind: StorageClass
metadata:
  annotations:
    trident.netapp.io/autogrowPolicy: "production-db-policy"
parameters:
  backendType: "ontap-san"
  fsType: "ext4"
What is the minimum growth amount for SAN volumes?
For SAN volumes, the effective minimum growth amount is 51 MB. If you configure a growthAmount of 50 MiB or less, Trident automatically increases the growth to 51 MB for the resize operation.
For example, this policy sets a growthAmount of "40Mi", but Trident applies a 51 MB growth for any SAN volume that uses it:
metadata:
spec:
  growthAmount: "40Mi"
  maxSize: "100Gi"
To avoid this automatic adjustment, set growthAmount to a value greater than 50 MiB:
metadata:
spec:
  growthAmount: "100Mi"
  maxSize: "500Gi"
