Deploy Trident
Contributors juliantap netapp-aruldeepa joan-ing netapp-mwallis
Trident for Docker provides direct integration with the Docker ecosystem for NetApp storage platforms. It supports the provisioning and management of storage resources from the storage platform to Docker hosts, with a framework for adding additional platforms in the future.
Multiple instances of Trident can run concurrently on the same host. This allows simultaneous connections to multiple storage systems and storage types, with the ablity to customize the storage used for the Docker volumes.
What you'll need
See the prerequisites for deployment. After you ensure the prerequisites are met, you are ready to deploy Trident.
Docker managed plugin method (version 1.13/17.03 and later)
Note
Before you begin
If you have used Trident pre Docker 1.13/17.03 in the traditional daemon method, ensure that you stop the Trident process and restart your Docker daemon before using the managed plugin method.
  1. Stop all running instances:
    pkill /usr/local/bin/netappdvp
    pkill /usr/local/bin/trident
  2. Restart Docker.
    systemctl restart docker
  3. Ensure that you have Docker Engine 17.03 (new 1.13) or later installed.
    docker --version
    If your version is out of date, install or update your installation.
Steps
  1. Create a configuration file and specify the options as follows:
    • config: The default filename is config.json, however you can use any name you choose by specifying the config option with the filename. The configuration file must be located in the /etc/netappdvp directory on the host system.
    • log-level: Specify the logging level (debug, info, warn, error, fatal). The default is info.
    • debug: Specify whether debug logging is enabled. Default is false. Overrides log-level if true.
      1. Create a location for the configuration file:
        sudo mkdir -p /etc/netappdvp
      2. Create the configuration file:
        cat << EOF > /etc/netappdvp/config.json
          "version": 1,
          "storageDriverName": "ontap-nas",
          "managementLIF": "10.0.0.1",
          "dataLIF": "10.0.0.2",
          "svm": "svm_nfs",
          "username": "vsadmin",
          "password": "password",
          "aggregate": "aggr1"
        EOF
  2. Start Trident using the managed plugin system. Replace <version> with the plugin version (xxx.xx.x) you are using.
    docker plugin install --grant-all-permissions --alias netapp netapp/trident-plugin:<version> config=myConfigFile.json
  3. Begin using Trident to consume storage from the configured system.
    1. Create a volume named "firstVolume":
      docker volume create -d netapp --name firstVolume
    2. Create a default volume when the container starts:
      docker run --rm -it --volume-driver netapp --volume secondVolume:/my_vol alpine ash
    3. Remove the volume "firstVolume":
      docker volume rm firstVolume
Traditional method (version 1.12 or earlier)
Before you begin
  1. Ensure that you have Docker version 1.10 or later.
    docker --version
    If your version is out of date, update your installation.
    curl -fsSL https://get.docker.com/ | sh
  2. Ensure that NFS and/or iSCSI is configured for your system.
Steps
  1. Install and configure the NetApp Docker Volume Plugin:
    1. Download and unpack the application:
      ----trident-installer-26.10.1.tar.gz
      wget https://github.com/NetApp/trident/releases/download/10.0/
      tar zxf trident-installer-26.10.1.tar.gz
.. Move to a location in the bin path:
[source,console]
sudo mv trident-installer/extras/bin/trident /usr/local/bin/
sudo chown root:root /usr/local/bin/trident
sudo chmod 755 /usr/local/bin/trident
.. Create a location for the configuration file:
[source,console]
.. Create the configuration file:
[source,console]
cat << EOF > /etc/netappdvp/ontap-nas.json
[source,json]
"version": 1,
"svm": "svm_nfs",
EOF
. After placing the binary and creating the configuration file, start the Trident daemon using the desired configuration file.
[source,console]
sudo trident --config=/etc/netappdvp/ontap-nas.json
NOTE: Unless specified, the default name for the volume driver is "netapp".
After the daemon is started, you can create and manage volumes by using the Docker CLI interface.
. Create a volume:
[source,console]
docker volume create -d netapp --name trident_1
. Provision a Docker volume when starting a container:
[source,console]
docker run --rm -it --volume-driver netapp --volume trident_2:/my_vol alpine ash
. Remove a Docker volume:
[source,console]
docker volume rm trident_1
[source,console]
docker volume rm trident_2
== Start Trident at system startup
A sample unit file for systemd based systems can be found at `contrib/trident.service.example` in the Git repo. To use the file with RHEL, do the following:
. Copy the file to the correct location.
You should use unique names for the unit files if you have more than one instance running.
[source,console]
cp contrib/trident.service.example /usr/lib/systemd/system/trident.service
. Edit the file, change the description (line 2) to match the driver name and the configuration file path (line 9) to reflect your environment.
. Reload systemd for it to ingest changes:
[source,console]
systemctl daemon-reload
. Enable the service.
This name varies depending on what you named the file in the `/usr/lib/systemd/system` directory.
[source,console]
systemctl enable trident
. Start the service.
[source,console]
systemctl start trident
. View the status.
[source,console]
systemctl status trident
NOTE: Any time you modify the unit file, run the `systemctl daemon-reload` command for it to be aware of the changes.
