Switch from Trident community operator to OpenShift certified operator
To switch from the NetApp Community Trident Operator to the Red Hat OpenShift Certified Trident Operator, you'll need to uninstall the community operator and then install the certified operator using the OperatorHub.
Before you begin
Before you begin the installation, prepare your environment for Trident installation.
Uninstall the NetApp Trident community operator
Steps
Use the OpenShift console to navigate to the OperatorHub.
Find the NetApp Trident community operator.   Do not select Delete all operand instances from this operator.
Click Uninstall.
Install the OpenShift certified Operator
Steps
Navigate to the Red Hat OperatorHub.
Search for and select the NetApp Trident Operator.
Follow the on-screen instructions to install the operator.
Verification
Check the OperatorHub in the console to ensure the new certified operator has been installed successfully.
 PDFs
PDFs
