Modify resources as you restore them using custom resources
Resource transformations enable you to modify a resource as it is being restored. This is useful when the restored version needs to differ from the original, for example, updating a hostname in a ConfigMap when restoring an application to a different cluster.
How resource modification works
The transformations field in SnapshotRestore, BackupRestore, AppMirrorRelationship, and other restore resources enables you to modify Kubernetes resources during the restore process. This is useful when the restored application needs to be configured differently from the original, for example, changing hostnames, registry URLs, resource limits, or environment variables.
Resource transformations use RFC 6902 JSON Patch operations and RFC 6901 JSON Pointer paths to target and modify specific fields within Kubernetes resources.
The following shows the basic structure of a restore object that contains resource transformations:
apiVersion: protect.trident.netapp.io/v1
kind: SnapshotRestore
metadata:
namespace: target-namespace
spec:
appVaultRef: my-vault
appArchivePath: /path/to/snapshot
namespaceMapping:
- source: source-ns
destination: target-ns
transformations:
- resource:
kind: ConfigMap # Required: resource kind
group: "" # Optional: API group (empty for core resources)
version: "" # Optional: API version
name: "" # Optional: specific resource name
operations:
- op: replace # Operation type
path: "/data/key" # JSON Pointer path
value: "new-value" # New value (for add/replace/test)
Supported resources
You can use resource transformations with resources that match the following criteria:
kind (required): The Kubernetes resource kind (for example,
ConfigMap,Deployment,Pod) -
group (optional): The API group (for example,
apps,route.openshift.io) — omit for core resources -
version (optional): The API version (for example,
v1,v1beta1) -
name (optional): Apply only to a specific resource by name
Modifying PersistentVolumeClaims and Namespaces is currently not supported. |
Supported operations
You can use the following operations to modify resources: add, copy, move, remove, replace, and test.
Add a value to a resource
Use the add operation to add a new field or value at the specified path. You can add data to objects or arrays.
The following example adds a node selector to a Deployment resource:
transformations:
- resource:
kind: Deployment
operations:
- op: add
path: "/spec/template/spec/nodeSelector"
value:
"topology.kubernetes.io/zone": "us-east-1a"
disktype: "ssd"
Use the following command to run this transformation using the command line:
tridentctl-protect create snapshotrestore <restore_name> \
--snapshot <namespace/snapshot-name> \
--namespace-mapping <source-ns>:<dest-ns> \
--transformation 'apps,v1,Deployment:add{"path":"/spec/template/spec/nodeSelector","value":{"topology.kubernetes.io/zone":"us-east-1a","disktype":"ssd"}}'
Copy a value within a resource
Use the copy operation to copy a value from one path to another within the same resource. The source is not changed.
The following example duplicates a data key for a ConfigMap object:
transformations:
- resource:
kind: ConfigMap
operations:
- op: copy
path: "/data/backup-key"
--transformation ',v1,ConfigMap:copy{"from":"/data/source-key","path":"/data/backup-key"}'
Move a value within a resource
Use the move operation to move a value from one path to another within the same resource. The source is removed and the value is placed at the destination.
The following example renames a data key for a ConfigMap object:
transformations:
- resource:
kind: ConfigMap
operations:
- op: move
path: "/data/NEW_KEY"
--transformation ',v1,ConfigMap:move{"from":"/data/OLD_KEY","path":"/data/NEW_KEY"}'
Remove a value from a resource
Use the remove operation to remove a field or value at the specified path.
The following example removes an annotation from a ConfigMap resource:
transformations:
- resource:
kind: ConfigMap
operations:
- op: remove
path: "/metadata/annotations/kubectl.kubernetes.io~1last-applied-configuration"
In the path for the above example, ~1 is the JSON Pointer escape sequence for /.
--transformation ',v1,ConfigMap:remove{"path":"/metadata/annotations/kubectl.kubernetes.io~1last-applied-configuration"}'
Replace a value within a resource
Use the replace operation to replace an existing value within a resource at the specified path. The JSON path must already exist.
The following example changes a hostname for a Route object:
transformations:
- resource:
kind: Route
group: route.openshift.io
operations:
- op: replace
path: "/spec/host"
value: "prod.example.com"
--transformation 'route.openshift.io,v1,Route:replace{"path":"/spec/host","value":"prod.example.com"}'
Test the resource modification
Use the test operation to verify that the value at a path matches an expected value before the other operations are applied. If the test fails, the entire modification is rolled back.
The following example updates database-host only if environment is set to staging:
transformations:
- resource:
kind: ConfigMap
operations:
- op: test
path: "/data/environment"
value: "staging"
- op: replace
path: "/data/database-host"
value: "prod-db.example.com"
--transformation ',v1,ConfigMap:test{"path":"/data/environment","value":"staging"},replace{"path":"/data/database-host","value":"prod-db.example.com"}'
