Refresh NVMe data LIFs
Enable NVMe data LIF refresh to let published NVMe volumes use LIFs that are added, removed, or assigned a new address without recreating the backend or restarting Trident.
Overview
When you add an ONTAP SAN backend, Trident discovers the NVMe data LIFs for the SVM. By default, Trident retains that set of LIFs until you add the backend again or restart Trident.
Set enableDataLIFRefresh to true to refresh NVMe data LIFs while Trident is running. Published NVMe volumes then use LIFs that are added, removed, or assigned a new address.
This option is an installation parameter, not a backend configuration parameter. It is disabled by default.
NVMe data LIF refresh is available starting with Trident 26.10.
This feature applies to:
ontap-sanwithsanType: nvmeon unified ONTAP. -
ontap-sanusing NVMe/TCP on ASA r2.
Removing or replacing all data LIFs at the same time is disruptive. If you plan to remove or replace all data LIFs, make sure a replacement LIF is in place first so that data access is not interrupted. |
Trident operator
For a new installation, set enableDataLIFRefresh in the TridentOrchestrator spec:
kind: TridentOrchestrator
metadata:
spec:
namespace: trident
enableDataLIFRefresh: true
Apply the manifest:
kubectl apply -f tridentorchestrator_cr.yaml
For an existing installation, patch the TridentOrchestrator:
kubectl patch torc trident --type=merge -p '{"spec":{"enableDataLIFRefresh":true}}'
Verify the applied value:
kubectl get torc trident -o jsonpath='{.status.currentInstallationParams.enableDataLIFRefresh}'
Helm
For a new installation, set the Helm value:
helm install trident netapp-trident/trident-operator \
--namespace trident --create-namespace \
--set enableDataLIFRefresh=true
For an existing Helm installation, upgrade the release with the value enabled:
helm upgrade trident netapp-trident/trident-operator \
--namespace trident \
--reuse-values \
You can also set enableDataLIFRefresh: true in a Helm values file and pass it to helm upgrade with -f <values-file>.
tridentctl
For a new installation, use the --enable-datalif-refresh flag:
tridentctl install --enable-datalif-refresh -n trident
To enable the option on an existing tridentctl installation, uninstall Trident and install it again with the flag. Follow the precautions in Uninstall Trident before uninstalling.
tridentctl uninstall -n trident
The --enable-datalif-refresh flag is an installation option and is not shown in tridentctl install --help.
