Configure automatic backend configuration for AWS FSx for NetApp ONTAP
Trident supports automatic backend configuration for AWS FSx for NetApp ONTAP (FSxN). When you create a StorageClass that includes the required FSxN parameters, Trident automatically creates the corresponding backend and a VolumeSnapshotClass.
Understand how automatic backend configuration works
Trident derives backend configuration from the StorageClass definition.
When you apply the StorageClass, Trident validates the required parameters, creates the backend, and annotates the StorageClass with status.
Trident creates the VolumeSnapshotClass only once.
Trident reuses the same VolumeSnapshotClass for subsequent StorageClasses.
Specify required StorageClass parameters
To trigger automatic backend creation, define the required parameters in the StorageClass parameters section.
| Parameter | Required | Type | Description |
Yes |
string |
FSx for NetApp ONTAP filesystem ID |
Yes |
string |
Trident storage driver (for example, |
Yes |
string |
Name of the Kubernetes Secret that contains FSx for ONTAP credentials |
Specify optional parameters
You can pass optional backend parameters through the StorageClass.
Define all optional values as strings in the StorageClass parameters section.
For a complete list of backend parameters, see:
FSx for NetApp ONTAP backend configuration.
Create a StorageClass
The following example shows a StorageClass that triggers automatic backend configuration.
metadata:
annotations:
description: "Demo StorageClass for FSx for NetApp ONTAP"
parameters:
fsxFilesystemID: "fs-0abc123"
storageDriverName: "ontap-nas"
credentialsName: trident-fsx-credentials
allowVolumeExpansion: true
reclaimPolicy: Delete
volumeBindingMode: Immediate
After you apply the StorageClass, Trident creates the backend automatically.
You can create PersistentVolumeClaims that reference this StorageClass.
Verify backend configuration status
Trident records the result of backend creation in StorageClass annotations.
| Annotation | Description |
Configuration result ( |
Detailed status or error message |
Name of the internal configurator resource |
Indicates the StorageClass is managed by Trident |
Storage pools created for this backend |
To verify status, run:
kubectl get storageclass ontap-fsx-demo -o yaml
Confirm that trident.netapp.io/configuratorStatus is set to Success.
If the value is Failure, review trident.netapp.io/configuratorMessage for the error.
Add additional FSxN file systems
If you need additional storage capacity while continuing to use the same StorageClass, add additional FSxN file system IDs.
Edit the StorageClass and add the following annotation:
metadata:
annotations:
trident.netapp.io/additionalFsxNFileSystemID: '["fs-03cc1a718cddd6e248"]'
After you apply the change, Trident updates the backend configuration and updates the StorageClass annotations.
Operational considerations and limitations
Deleting a StorageClass usually deletes the associated Trident backend.
This can disrupt storage connectivity and break running workloads.
Validate the impact before you delete a managed StorageClass.
Automatic backend configuration is supported only for AWS FSx for NetApp ONTAP.
