Understand RWX NVMe subsystem limits
ReadWriteMany (RWX) volumes that use the NVMe protocol have a scalability limit of 64 nodes per volume. The following includes the limitations, explains the NVMe subsystem architecture involved, and outlines the required resolution steps.
Understand the 64-node limit
If you plan to use ReadWriteMany (RWX) volumes with the NVMe protocol, a single RWX NVMe volume cannot be mounted by more than 64 nodes in a Kubernetes cluster.
Do not schedule workloads that mount the same RWX NVMe PersistentVolumeClaim across more than 64 nodes.
This limitation applies only to RWX volumes that use the NVMe protocol.
Understand NVMe subsystem models
Per-volume subsystem model (Trident releases earlier than 26.02)
In Trident releases earlier than 26.02, RWX NVMe volumes are provisioned using a per-volume subsystem model.
Each RWX NVMe volume is mapped to its own dedicated NVMe subsystem on ONTAP.
This model is simple, but it has a lower scalability limit.
In large Kubernetes clusters, subsystem controller limits are reached quickly because each RWX volume consumes a dedicated subsystem.
Super-subsystem model (introduced in Trident 26.02)
Starting with Trident 26.02, RWX NVMe volumes use a shared super-subsystem model.
Multiple RWX NVMe volumes share the same NVMe subsystem.
Each super-subsystem supports up to 1024 namespaces (volumes).
This model significantly improves scalability for RWX workloads and reduces the likelihood of reaching ONTAP subsystem limits.
Each RWX NVMe volume supports up to 64 nodes.
Identify error symptoms
If you create or attach RWX NVMe volumes at scale, you might observe errors similar to the following:
Maximum number of controllers reached. No more controllers can be created.
This error indicates that the ONTAP NVMe subsystem controller limit has been reached.
Resolve subsystem limit errors
To move beyond per-volume subsystem limitations and take advantage of the super-subsystem model, upgrade to Trident 26.02 or later.
Upgrade Trident to apply the super-subsystem model
To apply the super-subsystem model for RWX NVMe volumes:
Upgrade Trident to version 26.02 or later.
Scale down all pods that use RWX NVMe volumes to zero replicas.
Verify that no workloads are actively using RWX NVMe volumes.
Scale the pods back up.
This restart sequence ensures that RWX NVMe volumes are attached using the super-subsystem model.
The 64-node limit applies per RWX NVMe volume.
Other access modes and other protocols are not affected.
